Question about HP DTPS-150AB (09502783) Power Supply
My PS is trouble. type and mark ALL component IC for DTPS-150 ??
    Novelist:
  • 206 Answers
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic - Your PSU might cost you a bit more.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Posted on May 13, 2014
Type of ic used in Behringer
Behringer uses many types of IC's in their speakers and subwoofers. The IC's are normally marked. Is it an 8 pin? Then could be an opamp. Include the model and which PCB it is on if more than one and what marking is next to the IC?
Apr 07, 2014 | Behringer Audio Players & Recorders
My nokia 5610 phone is short due to heavy power battery pls give solution
I found this URL for you but be careful, I did not dig into it and it may have malicious code. I kind of doubt it but I am ALWAYS careful. http://schematichp.blogspot.com/2009/06/how-to-repair-nokia-5610-keypad-fail.html
May 22, 2012 | Nokia 5610 XpressMusic 1/2 Hawaian Flower....
Nokia 3110 fall in to watter and dead
1..remove this coil mark in (1)...if u want to check is pf is short,..... 2..remove this coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery.... 3..remove this coil mark in (3)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery.... 4..remove this coil mark in (4)..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery.... 5..remove this coil mark in (5)..if u want to check the light ic is short.... 6..also check the memory card driver ic n3200 it also got +b it can be check by only removing this ic..... 7..at end remove retu and tahvo ic .. all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .3500short.jpg
Dec 06, 2011 | Nokia 3110 Cellular Phone
Half inch norizontal line come on Sumsung SyncMaster 591s.Wher is fault. Please help me.
Hi
Its vertcial output section has the trouble. It is composed of and IC and surrounder components. If the electrolytic capacitors, or IC itself can cause this. Just open the monitor, and access the vertical output section. Look for any buldged or leaky capacitors on that side. Just resolder all the solder terminals of vertial output IC; by applying a little more solder, without making any solder bridge in between adjecent terminals. Loose solerings in circuit may also make this type of fault. If it doesn' help you, just repalce all of the electrolytic capacitors on that side first. There will be 6 or 7 of them. Replace it all at the same time. it won't cost more. If the fault still perists IC is damaged, and should be replaced with same type and number. OK.
Jul 15, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Although tv is showing picture the colours only showing background etc are green and blue
Hello
Your TVs red colour output section has the trouble. There is no red output at the red cathode of the picture tube. The red, green, and blue output sections are on the picture tube base board. In some Philips model, these will be consists of transistors, and some has an IC or Tree ICs for three colour output used. You just open your TV, measure the voltages at these three cahodes. There will be markings on the printed circuit board for these cathodes marked as [Rk,Bk and Gk].
In your TVs case the voltage at the Rk marked pin will be higher that the other two cathodes. This can be caused by an open drive transistor or an Ic whichever may ysed there. If it is transistor, just replace it with a same type and number, as in the ace of ICs the related Ic, must be replaced. If only one Ic is uded for red, green and blue outputs, that Ic must be replaced.
If you need any more assistance, feel free to get me through Fixya. Ok.
Dec 01, 2010 | Philips CCB130AT 13 in. Combo
2008 f150 shakes when braking, chaged brakes and
makes no sense other than maybe the anti lock system is messing up
Mar 28, 2010 | 2008 Ford F-150
Sony KP53S76 Projection TV Convergence IC Bad
Should be a 392-150 make sure you replace both.
Feb 15, 2010 | Televison & Video
Duraband DBD VR01
Call manufacturer service/parts department for part numbers and ordering instructions
Aug 10, 2008 | Audio Players & Recorders
Tosiba TZ55V61 Convergence IC 150?s vs 110?s
STK392-150 can be replacement for 110's no other resister values need to be changed, however be sure bad resisters are replaced and check all the resisters (6) have been taken out of circuit and checked. also check for solder cracks and cold solder joints.
Dec 02, 2007 | Toshiba TZ55V61 55" Rear Projection...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
