Question about AEG Lavamat 16810 Front Load Washer/Dryer
Getting E94 when trying to start my washing machine an AEG Lavamat 16820. Does anyone know what E94 means and is it fixable?
SOURCE: AEG Lavamat 6955
Replace door seal
Posted on Jul 26, 2007
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
read this site: http://www.askanowner.nl/qa/view.asp?s=2&qid=152459&arrqueryparts=&arrquery=code%3Bce kind regards, w vd vegt
Posted on Aug 28, 2007
mediarich
  • 188 Answers
SOURCE: Lavamat 16820
The reason the machine is coming up with E20 when drying.
is that there is a blockage of fluff in the dryer air duct on the right hand side of the machine just below the fan unit.
the air that goes through this duct is heated and returns back to the tub to dry the clothes. because there is a blockage in this duct the fan pushes air up the pressure switch tubes and fools the machine in to thinking that there is too much water in the drum,
too remove this blockage you have to disconnect the power supply, remove the lid and remove the back panel, 4 screws at the bottom + 4 up top under the lid. plull the water pipe with the valve out of the way and pull back panel away.
you should now see the dryer condensor unit blocked up with fluff. remove this unit and clean with bottle brush.
replace and make sure hoses are done up tight. replace back panel and lid, try again on drying and things should be alot better, drying should be alot quicker as well.
Posted on Oct 03, 2008
SOURCE: I have an AEG Lavamat 16820 washer dryer and the
The lock is rubbish on this machine but as a temporary measure you can feed a string down behind the door lock from the top and out the bottom. Then yank it to the left to open the lock. It will take a few tries but you get the hang of it!
We got sick of this so ordered a new lock off the net. I basically had to break the old mechanism to fit the new one because the door layers were so strongly glued together. Now fitted, the lock works perfectly but the machine thinks the door's open the whole time! Next step is either new door or new machine. Great.
Posted on May 12, 2009
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
The washing process stops after about 12 minutes at any program and the green door light is on but water in the drum.
it looks like your heating element are dead. But Im not sure.
Does drum is spinning?Does it pumps water then you set in on "drain" program?
Apr 03, 2013 | AEG Washing Machines
AEG Lavamat 16820 turbo Washer/dryer won't start - makes noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgmj
Apr 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
I have an AEG Lavamat 16820 washer dryer and the door wont open any ideas
May 04, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
PC board of Lavamat 42260 Top Loader washing machine. (Automatic) Washing Machine stopped on cycle and displayed E94 on panel.
Found that the water heater is giving low insulation resistance. It is being replaced by a new one.
Apr 14, 2009 | AEG Washing Machines
Lavamat 42260 - E94
This is a configuration error. There is a way to reconfigure it, if you have the technical information, but most likely you will need to replace the PC board.
Nov 28, 2017 | AEG Lavamat 72640 Front Load Washer
AEG 16820 Lavamat-turbo
Hi
this sounds like the fill vavle is fauty you can check this if you have a muiltmeter.
remove lid and unplug the green soliaod and check to see if open circuit.
if so replace and should be ok.
regards
Mar 08, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
54 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
