Question about Samsung Digimax S630 Digital Camera
I turn on my camera, samsung es30, and it says "card error: help OK", then the menu, 1, turn the camera on and off, 2. remove the memory card and re-insert it, 3. format the memory card. Options 1 and 2 don't work, and I can't format the memory card because i can't get off the options screen. Please help!
mark sox
  • 24 Answers
SOURCE: Samsung S630 Digital Camera, Card Error and Format Error
you have several options:
1. see in the specification details of your camera what memory card is compatible for camera. for S630 it is SDHC/MMC/SD card (Up to 4GB Guaranteed). see if you're using memory card within this capacity and type. If you're using a different memory card type and capacity, try to use memorycard that is compatible with your camera.
2. try to use memory card to other devcie like cameras, cellphones and other devices and if it still has error problem, your card may be the one defective. use other cards.
3. try to take pictures without using memory card. use only the internal memory of camera. if camera still display this error meassage, camera needs service.
hope these options solve one of your problems. c",)
Posted on Jan 11, 2008
Gwenivie
  • 39 Answers
SOURCE: format memory card option on the menu
Once FORMAT option has been accidentally selected
on the menu of your camera and there are pictures saved on your memory card, then it will automatically be deleting all the stored images on your card.
It's just really recommended to use the FORMAT option if it's
your first time to be putting the card on the camera.
But, if there are pictures already stored there, try to stay away from that OPTION so that your pictures will not be deleted.
There is no way for pictures to be retrieved.
So. it's advisable as well that you should transfer first your pictures to your PC before you could select on the FORMAT
option of your camera.
Posted on Jan 20, 2008
CrazyLarry
  • 173 Answers
SOURCE: card will not format
memory card? and SD card? whatever the card hook your camera to a usb to computer and find it under "my computer"
look at all your drives you should have like c, d , e, f, g, h, select the last drive and see if it finds your card if so try formatting it through the computer, whatever you do dont select c or d to format. if problem persists buy a new SD. I find good deals on ebay or Walmart.
Posted on Feb 21, 2008
SOURCE: samsung nv3 sd 'card error ! ' message
my camera say card error, can u help?
Posted on Jun 16, 2008
  • 7993 Answers
SOURCE: I purchased a Sony cybershot DSC- S930 and
The camera does not recognize the card because
1. Card not compatible
2. Camera cannot handle such a large capacity.
3.Card not inserted correctly.
Maybe a recent firmware update can address the 2nd limitation.
Hope it helps.
Posted on Sep 11, 2009
I am unable to take photo because of DCF full Erros come often ES30
This is what the manual says:
File names do not match the DCF standard.
Transfer the files on the memory card to your
computer, and then format the card. (p. 76)
Format in the camera, not in a cardslot of your computer.
Lots of errors, can be solved by removing and reinserting the battery(ies)
Nov 02, 2013 | Samsung ES30 Digital Camera
Samsung es30 driver
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 17, 2012 | Samsung ES30 Digital Camera
Cd drivers for samsung es30
Consider NOT using a driver.
Oct 25, 2012 | Samsung ES30 Digital Camera
My Samsung 5x ES30 Zoom Did Not Operate Normaly
Ensure you're using new batteries and try again.
Apr 02, 2012 | Samsung ES30 Digital Camera
Hi, Our daughter has a Samsung ES30 12.2 megapixel camera. I just put a new sd card in and it says Card Error, When you click on OK, it tells you to 1. Turn the camera off and on again, 2. remove and...
You need to format the card.
Insert the memory card into the system and this will be displayed as the mass storage device in my computer. Right click over the removable disk and then click format. It will format the memory card.
Then insert the memory card into the camera. Now the camera will not show the error message.
Hope this helps.
Shane
Apr 04, 2011 | Cameras
When l take my SD card, it still says " DCF Full Error"
Hello and Welcome
The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You will have to format the card with the Samsung camera.However, make sure you download any photos to your computer first
Anymore help, I am here to help
Best of Luck
Concerned:
Uxair Shah
Mar 14, 2011 | Samsung ES30 Digital Camera
When I take my SD card out, it still says "DCF
well as long as it works when u put the sd card in then its all good right?
also
  1. DCF Full Error error message. The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You'll have to format the card with the Samsung camera. However, make sure you download any photos to your computer first.
Mar 07, 2011 | Samsung ES30 Digital Camera
Our Samsung ES30 is showing a DCF Full Error. It is only 1 month old and has a 2gig SD card in it. What is the problem?
.try to format both...
remove the sd card on your unit,then insert that to the mmc reader then format it to your pc,,after formatted.,,
open your unit without sd card,,go to menu - setting - format -reset
after that insert it to your unit.,then take atleast 15 shots.,.then turn it off.,.,then open again for you to find out if this procedure will okey.,
Feb 23, 2011 | Cameras
My Samsung ES30 camera gives me the DCF Full Error message. I tried other solutions, such as formatting the memory card, I even tried a new memory card. I also tried drying the inside, with the batteries...
try to remove the memory card and then format the unit without memory card.,after formatting the unit.,reset it and then format the mmc to the pc.,after 10 seconds.,insert the mmc and then power on again.,
Jan 16, 2011 | Samsung Cameras
DCF Full Error
I have got a Samsung ES30 Digital camera .Everytime i turn it on it always says DCF Full Error ' which i have no idea means .Please help???
Sep 25, 2008 | Samsung S860 Digital Camera
Samsung Digimax S630 Digital Camera Logo
274 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
