Question about Kenmore 64802 Top Freezer Refrigerator
Refrigerator door won't shut - Kenmore 64802 Top Freezer Refrigerator
  • 425 Answers
Probably there is something inside that is not place correctly or a door that is not close properly.
it happens to me many times already...
try looking for it...
Don't forget to rate me...
thanks...
Posted on Jan 03, 2011
Freezer light won 't come on
did you try replacing the bulb? check to make sure the door switch isn't frozen shut or something.
Aug 11, 2013 | Sub-Zero 736TCI Refrigerator With Ice Box
Fridge door won't stay closed
What is the model number of your unit?
Nov 03, 2012 | Refrigerators
The evaporator fan is always running at a constent speed . Is this OK
Chances are you won't notice when it shuts off, but it does. The only reason I can say this without seeing the machine is because if it ran all the time, it would run during the defrost cycle as well and if that were the case your complaint would be about how hot the inside of the machine was and how the food was all ruined.
May 30, 2012 | GE GBSC0HCXWW (203 cu ft) Bottom Freezer...
Ice dispenser in door won't shut off
photo sensor dirty, clean area around dispenser
Nov 13, 2011 | Whirlpool GD2SHGX Refrigerator
The touch screen is frozen and won't respond to anything. Is there a reset?
Try this, unplug it for about 10-15 second. All these modern appliances use microprocessors for control. Unplug is doing hard shut down on your computer. stewbison
Aug 20, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
I noticed our top freezer door was left open approx 8-9 hours overnight. Now it seems it won't shut off? Is the motor burned out?
It will probally have to go thru a defrost cycle before everything goes back to normal. keep the doors shut and wait 24 hours and check it. hope this helps.
Aug 08, 2011 | Gladiator Freezerator Top Freezer...
2 yr old refrigerator part won't get cold
check the damper vent door between the freezer and refrigerator compartments to see if its frozen or stuck shut so cold air cant pass
Aug 02, 2011 | Kenmore Side by Side Refrigerator
HAVE A KENMORE REFRIGERATOR - MODEL # 253.60734407 - HAVING PROBLEM WITH THE MAIN DOOR STAYING CLOSED. IF I PLACE 2 LITES OF SODA ON THE DOOR. THE DOOR WON'T STAY SHUT. HAVE THERE BEEN ANY OTHER...
The main thing that makes a fridge door shut is that it falls shut because it is set at a slight angle with the front of the machine higher than the back. You may find the solution is as simple as making the fridge tip back a tiny bit more by turning the front feet clockwise to screw them out of the chassis and make them longer, causing the fridge to tip back a little and the door to fall shut as it should.
Jul 07, 2011 | Kenmore Refrigerators
Freezer door won''t open, was frozen shut, used a hair dryer and then could open but now it doesn't open all the way and seems to stuck on left side.
take defrost the freezer it sounds like ice has builded up behind the door and it sounds like u may need a new door gasket or it didn't get closed all the way.
here is something u can try to see if the gasket seals take a dollar bill put in the door frame shut the door if the dollar bill comes out easy the gasket is not sealing
Apr 02, 2011 | GE Profile Stainless Bottom-Freezer...
Refrigerator side not sealing tightly when shut.
Sounds like you may need a new magnetic seal. It is worth the money to fix it, saving electric and your food items.
Good Luck
Aug 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 64802 Top Freezer Refrigerator Logo
35 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
