Question about LG Heating & Cooling
Not too sure of model number on our split system. I think it is LSM304H-1. It was purchased in 2002. It runs for a minute and thens cuts out. Turn it on again and runs for a minute and turns off. Any help would be great. Thanks Sue\r\nhoward.susan40@yahoo.com
  • howard_susan Jan 03, 2011
    I will ask my Dad to check it out tomorrow. Thanks
  • 425 Answers
there are several reasons why your unit cuts-off. the safety devices on your system is working probably for some reasons:
1. try to check if the fan is running.
2. it could be it cut-out to high pressure. check the line, probably their is a close valve in the high pressure side or the low pressure side that causes your system to cut-off or due to sudden change in temperature in your area.
3. check your compressor oil level and also its temperature maybe it runs also too hot for it to cut-off.
4. check also the temperature settings of your unit or the timer if there is any maybe it is set for just a minute!
Don't forget to rate my for helping you... thanks a lot...
Posted on Jan 03, 2011
What dose the plasma button do
Plasma purification can be started by pressing the PLASMA BUTTON on the remote controller.
Repressing it will deactivate the operation.
Nov 06, 2016 | Televison & Video
Will not run under load, seems to be starving for fuel. When I leave it for a minute or two, I can start it and work with it for a minute or so then it sees to over rev before cutting out. If I start it...
Check the fuel filter in the tank for plugging. Check the fuel lines for kinks, rotting, or splits. Check the muffler and air cleaner for plugging. Make sure all the screws and mounting nuts are tight on the carburetor. When these things look ok, then turn the H needle jet CCW about 1/2 turn, start the engine and let it warm up. Open the throttle fully--the engine should be 4-stroking now. Proper adjustment is when the engine will 4-stroke, but immediately 2-stroke when cutting. You may need to turn the H needle somewhat CW to achieve that condition. Hope this helps!
Apr 16, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Daikin aircond cuts off i reset the circuit breaker and it works for ten minutes and cuts off again
What is happening is the a/c is overamping. This could be caused by a number of things. 1 Low air flow through coil, cause, dirty filter or evaporator coil, cure, clean both should look as if it is new. 2. compressor pulling more amps due to age or mechanical problems. Now depending on the area you live look at the wattage on the system. It may be in Kilowatts, if so take that number and divide it by the voltage that the system is required to operate on and this will give you a number which is your amps. Now go to the power supply to the house or apt and see if the breaker listed for the a/c is the same number as your past number that you had from the kilo watt calculation . This number shoould be below the number on the electical breaker. If it is higher than the breaker you need to have the breaker replaced for a high amp. draw. Make sure to check for air blockage first then proceed. Good luck on repairs
Dave
Dec 08, 2009 | Cfm Daikin R410a Split System Air...
2002 malibu anti theft problem
With the car RUNNING cut the yellow wire to the ignition switch from the group of three wires.
Make sure the car is RUNNING when the wire is cut.
Tape the ends and thats it.....the car will start first time from now on....as long as you don't mind not having anti theft.
Sep 17, 2009 | 2002 Chevrolet Malibu
Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Dec 10, 2008 | Bose (321GS) System
Low Fuel Cutting
ill fill up tomorrow morning. I slowed down to take a left hand turn. As soon as i started turning the bike started to cut out and hiccup like mad. I rode the corner out clutch in while giving it full wrist to keep it alive. As soon as the bike straightened back up it came back to life. It rained yesterday pretty hard so i drove to work but i bet $1000 dollars that if i fill it up today it will ride fine again. So the question is...clogged fuel filter, fuel pickup, fuel line? My guess is crap on the bottom of the tank and when low the fuel pickup is choking/starving on the sediment in turns. So im just throwing this out there, to see if anyone thinks this the right diagnosis. Thanks for any input.,Thats exactly what happens when you run out of fuel... so it could be a bad filter or pickup clogged.,,,
Nov 10, 2008 | 2002 Ducati 998 S Bostrom
Low Fuel Cutting
SPLIT AIR CONDITION MODEL ACT24W6WE AFTER ONE MINUT TURN OFF PLAESE GUIDE ME
maybe detecting lack of freon...does it cool during that 1 minute?
May 31, 2007 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
124 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
