Question about Dell Latitude D600 Notebook
Latitude Charger wrong
I am using a laptop with a different charger, Latitide D505 with Latitude D600 charger,
how can i fix (using this charger) this problem, and make the battery charge and laptop work on high performaces?
Ahmet
No, look maybe I'm not that good in "sentences" but that's not my problem, the problem is that Dell Latitudes laptops (many of them) has an option on BIOS to warn you when you're not using the correct charger (has to do with the wattage not voltage or amp.)
So, i know exactly the problem, i just want to know if there is any way to deal with this problem, because when your at this point, the battery will not charge and the performance will be minimum
Read the warning message yourself, so if you have any solution about my problem (not with english sentences) please let me know. If not, as for sentences i will ask my english teacher (when i will have one)
Thank you for your time.
Posted on Jul 10, 2008
Firstly, you should try to use correct sentence structure.
Secondly, as long as it's a pa-10 or pa-12 for the d600 you should be fine. the chargers are not specific to each laptop, rather they are more specific to the dell product family(the type of power connectors on each).
Posted on Jul 09, 2008
Why my lap top battery power goes off soon while starting?
These laptops are notorious for developing battery issues. We've got one at our house that would basically be a paperweight without a charger and external monitior. The best fix for this is to buy a new battery.
May 19, 2014 | Dell Latitude D600 Notebook
When I plug in the power cord to charge the battery, the light on the cord goes off. I tried several charges and they work. Can charged battery on another computer and place on the dead computer and it...
There's no fuse problem with that computer, try this first, Plug in the charger to an outlet don't plug it in the laptop, if the light on the charger turns on, then the charger is working try to plug it on the computer if the light on the charger goes out there's a problem with your motherboard. Contact the tech support for that so you can get that part replaced.
To double check try to use a known good charger if it works then you'll need another charger if not, Then contact your tech support for your dell make sure you still have a warrant.
Hope this helps!
Feb 15, 2010 | Dell Latitude D505 Notebook
DELL LATITUDE D600 WON'T POWER UP AT ALL!
The charger may be bad. You need to measure the output voltage at the computer end of the cord with a voltmeter. Zero volts means bad unit, but may be just the plug end wires are broken near the plug (common problem). A repair shop might be able to fix it with a new plug. A new charger is outrageously expensive.
Jul 19, 2009 | Dell Latitude D600 Notebook
I have a loose charger port on my dell Latitude d505. How can I fix it?
common design flaw, charger port is part of motherboard it breaks mb can be fixed by replacing motherboard i know it sucks
Jul 06, 2009 | Dell Latitude D505 Notebook
Dell d600
It could be your charger, if you have say a dell laptop, get a dell charger for it, it should fix the problem and it will reduce any damage done to your laptop and/or the charger, saves you money in the long run to. and if you want more technical assistance contact http://tinyurl.com/msfzw7
Jun 20, 2009 | Dell Latitude D600 Notebook
I'm using a universal battery charger and my
did you have a look at the sticker under laptop to see what voltage it was then set the charger to this,, if to setting is to low it will do this but if to high it could damage the laptop ,, you will find that it set to low or the other problem is most dells wont run via uni chargers unless the charger states it because dell like to use there own parts made by them unlike other makes
Apr 04, 2009 | Dell Latitude D600 Notebook
Dell battery
Bring it in the Geek Squad they can test your charger there, If the charger is ok send the whole pc to dell so they can check all the componets, charging unit might need to be replaced or you might have a short in the motherboard...
May 28, 2008 | Dell Latitude D505 Notebook
Dell Latitude D600 Notebook Logo
104 people viewed this question
Alun Cox
