Question about Cycling
The crank on mongoose tamdem bicycle fell out of frame this weekend leaving us stranded. According to manual this problem is normal? And a special tool is required to repair? Where is this tool to be found, and why was it not included with this product?
    Genius:
  • 1,788 Answers
No, it is not normal. I would say you were riding with it loose and then just finally stripped. Now you have to take in for service and hope that the frame is not shot. Who set up the bike? Take it to them. It is kind of like not checking your car brakes and tire pressure before you take a trip.
Posted on Jan 03, 2011
Need an assemble manual and or guide for mongoose mischief 2004 Serial num HBING
http://knowyourbike.com/mongoose/mischief/2004
http://www.bikepedia.com/QuickBike/BikeSpecs.aspx?year=2004&brand=Mongoose&model=Mischief
And finally the manual
http://www.mongoose.com/usa/manuals-instructions/
Jan 17, 2016 | Mongoose Cycling
How do i fix crank bearings on a mongoose rebel freestyle?
Usually takes special tools. The pedals should be removed, the crankset is either a single arm or a 3 piece unit. If its a single, remove large nut on one side of the crank, usually the left side. Then remove the inside cone, the bearings are visible and should be removed. The last is the crankarm itself. It will only come out if thew left side bear is removed. Twist it gently and it usually comes out at the 3 o'clock position.
If its a 3 piece crankset, special tools are need to remove. SAuggest you take it to the nearest bike shop.
Oct 07, 2014 | Mongoose Rebel Bicycles
What is the crank bearing size??
Almost all Mongoose models use the standard BSA 68.
I would write a question to them at:
http://mongoosebikes.net/mongoose-bmx-bike/20-mongoose-mode-270-v2-freestyle-bmx-bike/
This bearing should not fail during the normal life of the bicycle, unless the rider weight is over 80 Kg.
Jun 10, 2014 | Mongoose 20" Mode 270 Boys Freestyle Bike
Mongoose Canaan - Crack in frame
If I were you,and the frame is cracked...I would not ride that bicycle!
Jul 13, 2013 | Mongoose Canaan Team
Mongoose xr-75 pedal & crank fell off of bike
I actually found a bike today with an enclosed crank case. Your fix would be simple if it is the same. What you need is to replace the set screw that came out the crank and pedal. When you look at the crank that fell off down where it attaches you should notice a hole without a set screw in it. Find one to fit in that and then put it back on the bike. If you have not figured this out or need more clarification just let me know.
Aug 31, 2012 | Mongoose Cycling
I have a mongoose d series mt bike i stripped the crank on the sprocket side....where can i find one
Any Bike Shop or just assess the make/model size (probably printed or embossed on the crankarm and search the web for a set. No one sells just one crank.
You'll probably need special tools to remove it.
http://www.parktool.com/blog/repair-help/categories/crank-service
Aug 26, 2011 | Mongoose Sector 26 Men's Full Suspension...
I have 26" Mongoose Snarl,both
A simple web search for 'remove bicycle crank' turns up numerous videos.
http://www.parktool.com/blog/repair-help has the many special tools and advice one needs to work on a bike.
Aug 21, 2011 | Mongoose Sector 26 Men's Full Suspension...
I am trying to find out what size the Mongoose sx43 is. It is from 2000 and is bright yellow.
It could be one of several sizes. To determine the size you can measure the bike from the center of the bottom bracket (where the cranks install into the frame) up the seat tube to the top of the frame. This will give you the size of your bicycle.
Nov 10, 2010 | Mongoose Exile 26 Men's Full-Suspension...
Cycling Logo
21 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
