Question about Mastech 19-range Digital Multimeter Dmm Mas830b
Displaying incorrect voltage nearly an addition of 30 volts in actual AC supply
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 544 Answers
I would try to remove the battery.
Wait awhile and reinstall.
This might reset the meter.
Install new battery also may help.
Posted on Jan 03, 2011
  • amitsriva190 Jan 03, 2011
    Thanks, Will try the tips provided by you.... May be you are right as I was seeing battery low indication also at the time of incorrect voltage... Will update you tomorrow
Mine was reading 50-60 volts high on AC while the screen was perfectly contrasty, seeming to indicate the battery was fine. new battery fixed it.
Posted on Apr 02, 2013
I have an Everstart Jump Starter hp250,no AC adapter or manual. Not sure it even works. Is there anyway I can test it myself at no cost?
If the battery is discharged and been so for several months the battery is certain to be useless or nearly so. Lead acid batteries need to be kept fully charged or they die quickly. The standing rule for jumpstarters is to recharge monthly and after every use.
A cheap low powered jump starter will be cheaper to replace than to obtain a replacement battery but a replacement battery will be cheaper for a medium duty upwards and they are mostly easy to fit.
It is impossible to test a discharged lead acid battery or indeed a jumpstarter. A manual shouldn't be needed as they are intuitive to use and the safety precautions are generic.
The charger is also a fairly generic 12 volt charger (actually 13, 14 or 15 volts) as supplied with many appliances and accessories of all sorts and in addition the unit would be supplied with a fused lead to charge the unit from the cigar lighter socket, also generic.
If it charges successfully after you have borrowed a charger or connected it via the jump leads to a low powered, 0.5 amp, charger, the battery voltage should be at least 12.7 volts after standing idle for 24 hours.
Sep 12, 2017 | Computers & Internet
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
I have a desktop PC that when I turn it on it will power up and then after 6 seconds turn back off.
The first solution is right on the money, It's the video card, or many of us today forget to plug the damm thing in and the computer doesn't read and we think that there is a serious problem. If none of this helps then try troubleshooting through this PC repair guide. Hope this helps.
Dec 29, 2011 | E-Machines eMachines Desktop PC
What is the secondary voltage of power transformer
The schematics do not show the actual voltage.
From the design, the phantom power secpndary should be around 35 to 45 volts AC.
The 16 volt supplies would require a secondary winding that will be around 26 to 32 volts center tapped.
Transformers are quite reliable and unless a voltage is missing, the transformer is likely OK.
The most suspect items are the electrolytic filter caps if the voltage is not the design 16 plus and minus values.
Jun 16, 2010 | Mackie 1202vlz3 12 Channel Mixer
Printer will not turn on. power supply voltages
You should verify that your voltmeter is reading correctly. Check it against an fresh flashlight cell--it should read about 1.56 to nearly 1.6 volts. You apparently don't have an overload problem. Usually, only one voltage is the reference voltage for the voltage regulator (+5 volt?). It is entirely possible that the two supplies have a common failure. Make sure they have not been set for 220 volt AC supply.
Mar 01, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Can I use a 5 amp 240v AC domestic fuse to replace 5 amp 12v fuse
A fuse is rated for it's current carrying capacity so yes you can use a 240 volt 5 Amp fuse in a 12 Volt circuit.
The Voltage is given to indicate the insulation of the fuse, i.e. if you used a 12 volt fuse in a 240 Volt circuit it may arc and therefore is not suitable. You can always use a fuse with a higher voltage rating in a lower voltage rated circuit.
A 5 Amp fuse will carry 5 Amps indefinately and will only blow at 2 or three times it's rated current.
Oct 26, 2009 | Max American Terminal 30 i Fuses
On power on I am not seeing the display
either power supply is faulty or motherboard is fried. You can test power supply wires to motherboard with a voltmeter. Should be 12-13.5 volts. To high or very low voltage is bad and can fry video part of motherboard
Oct 01, 2009 | Lenovo 3000 N100 Notebook
My tecnics Amplifier Model # su-v98 has no power. I've checked all cords
Try these test, the only common possibilty would be the transformer and the power supply if both channels are out.You better to check both the positive and negative voltages from the power supply to see if both are present or if one or both are missing.This would be dc voltages of approx.20 to 40 volts.The positive voltage must be equal to the negative voltage,with the exception of their polarity.If one higher than the other, the regulator in power supply is busted already.The transformer can be checked for AC voltage before the power supply.This reciever uses a single power supply so the problem would be,common to both channels.You better change the regulator and checked some capacitor near the regulator.
Jun 14, 2008 | Technics Audio Players & Recorders
Lost power supply
If the desktop charger is the version that can accommodate two radios simultaneously similar to the T5000, then the AC wall adapter or the power supply is 9 volts AC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 26, 2008 | Cobra Radio Communications
Power supply gigaset 8825
The power supply for the 8825 base is to be 13 volts AC, rated at 850 milliamps or higher. You can go anywhere from 13 up to 15 volts without hurting the unit, and a higher current rating is even better. We actually make them ourselves through bulk purchases of varieties of power supplys. Your next delimma will be the plug size, it is a pretty common size, most universal adapters will have the right size of the outer and inner connections.
Nov 16, 2007 | Siemens Gigaset 8825 Cordless Phone
Mastech 19-range Digital Multimeter Dmm Mas830b Logo
237 people viewed this question
Top Mastech Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Paul Woodward
Are you a Mastech Measuring Tool and Sensor Expert? Answer questions, earn points and help others
