Question about SanDisk 2GB microSD Memory Card
I am unable to format my memory card? i have purchased new sandisk 2GB micro sd memory card,but in few days this problem will occur
  • 2,386 Answers
Hello
You can use card reader to format SD card from computer, els the card is new you can avail warranty to replace this one.
Good Luck
Posted on Jan 03, 2011
    Guru:
  • 443 Answers
We Wish You a Happy New year.
Right Click on the Memory card and check for properties and see, if it is showing 1.85 gb then you need not format or try to format in FAT32 if you are using NTFS.
Hope this helps you. Cheers!!!
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
My 2gb sandisk micro SD card reduce the size after formatting
Possible micro SD bad sectors. To check your micro SD bad sector or not, you use the HD Tune software. To restore the capacity micro SD, which is done is Low Level Format. You can use the software HDD Low Level Format Tool.
How to use HD Tune and HDD Low Level Format, you can see here
Transcend Repair Bad sectors
How to repair micro SD, you can see in here
MMC Repair Without Losing Data Video 2
Oct 12, 2011 | SanDisk 2GB microSD Memory Card
After i insert my 1 gb sandisk micro sd card into my blackberry 8530, an error message comes up: "cannot access media card due to fatal errors" i have tried to install, repair, and format it...
It sounds like in your situation that you may have a bad card. If you cannot get your card to mount to your phone for storage, I would try to find access to a pc that has an SD card slot that you can try to format it that way. If the card still wont format, your looking at a defective card and will need to purchase a new one.
You can find Micro SD cards here for purchase.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Depa=0&Order=BESTMATCH&Description=micro%20sd&IsRelated=1&cm_sp=KeywordRelated-_-micro_sd_card-_-micro%20sd
Sep 22, 2011 | SanDisk 2GB microSD Memory Card
2gb micro sd...unable to format...disc managment shows no media.....my comp shows 0 volume....how to format???
It may be a bad memory card. I have encountered this before. It's more likely nowadays especially with more and more cheap cards produced.
Jul 25, 2011 | SanDisk 2GB microSD Memory Card
I added a 2gb mirco SD card to my Sansa e270 6.0gb player, but the memory is still only showing 10mb of the original 6.0 gb available for use. How do I get the Sansa to recognize and use the 2 gb mirco SD...
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e270 MP3 Player
I have a sandisk 2gb micro sd card. I put it into my computer's card reader and it keeps saying it needs to be formatted. When I try to format it it says windows was unable to complete the format. I am...
The FORMAT process is trying to write data to the card, but that writing is NOT successful,
i.e., the memory on the card is damaged/defective, and so it "fails".
Responsibly recycle the card, and purchase a replacement memory-card.
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
Formating problem
i cannot access my 2GB micro sd card in computer or phone, when i opened it from computer i get message card need to be formated but when i start to format card windows says unable to format this device. please help me.
from kapil sharma
Oct 30, 2010 | SanDisk 2GB microSD Memory Card
My2gb sandisk micro sd card always ask to format the card but the computer/mobile unable to format it please help
most likey it is a faulty card . or a cheap counterfeit . i had same problems and only a new card was the solution
Aug 02, 2010 | SanDisk 2GB microSD Memory Card
2GB Micro SD needs format code that I never gave it
You can format your micro-SD Card using a software which you can download by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time. Download that file and save it to your PC. Then unzip that ".zip" file.
If you format micro SD card connecting it to your PC via USB port, it may not ask for password. (I think your phone asks password to format.)
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
May 12, 2010 | SanDisk 2GB microSD Memory Card
2gb micro sd From Sandisk printer won't read.
From what info I have gathered is that my card reader on my printer is old and will not read that big of card. so off to the computer store to buy a new card reader.
Jan 19, 2009 | SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD Memory Card Logo
94 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
