Question about Buffalo Technology Buffalo DriveStation JustStore 1 TB USB 2.0 External HD-CL1.0TU2N (Black) Hard Drive
I can't get into my external drive, I have a feeling maybe it has a virus on it as well as my important documents I need on there. On my laptop it says I have to format it and on my desktop comp it doesn't say anything, only when I check in my drivers setting it says that, this device will not start (code 10), what does that mean??? I've tried all of troubleshooting and nothing worked, I don't know what to do, I called Buffalo technical support and no one wants to anwser, I only get a answer machine repeating herself over and over, please help me???
Dipu007
  • 2110 Answers
SOURCE: File transfer rate is EXTREMELY slow
plz try to format the drive before transfer....
Posted on Feb 04, 2009
  • 23 Answers
SOURCE: i tranffered all my data from my pc on to 1tb
I had also stucked in this issue and recovered using http://www.recovermyfiles.com/
It will take lot of time, any how you will get the data back
Posted on Mar 12, 2009
Crankstart
  • 696 Answers
SOURCE: My DEll PC runnig XP SP3 cannot
Yes the drive is compatible with XP. I have seen a slightly higher than normal # of problems with their 1TB models so this may just be a batch problem. My suggestion if there's nothing crucial on the drive is to return it an purchase a different brand.
If it's not returnable you'll have to settle for asking Buffalo for a replacement. If there's crucial data on it you will need the help of a recovery pro. In that case, comment back with your Country, State and City and I will point you to a nearby Recovery facility.
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
ihwsolutions
  • 137 Answers
SOURCE: 1 TB is beeping
After doing some research it seems the beeping means that there is a disk failure.
Prop off the front of the unit, remove the drive and replace it. The unit will automatically rebuild the drive, which takes about 8 hours
Posted on Sep 27, 2009
  • 10406 Answers
SOURCE: Everything worked fine until yesterday
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
Testimonial: "THanks - I'll give it a go!"
How can I find the files on my 1tb, seagate external drive?
You maybe removed the driver for the hard drive when you ran the anti virus. Those programs can do some strange things. If you click on the start, then computer. It will show all hard drives on your system. If you cannot find your files. I would think your computer does not see the external hard drive. To reinstall the driver, you would need to go to the driver's manufactures web site to down load or yours may have came with a disk. If so just run the disk. Could do a system restore , but that would be last option .
Aug 02, 2014 | Seagate FreeAgent Pro 1TB External USB...
Toshiba backup software
im assuming you want to back up your laptop
Determine how much space you'll need to back up your Toshiba laptop's hard drive.
If you are intending to back up your entire hard drive, or have a lot of video and music files you want to save, you'll likely need an external hard drive.
On the other hand, if you only want to back up your most important documents, a USB drive should suffice.
Separate your video, music, pictures, games and documents into separate folders.
Right-click each folder and then click "Properties." Do this for your C: drive, too.
Locate the "Size" or "Capacity" section on the "General" tab.
The number to the right indicates how large the folder is, with all the files included.
This information should give you an idea of what kind of secondary storage system you'll require. If you're looking at over 100GB of storage space needed, you'll probably want an external hard drive.
Purchase an appropriate drive that includes backup utilities.
Some external drives and USB drives come with backup software.
Once you install and configure the software, all you have to do is press a button--either on the drive itself or on your computer's desktop or taskbar--to start the backup process.
Schedule your drive's utility software to back up your Toshiba laptop files once a month.
Your USB or external drive should be plugged into the laptop on the scheduled backup dates.
Store your most important files on an online storage facility, such as Mozy, DropBox or Toshiba Online Backup.
In case anything causes damage to both your laptop hard drive and your spare drive, you will still be able to access the files online.
http://download.cnet.com/macrium-reflect-free/3000-2242_4-10845728.html
Backing up your computer shouldn't be a tedious task. Macrium Reflect Free Edition makes file backup incredibly easy thanks to its intuitive user interface and helpful wizards.
bonus its free
hope this helps
Oct 03, 2012 | Toshiba Computers & Internet
bonus its free
hope this helps
Oct 03, 2012 | Toshiba PH3100U1EXB 10TB Desktop External ...
Cursor jumps whilst typing
Hello, If your cursor jumps while typing, i would want to know if this has been happening before if not then it means that your laptop has been infected with virus or malicious programs, i suggest you get a good anti-virus and scan your laptop thoroughly to remove the virus.. You can also try using an external mouse and see if the cursor jumps while typing. If none of this works try backing up all your documents to an external hard drive and format your hard drive or re-install your operating system. Regards
Nov 26, 2010 | Lenovo G555 Laptop
If i reset my dell inspiron b120 to factory settings will it get rid of all the viruses
Maybe. All the OS viruses will be gone, but if you have MBR viruses, you won't get rid of those. Try Microsoft Security Essentials, it's free. Download it and scan your computer.
Oct 28, 2010 | Dell Inspiron B120 Notebook
Iomega 250 GB IDE Hard Drive Problems & Solutions I have an external hard drive Iomega 250 GB IDE. It works perfectly well and suddenly I have tried to connect it to both of my computers but...
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
Aug 28, 2010 | Iomega (33652) 250 GB IDE Hard Drive
Friends laptop will no longer connect to internet. She also did not have any anti-virus software on her laptop, but does now. Like I said, she cannot connect to the internet, yet computer shows the...
You can right click on the "my computer" icon, click properties and click on the hardware tab. Then look for device manager. Look under modems to see if the internal modem is still displayed.
Sounds to me like she got a virus. Many will stop the user from connecting to the internet to download antivirus software. Have you run a scan on the computer since you installed the new anti-viurs? If not, see if you can do so. If you cannot run a scan. she more than likely has a virus and may need to clear the hard drive and use her re-image disks. After backing up her important files and documents to an external drive (flash driver, etc.)
I hope that these suggestions helped and will get your started on getting this laptop connected again.
Brian
Jan 24, 2010 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Inspiron 1520 laptop shuts down while working.....now its not starting at all....please help.
check with ur BIOS, n POWER ON/OFF switch might be damaged.
or there must be damaged to ur operationg system, maybe damaged to the system's DLL files must be damaged r missing, it will done by a virus, or any illegal [programs.
try using a better anti-virus software.
n for ur problem, during next reboot, plz insert the valid OS cd/dvd into the drive, n
in the BIOS select BOOT from the CD.
then follow the instructions n then go to fixing of th OS.
hope u'll be definity fixed with it.
else try reinstalling the operationg system, b4 that create a valid backup of all the important documents in the system, in a separate external memory device, like pendrivve or a external harddisk,..thank u!!
Jul 17, 2009 | Dell Inspiron 1520 Motherboard
I need to crash my acer 5100 laptop so i can reboot it to the factory state
no need to crash it, j
ust save your important documents on an external drive (or a USB flash), restart the computer, when it is booting click and hold ALT+F10
this will initiate a restore procedure to original factory state, remember all documents and files will be lost, so back them up externally before you do this
Nov 04, 2008 | Computers & Internet
System will not detect my Seagate ST3500641CB-RK 500gb external hard disk
if your system some virus hope it is not read......better you try any other some card reader or pen driver if it read you try other OS ....
Jun 07, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
Buffalo Technology Buffalo DriveStation JustStore 1 TB USB 2.0 External HD-CL1.0TU2N (Black) Hard Drive Logo
111 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
