When i print the documet the paper torn & jame . i pick out the ink also same problem
    Sergeant:
  • 210 Answers
Please check if there is a little piece of paper blocking the paper path or a part of the printer is not properly in place... try to print and when the paper jam turn off the printer and look on to the paper the lead edge of the paper what is blocking. I hope this information might help you solve your printer problem.
HRH
Posted on Jan 03, 2011
My Lexmark E332n (b/w laser) has worked perfectly for 3 or 4 months, then started jamming, creating a concertina effect on paper stuck between the output rollers. The upper of these is the heated roller...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Dec 22, 2010 | Lexmark E332n Laser Printer
I have never had a problem with this printer until now. I have installed new black & white as well as colored ink, but the power & paper lights flash, and both of the ink-out lights stay on. The...
Sad to hear that mate. I've still got mine and it works like a dream. I can leave it for years without printing anything and after a few head cleans it still prints like new.
Try and get another one because its that good and replacement ink costs
Sep 21, 2010 | Epson Stylus 880 InkJet Color Printer
Hi I've got an epson stylus dx4400 printer. The printer is a little strange because two of the ink cartridges are reading full, even though one of them is completley empty and the other is about a quater...
There is no sensor that reads actual quantity of the ink in the printer. The measurements are based on calculations how many pages are printed and what has been printed after last ink cartridge replacement. Probably the printer has been tricked that there is a new ink cartridge, but there is the old one.
Often a small object can fall in the paper tray and go down the paper path, preventig paper from picking up and moving. Rotate the printer with the front side up and try with thin and long flat skrewdriver to rise the thin long rollers that hold the paper to the feed roller, one after another. These rollers are held there by springs. If someting is stuck behind them, it should fall down. I've found there coins, pensils, rullers, paper-clips and so on.
Jun 15, 2010 | Office Equipment & Supplies
Paper comes out torn and see loose piece of foam
OK
Remove the ink cartridges and print-head then remove the long skinny piece of foam and wash it and dry it - don't wring it out but press it between sheets of paper towel. You'll see lots of ink come out of it.
Using more paper towel, clean out all the ink you can find inside the printer - there will be lots. Look at the end where the print-head parks and you'll see 2 more sponge pieces. Don't remove them but use plenty of towel to absorb as much ink as you can from them.
Once you think everything is clean look for any loose bits of paper inside and remove them. Then, refit the now dry piece of foam. It's not as hard as it looks as the thing is shaped so that it will only fit in one way. Make sure it is properly seated then refit the print head and the carts and switch on.
I've had this happen twice in the last year on my ip5200 - particularly when using scrap paper.
Dec 31, 2009 | Canon PIXMA™ MP510 All-In-One InkJet...
Ink cartridge not moving
it is a problem of carrage motorneed to replace
Sep 05, 2009 | Epson RX620 All-In-One InkJet Photo...
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
Paper jam in tray
Chances are the paper is getting torn as you remove the tray. I suspect you need to replace you feed rollers.
Feb 20, 2009 | HP LaserJet 4600dn Color Printer
Paper jam
Remove the toner, and try to gently pull out the paper jam.. If the page gets torn, or ripped, make sure you have all the pieces of the paper removed. Then re-start the printer. Print a test page to make sure the paper path is clear..
Nov 21, 2008 | HP LaserJet 4L Printer
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Black ink splattering the sides of the paper
remove ink cartridge wipe off print head area with rubbing alcohol
applied to a microfiber cloth
Jan 17, 2008 | Epson Stylus CX6600 All-In-One InkJet...
26 people viewed this question
jasbo
jasbo
