Hi, accidentially the 'magnetic strip' related to the sensor (door/lid open) has been damaged. Am getting the error message 'dE'.How do i rectify this please? Is there a do it yourself solution for this? LG Washing Machine, Top loading, model WF-T7512HN
  • pamkrin Jan 05, 2011
    Problem solved. Found a small magnet fixed to the top lid which had come unstuck and dropped itown tinto the spin drum. Re-stuck the magnet (which is detected by the sensor in the closed lid/door position) and the dE error dissappered. Now the m/c runs fine. Thank you.
  • Rupesh koulge Sep 15, 2013
    Thanks a lot. this solved my dE problem today...
4 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: LG WF-T700 Troubleeshooting DE blinking
The "DE" code indicates a door open error. This can be caused by the door not closing all the way (this could be because of bent door/hinges or the door gasket bunching up and not permitting the door to close properly), loose electrical connections at the door switch or powerboard assembly, or the door switch itself is faulty. It can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity would mean a bad switch. Also check the door gasket for "bunching" and you can unplug and reseat electrical connections. These are some areas to look at. Be sure to disconnect unit from power before attempting any repair/troubleshooting. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 28, 2009
SOURCE: I have a WF-T556 top loader with a de error.
There sure should be....why, because mine stopped working as well. Found magnet inside machine after getting rid of water on spin cycle (thankfully it still allows the water drain to occur). Put magnet back on and hey presto, all good.....if only I had taped it on as 5-6 washes later and it has fallen off and I can't find it - hopefully a standard magnet will be enough to fix from shops - I am sure LG or proper repair place sells them for a fortune :(
Posted on Aug 07, 2010
SOURCE: What is sensor magnet in LG 6.5 kg washing
The machine has a small magnet on the front of the lid. There is a sensor (Hall Effect probably) in the electronics block that senses if the magnet is there (lid closed) or not there (lid open). They aren't that well attached and seem to fall off and wind up in the wash, which means they get lost when the washing is being hung out.
The machine will not start without the lid closed you get a dE error code which means the lid is not shut. You can trick it temporarily by putting a small round magnet inside the front housing if you don't have a proper replacement, as the real one needs to be quite strong. Not sure what they cost, my husband just did the 'trick' to our daughters machine, but a small button magnet wasn't strong enough to trip the sensor from the lid position, he had to stick it right next to the sensor.
Shouldn't be that dear, you can buy blocks of very powerful neodymium magnets in varying sizes for under ten dollars.
Posted on Nov 05, 2010
Error message dE
hello there and thank you for choosing fixya
dE - Lid door open error Lid /door isnt fully closing or is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board
Jul 28, 2011 | GE Energy Star WCVH6260F Front Load Washer
Lg Fuzzy Logic 5.5kg Turbo Drum with I-sensor, Model WF-T552TH Washing machine goes through initial fill up, when changing to spin/wash works for 2 seconds, then stops spinning back and forth and shows dE...
There is a small magnet at the front of the lid that triggers the door error, mine was corroded and the lg people wanted $80 for a service fee.. Ha I went to my local hobby shop and got a small earth magnet and some super glue $1.50 later and she's fixed.. tadAaa.
May 11, 2011 | Washing Machines
Samsung Top Loader is giving a dE error when the tub should start spinning, it runs the Fuzzy selection and will fill, but the wash cycle doesn't start and the error comes up. This happens even if the tub...
Hi, dE MEANS DOOR ERROR,There is a little magnet that detects if the lid is open or closed & this magnet always falls off into the machine then pumped away. (If it gets past the pump with out jamming it).you can't just buy the magnet you have to buy a whole new top & most of the time this cause's the computer to fail as well
Apr 08, 2011 | Samsung Washing Machines
My machine lg top loader wf-t7050tp gives me a dE error what does that mean
this means door error there is a magnet in the lid that falls of and this is how the computer knows the lid is shut lg dont sell the magnet you have to replace the whole lid sorry.
Jan 11, 2011 | Washing Machines
What is sensor magnet in LG 6.5 kg washing machine? Recently I got a dE error and when technicians attended, they said, there was problem to closing door lid. To resolve this, technician replaced sensor...
Sep 09, 2010 | LG WFT1071TP Top Load Washer
There really is a sensor magnet that is necessary for door lock mechanism to work. Not sure about service call charge, but if it works the he did fix it anyway
May 19, 2017 | LG WFT1071TP Top Load Washer
This washer has an error code of DDO, Dispenser door open, would you think a sensor issue or something more?
The meaning for ddo error means"Dispenser Drawer Open" .To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it.
Thank you !!
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
Lid open error in WF-T6517TE
it could be that the magnet in the door lid has slipped or fallen out. I stuck a new magnet on the rim of the machine and the dE eror message went away
Dec 13, 2009 | LG Washing Machines
LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Sep 11, 2009 | LG Washing Machines
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check lid switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
