Question about Dishwashers
LG LD1415T1 showing error IE?? - Dishwashers
2 Suggested Answers
  • 1382 Answers
SOURCE: LG Dishwasher - LD1415T1 -
"OE" indicates outlet error in your dishwasher. Check that you can hear water pumping first if not check your drain lines for obstruction.
Thank you !!
Posted on Jul 30, 2010
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
My fuzzy logic LG washing machine, is no longer spinning or washing the clothes its showing error
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
TIP Make sure the water taps are fully open.
Make sure the hoses are not kinked or pinched. (Use caution when moving the washer.)
Clean the inlet filters.
Check another faucet in the house to make sure your household water pressure is adequate.
Reference:
http://www.lg.com/us/support/answers/front-control-top-load-washers2013/control-panel
May 19, 2015 | LG Washing Machines
My LG LD1415T1 dishwasher displays E1 at the end of short wash cycle. It's OK again when cooled down
from what I can work out this is related to measurement of the flow and water levels, check all hoses etc for any build up and make sure they are clean.
http://answers.lg.com/answers/7676/product/MD00000191/lg-electronics-ldf6920st-questions-answers/questions.htm
Feb 05, 2015 | LG Dishwashers
Cold water will not shut off and keeps running into the machine and then machine shows error ( IE)
'IE' for LG's decodes as 'water inlet error' which is quite right!
This is symptomatic of a malfunctioning water control valve- it's not closing completely- its default/no power state. Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Apr 06, 2011 | LG WM1812C Front Load Washer
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
Water not pumping out of LG model no.LD1415T1 dishwasher pump blocked or faulty how can I fix it? thanks,Gaz
well gaz put your work clothes on i am a lg oem authorized repair company... if the pump is bad you have to pull the dishwasher and turn it up to get to the bottom of unit and replace... not really that difficult just time consuming... it is possible to get down into it from the inside of unit by removing componets in bottom of dishwasher and checkwith your finger for obstructions...these things have plastic impellers so it doesnt take much to take out the motor... goodluck.....
Dec 31, 2010 | Dishwashers
LG Dishwasher - LD1415T1 - ERROR CODE: OE. Ive cleared the filters and still not working?
Thank you !!
Jul 30, 2010 | Dishwashers
IE error code
IE. is inlet water valve error.
Make sure someone did not turn off the water to the washer!!!!
Remove fill hoses and check filter screens on washer and fill hoses and clean if needed.
If problem continues water valve may need to be replaced.
Jan 16, 2010 | LG Washing Machines
LG FRONT LOAD WASHER ERROR CODE IE
LG has general error codes for all there appliances and the "ie" error code is for the water supply. You either have a kink in your hose, water vavle shut off, or the bad problem your pump is bad.
Jul 30, 2008 | LG WD-1045FH Front Load Washer
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
Owen Barnes
