Question about Sony Cyber-Shot DSC-P73 Digital Camera
Not Pwering on despite changing batteries
Please advise the power problem
I have brand new batteries but my camera comes on and then goes off as if the batteries are dead??!
Posted on Aug 16, 2008
Brand new batteries,totaly discharged,on charger 8 hrs,charger lite is off.Place batteries in camera ,error message "charge battery".Same with used batteries.Is the charger defective or is the camera defective .What to do ??????
Posted on Jul 22, 2008
Mp3 not pwering up
Maybe you can try it after several time. One time my phone also can't be powering up, but after some days went, it is normal as before. I reall don't know how it is. But I'm very happy it goes well. If it can't work still, you may consider sending it for repairing or change a new one. In this summer, getting a waterproof MP3 player is a nice choice. Of couse,I hope this is the worst plan.
Jun 13, 2013 | Audio Players & Recorders
Pwering up after remodel
No reset anywhere on it. If it worked before then it most likely is the wiring to the machine
Jun 07, 2013 | Bosch SHU3036UC Dishwasher
Hi, when i turn my Techwood 37 off on to stand by it turns its self back on again despite advise of removing the batteries from the remote. It has also started turning its self on and off whilst you are...
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.
I hope this will help in solving the problem.....
May 07, 2011 | Televison & Video
When doing an ECG the low battery signal comes up and the tracing is not completed, despite being turned off and plugged into power for long periods.
u have to change the battery of ur machine. its a 9.6v battery pack.
before replacing the battery check is it gettigig the correct changing voltage . for checking that remove battery and connect the power and check the voltage at the battery connector on the machine . it should be about 10.5v. if it ok replace the battery
Jan 05, 2011 | Life Science Fukuda Denshi Cardimax Fx7102...
How do i change the battery
1. Get a new battery suitable for your bike type.
2. Ensure that the new battery have been fully charged to use.
3. RH cover under your seat housed the battery.
4. make sure that ignition and all that takes power from battery are off.
5. You will see your battery when you open RH cover under the seat.
6. Loosen bolt that holds red covered lead (power or positive)
7. Loosen bolt that holds black covered lead (ground or negative).
8. The reason taking the red lead first is to cut the power immediately.
9. Reverse the process for installation, ensuring are properly secured.
10. Ride on and enjoy.
Please rate the advise as we are giving free advise for community user.
Jul 31, 2010 | 1999 Honda VT 1100 C Shadow Spirit
What does it mean when the battery icon light it flashing yellow?
If the battery indicator is flashing despite it is being charged, then the battery has internal problem which means, it's need replacement. Please check that the battery is not physically damaged and check the voltage. Keep it outside without charging or installing on the system for few hours and try again. If this doesn't help, you'll need to replace it. Good luck. Thanks for using FixYa.
Jun 09, 2010 | IBM ThinkPad T60 Notebook
Not working
Press and hold the power button for 10 sec and if it is not working charge the battery and if you charge the battery and still not pwering on replace the battery and make sure to buy the original battery and not generic battery.
Jun 13, 2009 | Nokia 6270 Cellular Phone
Remote control that no longer works, ie. no response from the TV despite changing the batteries
You can get an IR remote tester at radio chack or frys. It's just a card that you point and shoot at with the remote. If you do not see red flashing on the card replace the remote . If you do then call serv shop. remote reciever is bad.
Apr 24, 2009 | Televison & Video
Sony Cyber-Shot DSC-P73 Digital Camera Logo
188 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
