Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
I´m P-08 code
  • 2,133 Answers
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor.
Due to short of gas/evaporator & air filter blocked/less rpm of blower motor.
Remedy: Find leak and arrest and do gas charging/clean filter & coil/replace B.Motor capacitor.
Posted on Jan 03, 2011
How do I fix code 13 engine speed sensor Above 1000 rpm
Clearing the codes is simple that is done by removing the fuse of the EFI from junction box 2 for 10 seconds. Make sure to remove the jumper wire and switch the key off before clearing the codes.
Here are some common Lexus vehicles 1990-1995 codes:
Code 12 and Code 13 Rpm signal circuit fault
Code 14 Igniter signal circuit fault
Code 16 ECT control signal fault
Code 21 and Code 28 Main oxygen sensor fault (for ES300; SC300 & GS300 models)
Code 22 Coolant temperature circuit fault
Code 24 Intake temperature sensor circuit fault
Code 25 and Code 26 Air fuel ratio fault (for ES300 & SC300 models)
Code 27 Sub-oxygen sensor circuit fault (for ES300 CA & GS300 models)
Code 31 Low airflow meter voltage (for ES300 and GS300 models)
Code 32 High airflow meter voltage (for ES300 model)
Code 35 Barometric pressure sensor circuit fault (for GS300 & SC300 models)
Code 41 and Code 47 Throttle position sensor circuit fault
Code 42 Vehicle speed sensor circuit fault
Code 43 Starter signal
Code 51 Switch condition signal fault (for ES300; GS300 & SC300 models)
Code 52 Code 52 and Code 55 Knock sensor circuit fault
Code 71 EGR system circuit fault (for ES300; GS300 & SC300 models)
Code 78 Fuel pump control circuit fault (for GS300 & SC300 models)
Nov 18, 2014 | 1990 Lexus LS 400
Ok had the codes come up for both crank sensors on our Pontiac Montana and knock sensor, replaced all three sensors cleared codes and the check engine light keeps coming back on after clearing codes, for...
I guess you do not know that OBD Codes have
nothing to do with replacing parts
The Codes are used along with the diagnostic
info & charts to check the system that set the codes
Only component testing will find a problem
You used the name of a codes to replace a part
with a similar name
I would guess you did no testing & have no idea why the
fault codes were set, so you found no problem, thus you
fixed nothing & the MIL Lamp is still on
You Cleared ALL DATA needed to help diagnose the issues
You lost your codes & freeze frame data at the time the codes
were set & your lost your emission monitor data
Now you get your codes & write them down
Google the codes & study the possible cause
& solutions
TYPE: OBD & your codes
Need to study OBD Vehicle Systems
Oct 16, 2014 | Cars & Trucks
Ford f350 code 22 keeps coming up
Well ya
You have to have a shop diagnose the code & component
test to find the problem & resolve it
We have had codes & obd systems since 1981 on GM & Ford
& every other vehicle worldwide since 1983
You have a vehicle that has a problem & fails to meet federal
emission standards,you know that, you have gotten the code,
now google the code & read up
The internet has pictures of how to get older OBD 1 Codes
& has a list for you of the sensors & problems
Jun 13, 2014 | Cars & Trucks
Nokia 2320c-2b unlock code please imei:011975003866993. email:bogyishar@gmail.com. . thanks in advance.
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Dec 07, 2010 | Cell Phones
When i want to delete multiple contacts it asks for phone lock code what is that code i am having samsung corby text
hi, you could try the default codes first.
1234 0000 or the last 4 digits of your phone number.
if that didn't work, you need to reset the phone.
*WARNING* this will erase all data & files on the phone memory.
Remove the sim card & memory card (if any) then turn On the phone.
*type in these codes, 82767*3855# *Phone will restart then place the sim card & memory card back in, power up the phone.
password should go back to default.
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks... ♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫♫
Jul 01, 2010 | Samsung SGH-S5230 Cell Phone
Radio not accepting manufactur code.
If it is the correct code, you may have entered it a few times & locked the system. Either disconnect the battery & wait a minute & reconnect & retry, or pull the radio fuse & retry after waiting a minute & reinstalling.
Feb 14, 2010 | 2003 Honda Odyssey
Hello! I have a Nokia 1200
try this code 12345 or 0000 or 00000
Jul 24, 2009 | Nokia 1100
Format N95
There are 3 methods to format the phone
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! IMPORTANT: back up your phone and memory card first! ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
First: if the phone menus work there is a; go to menu -> tools -> settings -> general -> factory restore. note: the defualt code is 12345
Seconed method requires you to enter these into the dial number area. Nokia Code : *#7370# : NOKIA Format phone (Soft Reset)
Nokia Code : *#7780# : NOKIA Factory Reset (Hard Reset)
Found these in the N95USERS fourm. Note: the defualt code is 12345
Third: is a button combination the needs to be done during the phone powering on
Hold down. 3, * and Green Call button While holding this combination press the power button once to start the phone Note: this does not require any codes; if this works the phone will prompt you to be set up again
None of these methods format the memory card
There are two methods to format the memory card
First: Go to menu -> tools -> utillites -> memory -> options -> format mass storage
Seconed: Connect your phone to your PC via the supplied USB cable. Then select Mass Storage mode on the phone. Once you PC has installed the Mass Storage device you can format the card from My Computer. Note: assuming Microsoft Windows XP or VISTA.
Billman87
Nov 16, 2007 | Nokia N95 Cellular Phone
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
469 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
