Question about Maytag M7D24E7A Air Conditioner
Unit spitting ice and water on inside
Unit works and then at night it starts spitting ice and water on inside.
once the unit is shut down and started in a couple of hours it works fine
    Scholar:
  • 149 Answers
Possible dirty coils or thermostat
Posted on Jul 22, 2008
Do the ice makers shut off automatically when full?
The icemaker has ice level sensor located inside the ice bin. Once ice cubes reaches the sensor, it cuts out automatically and starts once the ice level drops
May 03, 2016 | GE Refrigerators
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
Jul 29, 2012 | Hampton Bay HBLG5004 Air Conditioner
Hi, recently my a/c window unit starting making a water sloushing sound then started spitting ice. Is it dying?
What you are hearing is a water buildup in the drip pan under the unit. This is caused by a clogged drain hole and/or not enough downward tilt on the rear of the unit. The rule of thumb is 1/4" to 1/2' rear downward tilt. This allows the water to flow to the rear of the drip pan and out thru the drain hole. The spitting ice, is from the fan blades hitting the water in the drip pan. Turn the unit OFF & unplug it. Then check and adjust if necessary, the things I mentioned above. Aslo, be sure that the air intake filter remains clean.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Maytag M7D24E7A Air Conditioner
My mr coffee Iced tea maker has been working great for a year. Tonight it tripped a ground fault breaker, and only started a tea cycle. I reset the breaker and the machine squirted once then started to...
we had one like this and we suspect a power surge damaged it. it worked fine one night, but we had a lightning storm that night and we think lightning hit out power pole and fried several of our appliances. the tea maker would come on but like you described it seems to forget what its doing. consider the possibility that a power surge got it (doesn't have to be lightning, several things can cause a surge)
Aug 12, 2010 | Mr. Coffee Iced Tea Maker TM1S
When ice maker fills the water spills over edge of ice tray and down into ice storege bin. This creates large ice clumps that that jam unit. Is there a water pressure regulator that I can turn down...
Good day,
No pressure regulator. When the ice maker goes thru a harvest, at the end, it turns on the water valve for 7 seconds, after which the valve must shut off smartly.
The usual cause, is the valve in the rear back of the machine contunues to weep for a while, causing an overfill situation.
Replacing the valve is the only known solution.
This is based on the fact it worked propery at one time, and your not connected to a well, which has a regulator, that is set too high.
Thank you for using FixYa
Jan 19, 2010 | Refrigerators
My Kenmore coldspot refrigerator is not producing ice. The water works fine, but no ice.
I'd start by making sure the ice maker is not simply "shut off". no offense, it is a common occurrence. the unit can be shut off several ways depending on the model you have. some ice makers have a switch right on the ice maker module/head. some have a switch at the side wall of the freezer, if it has an ice bucket on the door, and most if not all ice makers have a shut off arm to automatically shut it down when it's harvested a full bucket of ice, which can accidentally be pushed up into the off position by simply reaching in to grab ice or something other. if all that has been ruled out, ok.
next, start by pulling the unit away from the wall, or whatever the case may be in your environment, as long as you have access to the rear of the unit. (be careful of the water supply line) I should add just because you are getting water from the dispenser on the door does not necessarily mean anything about the ice maker.
**FIRST; before going any further, unplug the unit from the wall**.
now that the unit has no power. shut off the water to the unit. examine the water lines traveling along the back of the fridge so you're familiar with the routing of the lines.(draw a picture/take a photo if you think it's helpful) if this is a bottom mount, you'll see the water line for the ice maker at the lower right hand corner, if it's a top mount, it will be located towards the top right corner, (provided you're facing the back). identify where the line enters what they call the "injector" or "supply tube". you'll notice the line being held in place by a small clamp of some kind. remove this clamp. once the clamp is removed, gently pull the plastic line out of the tube. if you've got the line out of the tube, tape it to the back of the fridge out of you're way, careful not to kink it or lay it on the floor, it could be damaged or water may leak onto the floor. now you have to pull that injector tube out of the back wall. it may be pressed in there (should be) fairly snug, so you'll have to apply steady force while twisting it back and forth, it should pull out and is likely several inches long. once you have that out, is it iced up ? you'll likely have to replace the inlet valve for the ice water supply. some units have a water/ice valve all together with 2 valves on it, some have separate valves for water and ice. you'll need to determine which one by looking or even better, cross reference with the model and serial numbers at an on-line parts supplier or local parts depot.
hope that helps,
good luck
Sep 28, 2009 | Kenmore Refrigerators
Compressor starts then shuts down like head pressure building to high
Make sure that your condenser fan is working. If your unit is water cooled make sure you have water flow.
Nov 05, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Samsung window air conditioner model aw05ncm7 icing up not cooling
After I opened the front of the unit and discovered it full of ice, I left the unit off until it defrosted, so to speak, after the ice had melted, I turned the unit back on to see what happened. It is working fine now, I'm not sure why it iced up, if this is normal or not, but after it melted the problem was solved.
Jul 22, 2008 | Heating & Cooling
Hoshizaki KM-500MAH not making ice
Look at water solenoid valve when the unit is running in ice mode. Check to see if the water is shuting off completely. If the water valve does not close properly it will keep adding a little bit warm water to the ice a slow down the ice production.
Sep 21, 2007 | Hoshizaki Commercial Freezer KM-500MAH
LG Dehumidifier Not Working
the freon has leaked out, must be replaced.
Jun 05, 2007 | LG LD65EL Dehumidifier
Maytag M7D24E7A Air Conditioner Logo
554 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
