Question about AEG Washing Machines
AEG 74630 update,my washine machine fills with water ,it can drain the water away if i set it to do it,but it will not spin whatsoever the belt is fine the water pump is fine i put it on short spin it goes through the cycle without spinning the door lock seems to be fine as it clciks as it should do please help....
    Genius:
  • AEG Master
  • 1,466 Answers
If the motor is not turning sounds like worn brushes on the motor...ensure no spin switch is not pressed in firstly...
Posted on Jan 03, 2011
Hi i have a problem with my servis m6725w washin machine it drains and fills but wont spin the drum at all
Motor brushes? Thyristor on control board? Belt broken? Not a lot else it can be.
Dec 28, 2010 | Microwave Ovens
Washine machine not spinning
It sounds like a snapped belt or a broken motor. Can you here the motor run? You can access the motor and the belt from the back of the machine. If it is the belt snapped, this is easy to replace yourself. If it is the motor, you will need a repair man.
Jul 17, 2010 | Bosch Washing Machines
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
AEG 74630 washing Machine stopped working, will not spin or complete cycle, have manually drained and checked for blocks in pump but seem OK
I have same problem right now. The machine works fine up to the stage where it needs to pump out. the pump was dead. Have replaced the pump, but still not working and it's probably the PCB that needs replacing - expensive but will buy reconditioned for about £50.
Pump available for the machine on Ebay and easy to replace. Take of machine back panel - make sure machine off and unplugged. Pump has 3 screws holding it in - then just replace. Easy. Good luck
Jan 08, 2010 | AEG Lavamat 72640 Front Load Washer
Water will not drain from washine machine
it could be your lid switch or your water pump
Mar 17, 2009 | Kenmore 22642 Top Load Washer
Washine machines
Yes. There is a part that allows you to connect the cold water supply to both the hot and cold inlet hoses. It has worked successfully on our 6100 for 8 years or so. I think it was part of the original kit rather than a subsequent purchase - it's a Y-shaped yoke with an inlet connection and two outlets that accept the two hoses feeding the inlets of the machine. From memory i tink the situation is mentioned in the user manual somewhere.
Jun 10, 2008 | AEG Lavamat 72640 Front Load Washer
Need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Apr 09, 2008 | Washing Machines
Washing Machines slowly fills with water over a few days
could be leaking inlet valve or if drain is plkumbed in unbder sink, could be filling thro drain pipe when you emptyt sink
Mar 17, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
190 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
