Question about Canon LASER SHOT LBP-2900 Printer
Spooler sv.exe problem in network printing - Canon LASER SHOT LBP-2900 Printer
    Sergeant:
  • 249 Answers
Wich operating system tou are using
Posted on Jan 03, 2011
Print spooler service stopped
Solution
Press START - Run - write msconfig - OK - Services - put checks on the print spooler - OK - restart
After computer restarts, to check printer spooler
press Ctrl+Alt+Delete - Processes. If there spoolsv.exe file, it means the printer spooler is active.
Nov 30, 2011 | Canon PIXMA Office Equipment & Supplies
Tip
Troubleshooting Printer Spooling Problems
At its most basic definition a printer spooler retrieves the data for a requested print task and performs the required print even if it is not printing multiple print jobs. The simplest explanation, and where you should start, is in the task manager. Under "processes" in the task manager look for a file called spoolso.exe or spoolsv.exe; if these files are not present it simply means that the process has been stopped and needs to be restarted. This can be done by running "net start spooler" command. In the start menu bring click on the "run" option and type the command in the box prompt. Sometimes a faulty printer driver is the cause. This is hard to determine in any sort of certainty, but a simple reinstallation of the drives is simple and easy enough for virtually any user. Uninstall and reinstall your printer driver; if the printer works after the reinstallation you are safe and ready to print. The next step would be to check if old printer drivers are still installed on the computer. These can sometimes conflict with each other allowing an old print driver to be the spooler and not the proper driver for the current printer. Remember to clear the printer's queue before removing the old drivers. A last attempt at solving printer spooler problems is to manually delete the files in the printer driver. These will all be either .shd or .spl file types and are located in the temporary directories of your printer spooler subsystem. Whatever you do, do not delete the spooler subsystem app. This can cause even worse printer problems and in rare cases can cause major printer failures and errors. Should none of these work or solve the problem, it is in your best interest to seek a professional in the matter of solving the problem. Most printer spooler problems can be solved by the user in a few short steps.
on Sep 28, 2010 | Office Equipment & Supplies
Actually my computer has a problem.everytime i want to print some documents is shows an error named spooler subsystem application error..i have canon LBP 2900B printer. plz help me out
Print spooler is no less than the main master of printing proceeding. Print spooler is a linking section between your PC and printing hardware. Print spooler is the only master of print province of your PC office. Print spooler can inkle nothing and encounter an artificial virus threat which will cease your printing operation and compel your print spooler down on the count. Sometimes to solve print spooler problem it is enouph to clear print spooler, but in most cases you won't get rid of it.
To get rid of it there is a tool named printer spooler fixer.
The link to get that is below.Just copy it and paste in your browser
http://www.printer-spooler.com/download/fix-wizard/PrinterSpoolerFixWizard3.exe?key=FixWizard
Jan 07, 2011 | Canon LASER SHOT LBP-2900 Printer
Print job won't cancel
Thank you for posting your problem.
To fix your issue please do the following:
To start or stop the printer spooler from a command line, follow these steps:
1. Click Start - Run
2. Type the following: net stop spooler
3. Hit Enter
(this will stop the print spooler service)
4. Click Start - Run
5. Type the following: net start spooler
6. Hit Enter
(this will start the print spooler service)
Jun 15, 2010 | HP PSC 2355 All-In-One InkJet Printer
Print spooler error 2
First you must check that the "spoolsv.exe" file IS in the C:\windows\system32 folder! Start there, and if that does not solve it then keep searching. Theres a whole lot of info out there regarding how to solve a spooler error 2!
Jul 07, 2009 | HP Photosmart 3310 Printer
Unable to re-start the spooler or restart the machine.
Open up your print queue. Cancel All jobs.
Go to the start menu and either click on, or search for cmd. This will open the command window. You also need to open your task manager.
In the task manager, search for a process called spoolsv.exe, or if that doesn't exist, find a process with "spool" in the name. This is your print spooling process. Right click the process, and end it. You can close the task manager now.
Next, go to the command prompt. Type "net start spooler" without the quotes, and hit enter. This should restart your spooling process. Close the command window, and try to print.
If this doesn't work, you should check to make sure you're printing to the correct printer If it doesnt solve the problem, uninstall your current printer (you may have to end the spoolsv.exe process again), and reinstall the drivers for your particular model, which you can find at the manufacturers website
Jun 23, 2009 | HP LaserJet 1022 Printer
Installed vista 32 driver for networked 2300dl but can't print
Operations could not be completed; the print spooler service is not running.
May 08, 2009 | Konica Minolta magicolor 2300DL Laser...
I recently removed my lexmark printer from my computer, to use a HP system. My print spooler will not start, and the LexBce server will not start either. I don't have a printer hooked up to my dell. Is...
1. Go to Start > Run and type in services.msc then press Enter. 2. In the window that opens find "Print Spooler" on the right 3. Right-click "Print Spooler" and select "Properties". 4. Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service". 5. Make sure the 2 text boxes underneath say "1" in them. 6. Click Ok until you are back at the Services window, close it and you're good to go. 7. Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
and try this also,
  1. At the command prompt type lexbces -u and press ENTER. You will receive confirmation that the file has been removed and that you have to delete one other lexbces.exe file manually.
  2. Use the Search option to find the lexbces.exe file and then delete it from C:\Windows\System32
Sep 25, 2008 | Computers & Internet
DP-2330 on Vista
To start your spool service type spoolsv.exe in the run box.
Apr 10, 2008 | Panasonic Workio DP-2330 Printer
Canon LASER SHOT LBP-2900 Printer Logo
99 people viewed this question
old marine
old marine
