Question about Cameras
I have an old Sunpak 3075G Thyrisistor circuitry Flash that I used to use over 15 years ago, I recently got interested in Digital SLR photography and went to try it out the other day but I have a problem The flash refuses to fully charge up. Even with new batteries , it just continues to emit a high pitch hum usually associated with it recharging, but the ready light will not come on at all. When I try to push the mainual flash button I get no operation so I presume its not charging itself. I have a new Canon EOS 550D Digital camera and I was wanting to use this until I can afford a new Canon speedlight. Could the Capacitor be faulty. The flash not been used for at least 15 years now. I live in Sydney Austrlia , so I don't know if parts are still available.
  • Cameras Master
  • 5,412 Answers
May I add a warning here - using an old film flash unit with digital cameras is not recommended, as the trigger voltage is way too high (over 350 volts as mentioned), whereas the digital usually requires 6-10 volts. Using the old flash could totally fry your camera.
Posted on Mar 20, 2017
Bogdan
  • 198 Answers
SOURCE: Flash Will Not Operate
Flash doesn't operate from various reasons. Try to reset your camera if you find in the instructions manual a procedure like that. If it doesn't work here are some possible reasons. The flash works because a power inverter will charge a capacitor at about 350 volts. These are required to make a small lightning inside the flash tube. If the capacitor is damaged it will not charge, and the flash woun't work. If the invertor is damaged, it woun't charge the capacitor, and without those 350 volts the lightning inside the flash tube woun't go on. If the components that links the the camera's internal processor to the inverter circuitry doesn't work because of some failure to those components, again the inverter woun't work. Any shortcircuit or open circuit or imperfect contact can result in this. Even if the camera's firmware was corrupted in some way it could fail to instruct the camera to charge the flash circuitry. As you can see there are many reasons for that but only a service center can make the correct diagnostic. It isn't adviceable to dissasemble de camera yourself and tamper with the invertor circuitry as you are exposing yourself to those 350V. You may get some nasty electric shocks or damage other components. Therefore, I think the best aproach to this problem is to have it diagnosticated and fixed by a specialised service facility.
Posted on Mar 14, 2007
SOURCE: Battery will not charge
Yep. Same hear. Casio will replace with reciept - call 1300 728 606. Pitty I've lost mine!
Posted on Jan 02, 2008
camerawes
  • 36 Answers
SOURCE: problem with slr camera flash obstruction
The problem is in the flash pop up switch. It is probably jammed in or there is some kind of substance on it causing it to stick. You can find it by manually popping up your flash. You should then see a little black spring loaded post on the release button side of the flash. Check to see that it is not stuck in in any way. If so that is why you are getting error 5. To repair you can try a qtip an a little rubbing alcohol. Otherwise you will need a technician to do it.
Posted on Jun 10, 2008
  • 115 Answers
SOURCE: My Nikon D40 won't take pictures fast.
There is a buffer in your camera that processes your images for storage on your memory card. The larger the file size, the more the buffer is being used per image. That will slow down your image transfer.
Also, memory cards are not just about the size of the memory card. It's very about about transfer rate. Once the buffer is ready to send the image to the card, the card has to be able to accept the MB quickly. If your card has a transfer rate of less than 255, it's going to be slow, especially with larger images.
Posted on Sep 28, 2009
  • 43 Answers
SOURCE: MY DIGITAL CAMERA KEEPS SAYING
Remove the battery and push the reset switch for about 5 seconds. Reinsert the battery.
Posted on Jan 29, 2010
Will my sunpak PZ4000 flash trigger voltage harm my nikon D50 circuitry?
The Sunpak PZ 4000 and 5000 were made for film cameras. I have one for my EOS film cameras. It works just fine. I know this series of flashes was not made for the digital cameras. It likely will not harm your camera if the flash is designed for your camera brand. But some functions will not work.
For example, do not use a flash for Minolta on a Nikon.
You risk damaging your cameras electronics or frying the flash.
Get their PZ 20, PZ 30, PZ40 or PZ 42X for your digital camera.
Oct 02, 2009 | Sunpak PZ 4000AF for Nikon TTL Flash
Use of lens MP-E 65 with canon 450 D.
Upon searching the lens is compatible with your camera...
Sep 22, 2009 | Canon Digital SLR Camera Kit - EOS 450D +...
Need manual for Sunpak 4000AF Power Zoom Flash
Regarding using the Sunpak 4000AF flash with my Canon EOS Digital Rebel, I can't get the flash to fire. There seems to be no combinations of settings that works to make the flash work. Could a weak battery in the Canon cause this? Does it require some other wire connector between the flash and the camera?
I know this is old technology now, I have a pocket digital for most of my uses, but I'd like to try bounce flash again on my old Rebel digital, and so I've gotten out my old camera and the flash I had bought for it. I had bought the Sunpak flash years ago and I honestly don't remember if I got it to work back then or not.
Thanks for any advice.
Jun 25, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Sunpak PZ 4000AF for Canon EOS 35mm SLR body
Canon digital uses E-TTL metering for best flash results, the older Sunpak unit isn't compatible with this, so it is not fully compatible. It may work in manual mode - but won't be as good as a more modern compatible digital flash like the Canon or Metz (eg 58AF1 Canon) versions.
May 11, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Flash
becRN,
take the camera to a good camera store and try any in your price range, the manual should state the camera's that are compatible. note that many new model flashes do not work on older camera's.
May 28, 2008 | Minolta X-370S 35mm SLR Camera
Minolta 7000 SLR
The Konica-Minolta 5d, and 7d, both discontinued but available used on ebay and other places will work with your AF lenses, as well as all the sony alpha camera bodies. KM sold their camera business to sony, and most of the whole maxuum/alpha/dynax group of engineers went with the sale to Sony. I had a 7000, and an 8000i, and all my lenses are quite happy on the 7D I picked up a few months ago on ebay.
Mar 27, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Cameras Logo
189 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
