Question about Homedics Digital Scale
I CHANGED THE BATTERIES ON MY HOMEDICS SC372 SCALE AND NOW IT WILL NOT WEIGH ME. DO I NEED TO WAIT A PERIOD OF TIME FOR THE BATTERIES TO CHARGE THE SCALE? IF NOT, WHAT COULD BE THE PROBLEM?
SOURCE: can't find instructions for Homedics digital scales SC-390
EACH BUTTON IS FOR FOUR INDIVIDUAL USER. BUTTON ALLOWS YOU TO INPUT IDEAL WEIGHT (FOUR GOAL WEIGHTS FOR FOUR INDIVIDUAL USERS). AND CALCULATE AGAINST ONE OF THE FOUR INDIVIDUAL ACTUAL WEGHTS. i AM USER 1 IN MY FAMILY. I HIT THE 1 BUTTON, WEIGHT AND MY GOAL WEIGHT COMES UP BEFORE MY ACTUAL.
Posted on Mar 08, 2009
  • 208 Answers
SOURCE: Inaccurate Readings
time to buy a new scale :)
Posted on Jun 22, 2009
  • 39 Answers
SOURCE: The Homedics SC 380 scale does not work after the battery insert
ensure the battery contacts are clean, if they are corroded it wont work. You may have to buy a contact cleaning spray or brush to do it.
Posted on Feb 01, 2010
SOURCE: scale wont reset bfm788dq-63 health o meter
There are lots of links which may help you but according to me http://www.dictone.com help more
Posted on Jul 02, 2010
guyster7148
  • 192 Answers
SOURCE: i changed the batter in
Open it again and make sure the battery is in the correct angle..... I have made this mistake from time to time
Posted on Sep 12, 2010
What kind of battery do I need for Homedics Lithium Electronic Scale
Here are the Instructions for SC300:
http://web.archive.org/web/20061029012330/www.homedics.com/prod/getpdf.aspx?name=SC300.pdf
Page 2 says the scales require a 3 volt CR2032 lithium battery. These can probably be found wherever batteries are sold - WalMart, Target, etc.
Dec 09, 2014 | Homedics Health & Beauty
Operating instructions for Volt -100 pocket scale
If you don't have the measured weights that sometimes come with scales or can be purchased individually, I'd recommend using a United States nickel/5 cent coin. They are supposedly an exact 5 g's each, and a Volt-100 scale requires 100 g's for recalibration. Therefore, you can recalibrate your scale using 20 nickels. I also use a Volt-100 and so far this has worked for me exactly; the most it's ever been off is .02 g, which is basically nothing.
What you do is remove your batteries, (I'd replace them with brand new ones if you have the option) then place the scale on a completely smooth, perfectly level, flat surface. Power the scale on, make sure it is reading 0.00, hold the M (mode) button until CAL comes on the screen, release the button for a quick second, then press it again one more time (quickly, don't hold this time), and then wait until "100.00 g" is flashing on the screen. Then you're going to place your 20 nickels on the scale as smoothly and with as little jostling or movement as possible. After a moment, the screen should read out "PASS". You then power the scale off (don't weigh anything before turning it off as it can possibly adjust the calibration you just set or weigh out heavily or light) and to test out your newly calibrated scale, turn it back on and weigh one nickel. It should be exactly 5 g's, with no more than a .02 digression in either direction if done properly. Good luck!
Jul 07, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Scale keeps showing lo no weight
Try taking the battery out and putting it back in, also there should be a small reset button. You will need a toothpick to push the reset button. Allow time for the scale to reset before stepping on it.
Apr 19, 2011 | Homedics Digital Scale
Hi I have the the Weight Watchers Body Fat/Hydration Electronic Scale WW83C model and I keep getting SLo or HLo when I step on the scale depending on how I switch around the batteries. How do I fix this...
the remote is actually the peice the time is on.. i just changed the triple a batteries now and the hlo disappeared and i am now able to weigh myself again
Sep 15, 2010 | Conair WW81 Weight Watchers Body...
I changed the batter in my homedics scale model #sc-535 1606 and noe it does not work
Sep 12, 2010 | Homedics SC-405 Digital Bath Scale
Hello my taylor 5589 fat scale doesn´t work anymore. each time i weigh myself it says err2. i changed the batteries and it´s still the same.
Had the same problem with mine and sent it back since it's under warranty. Taylor did not need a receipt and I just received a new scale today, model 5742 although it cost me just about $20 to ship it back and that's UPS ground! The scale retails for $29.99 on amazon.com. Good luck!
Dec 01, 2009 | Health & Beauty
Need to reset scale weight
You have probably set your scale to kilogram and not pounds. There should be a button to set this underneath the scale or even a reset button to reset the scale to its original settings.
Jul 08, 2009 | Homedics Glass Top LCD Digital Lithium...
Battery replacement
Check to make sure you inserted the batteries correctly the plus signs should be up. If that doesn't work I reccomend contacting homedics customer support as something is worng with the scale that you cannot fix there is a lifetime limited warranty on the product so its better to let them try to fix the problem.
here is support contact information
http://www.homedics.com/products/support
here is the information on the warranty
http://media.homedics.com/warranty/warranty_life.pdf
Apr 01, 2009 | Homedics Elegant Glass LCD Digital Scale...
Homedics Digital Scale Logo
224 people viewed this question
Top Homedics Health & Beauty Experts
Jim London
Jim London
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
