Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman Security+ Opener random opening
I have had this opener for a couple years and have had no problems. This morning all of a sudden I heard my door open. I went and checked both my remotes and my wireless keypad. nothing was being disturbed and it suddenly closes while I am standing there. Then it opened again a minute later. I know that these are supposed to be rolling codes and impossible to clone but I went out and checked the street. there was nobody around, no parked cars, etc. Any thoughts? I am very concerned now since I have a lot of expensive tools etc. in my garage.
  • broncojim Jul 09, 2008
    With the "Rolling Codes" on the Security+ I thought it was practicaly impossible for someone to duplicate the signal? Am I mistaken? I will replace the batteries on my remotes and keypad tonight and reprogram them.
    Actually everyone was still in bed. Both remotes were sitting in the cars undisturbed and I was standing 10 feet from the remote kepad when it happened the second time.
    Genius:
  • 2,035 Answers
This could be happening due the faulty sensor or any hardware failure please remove the power supply of the door opener for 30 min and then plug it back and check if it as the same problem:
Posted on Jul 09, 2008
  • 19,396 Answers
The signal may coincide by chance with the code generated by a different device, it is rare but it can happen.
  • 2,326 Answers
Is very unlikely that these devices open by themselves without pressing a manual switch or a remote controller.
I would suggest to check the switch that opens the garage manually and see if that could be the problem, disconnect that switch.
You can also remove the batteries from your remote controllers once the manual switch is disconnected.
If the door still opening, I would suspect that the door opener is getting the commands from another source.
  • Jaime Hernandez Jul 09, 2008
    It might not be someone that is duplicating the signal but it could be a frequency that the antenna picks up and send it to the circuitry instructing the opener to activate.
    Brigadier General:
  • 3,614 Answers
Try to change battery first.../?
  • micromaster
    micromaster Jul 09, 2008
    it so very unusual to heard that story... are you sure there was no duplicate remote of that the one you are using...
    but also please try to change battery, or its better to change codes for better security oon your place..
  • micromaster
    its better to change again the code you are using... it for your own security..
Craftsman garagedor opener
Remove the cover from the motor housing and check the drive gear. It is a white nylon gear and will be obvious if it is bad.
Jul 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
I installed a Craftsman garage door a couple of weeks ago and all of a sudden it keeps opening by it's self. It is model #139.53918D what is causing this?
Make sure the door isn't closing too far. This will cause it to open. Your opener comes with a warranty. Call Sears repair.
Sep 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman ( Liftmaster) door opener that all of a sudden one night opened our door by itself. I closedd the door and in a few minutes it opened again. It continues to do this at random times. I...
Make sure it isn't the wiring to the wall console by removing the connection at terminal #1 on the end of the motor unit. Staples used in installation can cut through the insulation and cause this problem.
Apr 05, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener intermittently not closing
A couple things to check and do. If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit if necessary.
If the main light isn't flashing it may just be a simple adjustment. Locate the 'down force' adjustment on the rear of the motor unit near where all those white wires go. Increase this about 1/4 turn and try.
For the light you should unplug the unit and then using a small screwdriver pull out on the center contact in the light socket.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes quit working on Craftsman 53975 garage
It sounds like you have a logic board problem. If your remotes work at all it is not a programming problem. You could pull the logic board and check for loose connections especially around the small transformer. 18 years for an opener is very lucky. Their average life is about 1/2 that.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
My lift master garage opener opens randomly
change the security code in the opener and the remote.
seems like omeone in your are have the same frequency remote.
Nov 12, 2008 | liftmaster Chamberlain Garage Door Opener...
RE Craftsman Security+ Opener random opening
could be possible... or due to low battery the system goes into malfunction... it is better to observe and check your security system,.
let me know more about this problem...
Jul 09, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
148 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
