Question about Seca 769 Digital Scale 400 Lb with Bmi and Height Rod
I have an error message ER:0:11 on my Seca 770. can you advise what the problem is
What is the error message "Er cH" mean?
I think you mean a dh error code which is a defrost problem either your sensor or heater is bad
May 07, 2014 | Refrigerators
Seca 769 error code e.10.11
showing error code " Seca 769 error code e.10.11" how can i solve this problem.pls help me.
Oct 07, 2013 | Seca 769 Digital Scale 400 Lb with Bmi and...
I have a Seca 703 digital scales, When I turn on it says Er:1:40 Can you help me?
This could be a power issue. Make sure your battery pack wire connections are good. If they are loose, I suggest purchasing the Seca 400 power adapter, which works with this model.
Sep 18, 2011 | Seca 769 Digital Scale 400 Lb with Bmi and...
What does the message "Er
Hi
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. This can be caused by frost accumulation on or around the freezer fan. Unplug the unit for 3-4 hours to allow this to melt off. If error code persists, call Customer Service.
Please get back to us if you have further query or else please accept the solution.
Sep 02, 2011 | U-Line BI-95
Have Seca 958 chairscales. Error on diplay : Er : 1 : 40 Please can you help as this error is not mentioned in the manual.
This is an EEProm error. Recalibrate the scale or write the correct EEProm data by service program
Mar 29, 2011 | Health & Beauty
Error codes flashing
Hi, This is mainly due to control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually..
Apr 13, 2010 | Frigidaire PLD4375RFC Dishwasher
Err 12 and Err 16
Dear FixYA
Was advised to send to Scales to another company to be fixed. Therefore no longer need your assistance.
Thank you
Julia
Jan 22, 2009 | Seca 354 Digital Baby Scale Pediatric...
Seca 769 Digital Scale 400 Lb with Bmi and Height Rod Logo
567 people viewed this question
Top Seca Health & Beauty Experts
pawnpower
Jaye t rock
Tom Chichester
Are you a Seca Health and Beauty Expert? Answer questions, earn points and help others
