Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
My srx75 does not seem to be getting fuel to the carbi it fires up when i pour fuel into carbi and runs until that fuel is finished
  • 784 Answers
Sounds like a fuel pump issue, a blocked fuel filter or poor fuel pick up.
c...
Posted on Jan 03, 2011
Fuel going to carby but dos'nt seem to be going into carby. Will start for a moment as i pour fuel into chambers?
Hi Kristian, Seems like the needle could be stuck inside the seat.... You need to pull your carby off and unscrew the bottom half from the top, 1st sign of a needle stuck inside the seat is a dry carby There you'll find the float, push the float up and down and see if the needle above the float slides up and down from the seat, If the needle stays up then it's stuck and NOT letting the fuel into the carby, Just pull it down with your fingers to loosen it up. I hope this helps.... CHEERS..
Apr 28, 2016 | Hyosung GT 250 Motorcycles
Will not start. has fresh petrol , spark. clean carb . . will not drawfuel into barrell. it fires but not runs if i pour petrol down carb
check that the float and needle and seat section has not been jammed in the fuel seat off position when reassembling the carby
Jul 21, 2015 | Motorcycles
Already change the pump fuel but cannot start
You may have an air lock in the fuel line.
Pour a bit of gas in the carby and start the engine, you may need to do this a few times until the fuel reached the carby.
Mar 01, 2013 | Cars & Trucks
89 mitsubishi carby model has spark and pumps fuel to carby but the spark plugs are dry just keeps cranking but wont even try to fire also has good comp,was driving till water pump blew now just wont fire...
Check that the fuel pump is working and pumping fuel (fuse or burnt out) as it sounds like there is no fuel in the carby. To check if the engine is going to run remove the air filter from the top of the carby and pour about a table spoon of fuel directly into the carby throat. Replace the air filter and crank the engine. If is going to run it will fire and then stop
Feb 20, 2013 | Cars & Trucks
2002 kia sportage fuel pump needed replacing so we did and now car won't go
There maybe an air lock in the fuel line.
Try pouring a little fuel down the carby and then start the engine, you may need to do this a few times until the air lock is cleared.
Feb 07, 2013 | 2002 Kia Sportage
1982 gmc pickup I replaced the mechanical fuel pump and still am not getting fuel up to the carb and it will not start
You most likely have an air lock in the fuel line or fuel pump.
To start the engine and hopefully get the fuel to the carby, pour a little fuel down the carby and then start the engine. You may need to do this several times until you get the engine running.
Apr 08, 2012 | 1983 GMC C1500
I have a 93 Eagle Vision we ran out of gas now the car will turn over but is getting no fire
There may be an air lock in the fuel line or fuel pump.
Pour some fuel in the carby and start the engine. You may need to do this a few times to get the air lock out of your fuel line/pump.
Jan 22, 2012 | 1993 Eagle Vision
I just rebuilt my 3.3 engine and put it back together. It seems to turn over fine but it wont **** any gas it to the carb so it wont fire. Did I do something wrong?
There may be an air lock in the fuel line or fuel pume.
Jan 22, 2012 | Traxxas T Maxx 3.3 Monster Truck
Why does my motorcycle stall when i slow down and dies when im riding normal speed after like 15 sec into the ride and it doesnt seem like its getting all of its power when u gag on throttle
Your fuel petcock (on/off tap) may be restricting fuel flow and the carbies may need to be cleaned.
To maximise fuel flow thru a dirty fuel filter or restricted fuel flow thru a contaminated carby jet, disconnect fuel hose from tank and drain remaining fuel in carbies into a glass and inspect for contaminates. Take off float bowls and spray ($8 retail 400g aerosol spraycan carby cleaner) cleaner down fuel line/hose until it pours out of carbies. Allow to evaporate. Replace fuel filter (there may be a cylinder of white mesh gause inside of fuel hose) and check bottom of tank for rust, scale or debris. Try fresh fuel, new sparkplugs (0.8mm gap) and ensure choke is functioning correctly. Check camchain tensioner is not loose. Keep battery fully charged, replace if the bike can't achieve this when running with no lights..
http://www.cmsnl.com/honda-cx500-79-us_model7377/partslist/ This link will give you diagrams to help you out.
Cheers.
May 08, 2010 | 1979 Honda CX 500 A
Continualy turning over and wont fire up, Im getting a spark off all 4 plugs carbs appear to be clean just wont fre up
squirt a bit of aerostart in the air cleaner, if that makes it run its a carby fuel problem, if that doesnt make it fire, do compression test, check valve clearance , valve timing
Apr 06, 2010 | 1981 Suzuki GS 750 L
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
252 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
