Question about Duravit 0063810000 Stark 3 Toilet Seat and Cover with Stainless Steel Hinge
The toilet seat sits crooked on the bowl - how can I adjust or tighten the silver attachment points?
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
olddewsons
  • 38 Answers
SOURCE: toilet seat come loose and no obvious way to
well there should be 2 hinges rite behind seat. you wont see the screws cause they are under a plastic cover. take a flat head screw driver and pry up cover. lil cover should lift up towards tank. then you should see screws. the nut is under bowl you have to bend down then look up to see them or do what i do and feel for them. take big flat head or big philips screw driver and while you hold nut titen screw. hope this helps. duane:)
Posted on Oct 11, 2009
kachbibi1
  • 979 Answers
SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Posted on Jan 28, 2009
  • 10865 Answers
SOURCE: elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Posted on Jan 31, 2009
  • 653 Answers
SOURCE: raising water level in the toilet bowl.
The water level in the bowl is limited by the height of the internal trap down stream from the bowl. There is no adjustment possible. If the problem is odors, you can either flush more often, turn on the exhaust fan, or buy a different brand or model of toilet.
Posted on Apr 04, 2009
How do you tighten the posts on a rak toilet
Look where the seat attaches to the toilet bowl. There are 2 nuts underneath.
Those are the nuts you tighten. they will hold the seat firmly.
Aug 19, 2014 | Home
Wand will not launch when seat is activated
follow this steps and fix it. God bless you
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism . Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If the bowl drains sluggishly, remove the clog with a plunger or auger, or raise the water level in the tank .
If water runs continuously through the toilet, lower the water level in the tank , adjust or replace a lift chain or wire , repair or replace a worn flush valve , clean or replace the valve seat assembly .
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
If the seat is cracked or unsightly, replace it .
If the bowl or tank is cracked or otherwise unacceptable, replace the entire toilet .
Nov 25, 2013 | Home
Have a Duo Flush System from FluidMaster. It continuest to ghost flush. Have adjusted the float valve several times but is still ghost flushes. How can I stop this?
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism. Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball , or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
Nov 25, 2013 | Delta Home
How to tighten an american standard toilet seat
They all work pretty much the same. Feel around the top rim of the bowl near where the tank meets the bowl you should find one bolt underneath on either side of the toilet seat. Tighten the nut under there to tighten the seat.
Oct 24, 2013 | American Standard Church Seats EL270...
Toilet seat slide
try to tighten mounting bolts be careful not to over tighten may crack poclean also see if seat has rubber gromets between hinge mount point at bowl.
Oct 30, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
When you sit on the ring it veers off to the left and you are left sitting there crooked. How do we adjust it?
See if nuts on studs on bottom where it mounts to the floor & flange are loose. If they are loose tighten both of them evenly. If they are tight you will need to replace wax ring that is between toilet & floor.Turn off shutoff water valve to toilet. Flush once holding down handle to let tank drain. Remove both nuts & lift toilet off flange. Remove wax ring. Scrape all old wax off toilet & floor flange. Install new wax ring. Set down toilet on ring & snug nuts evenly. Sit on seat & apply your weight evenly to distribute wax & level. Retighten nuts. Turn water back on. Allow tank to refill. Flush toilet & check for leaks.
Sep 30, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
How to stop seat from wobbling doesnt seem to have screws that fo into seat just a place for seat to sit on and then some cap to put over but nothing seems to tighten it.Im tired of falling off the toilet
First lift the covers off where the bolts should be (they should lift towards the tank). Are the bolts in place? If not, go to your neighborhood hardware store and look for replacement hardware. (Most stores will have staff willing to help you find the right parts.) Is the bowl damaged so that the holes seem large compared to the holes in the seat anchor points? Are the seat anchor points damaged?
The bolts should have nuts (and possibly washers, but not all models use them) underneath the bowl. Screw down the bolt while holding the nut from turning (so you need an adjustable wrench or appropriately sized wrench). Again see the local hardware store for the hardware if you do not have the nuts. Keep the seat centered as you tighten the bolts. (Alternate tightening until it is stable - do not tighten one bolt all the way down before doing the other side. You risk overtightening and cracking the bowl.)
I hope this helps.
(if the seat is damaged, you may want to replace it. If the bowl is damaged you must replace that.)
Jun 10, 2010 | Kohler - Toilet Seat - Moondance -...
Have to replace two new toilets seats,the seats move
Martin, Jacuzzi has a one year warranty on toilet seats so if you have defective seats and they were purchased less than a year it is covered you will have to find a dealer near you, I provided a link for you to accomplish this. How is the seat attached? There should be two plastic screws with a nut on the underside which can be tightened these tend to loosen and nee re-tightening every so often. I hope this has helped. Thanks for using FIXYA, good luck and have a great day. Jeff
Find A Jacuzzi Dealer
Apr 07, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Jacuzzi Era elongated seat attachment
first need to buy the longer oval seat so it sits correctly at the front most mounting screws are universal-- go buy thin rubber washers and trim and place between the hinge and bowl than tighten down this will stop slippage but the front if not correctly sitting on the bowl will still cause problems
Jan 22, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Duravit 0063810000 Stark 3 Toilet Seat and Cover with Stainless Steel Hinge Logo
1,174 people viewed this question
Top Duravit Home Experts
Craig Butler
Craig Butler
Paul Carew
Lawrence Oravetz
Are you a Duravit Home Expert? Answer questions, earn points and help others
