My mum has a evesham laptop she run it pluged in mains before she plugs into computer the charger is just green and when she plugs it into laptop it starts to flash and laptop will not swicth on can u help
    Genius:
  • 1,288 Answers
Sometimes this is caused by a bad battery, you could try taking the battery out and run it off the mains, however, with this make of laptop, like Gateway and Hi Grades, the issue probably lies in a burned out or faulty power board. The flashing light on the charger indicates that power is being, for want ofa better expression, "rejected" by the laptop... current has nowhere to go, so it is not flowing and the blinking light is indicating this.
As to repairs.. suggest it needs stripping down, oddly enough,the problem might just be a simple short caused by a screw working loose and shorting out a component
Posted on Jan 03, 2011
Dell inspiron said battery low plug into charger, when plugged in charger light goes out and laptop will not power on, why?
Remove the main battery from the laptop and try power, if it works the battery is bad, if no change the charger needs to be checked for proper voltage. Since your laptop is less than a year old you should have warranty for up to the year, check this asp and find your paperwork should verify.
Mar 24, 2012 | Dell Inspiron N5030 Notebook PC
My laptop pluged in but not charging
There could be many problems with your laptopFirst, check if your laptop was plugged into a surge protector (ex. Power Strip). If it wasn't, a surge could destroy the charger, power supply, or even motherboard.
Second, try a different charger. If it was the charger that broke, then try a different one. I have had this happen to many off my computers over the years.
If it is fried, take it to Staples, or a local computer shop. I would always recommend plugging computers into surge protectors. Good luck!
Feb 05, 2012 | Compaq Presario CQ62-215DX Laptop
Evesham Laptop battery not charging and now mains not working
for the battery i recomend freezeing the battery it takes a while to take effect but i had the same problem and i just put it in the freezer every night and slowly it gets better
Mar 16, 2009 | Computers & Internet
Battery problem
Evesham is no longer in business but the following url is for a company that supports their products..
http://www.tewktech.com/
Good Luck and please rate this post
Jan 30, 2009 | Evesham Nav-Cam 7700 GPS Receiver
Charger for E1705 beeps and no green light
If, when not plugged into the system, only the wall, the AC adapter LED doesn't come on and the adapter beeps, then it has failed and will require replecement. If the computer is still under warranty, the adapter is covered under the warranty.
If not covered under warranty, then buy a new AC adapter.
If the LED comes on when not plugged into the system, but goes out when connected to the portable, then the motherboard may be bad.
Nov 12, 2008 | Dell Inspiron E1705 Notebook
Evesham quest a240 looses the clock settings when switched off
Needs a new bios battery. Mine lasted 6 months before giving up. However you can leave the laptop plugged into the mains power when computer is switched off and the date/time will be kept. Otherwise change the bios battery or reset the time each time you use it. I phone Evesham and they said that the bios battery is soldered to the chassis on this model and so would need to be returned to the factory for this to be replaced. Since Evesham are now defunct you would need to get a PC repair shop to replace the battery. Is easy to do.
May 19, 2008 | Evesham Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
