Whenever I turn on my HPPresario C500 laptop computer on I get a message reading that HPProduct Assistant cannot be found on my computer or the I have to browse for another path. I am not a technician or a computer analyst. I formatted the hard disk yesterday and everything was working well. Culd you help me out ?
    Sergeant:
  • 210 Answers
Hi, I believe that the HP Product assistant software you had deleted when you formatted the hard drive... My question is did you follow the user guide manual. did you use or install a different operating system? My only suggestion is to click start click run type msconfig click ok ,click startup tab and uncheck the HP product assistant, and restart the computer. I hope this information will help you solve the problem.
HRH
Posted on Jan 03, 2011
How to clean the fan of my computer
Regular maintenance of your Compaq Presario laptop helps to keep the machine running properly.
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
or you might want to remove it to get it clean
HP Presario C500 is a laptop that, like most other laptops, requires a clean, functioning fan in order to work properly.
If your fan is too full of dust to function properly or needs to be replaced because it is no longer working, then your computer could be in danger of overheating and crashing.
Instead of having to purchase a new laptop because your C500's fan has failed, remove it and clean the fan or replace it with a new one.
Turn off your computer and unplug all the cords and cables from it, even the power cable.
Turn the laptop over and remove the battery, then remove all the screws at the bottom of the computer with a Phillips-head screwdriver.
Remove the two face plates from the bottom of the computer and you'll see the hard drive and RAM below.
The face plates will come out easily once the screws are removed.
Remove the two screws holding the hard drive in place and then lift the hard drive out.
Remove the screw found directly below the hard drive.
Turn the laptop over again and pop off the keyboard.
If all the screws at the bottom of the computer where removed, then the keyboard will come right out.
Remove all the screws underneath the keyboard and case and then lift the case enough to access the fan assembly in your HP Presario C500.
Unhook the cable coming from the fan into the motherboard and remove the screws holding the fan in place, then pop the fan out of the computer.
Hope this helps
Oct 20, 2012 | Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD...
How to clean the fan air
or Remove an HP Presario C500 Fan Assembly to clean it
Hope this helps
My Compaq Presario V3000 has a problem with the wireless on it. Whenever the wireless side-switch is turned on before I turn on my laptop, before it shows the login screen a blue-screen message shows...
you should reinstall the wireless drivers on your laptop go to the hp support site and type in the model number (it can be found on the white service tag under the laptop)
Jun 14, 2011 | Computers & Internet
Acer orbicam 3690-2710 stop working after install. Initially worked upon setup, but when I try to reopen after closing it a message appears saying: "A webcam was not found or is not working...
Access Camera Assistant Software:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
If the the above steps are not working, then follow the below steps:
You can reinstall the WebCam drivers from the Acer recovery management, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> Restore Application & Drivers> Contents> Select Acer Crystal Eye and install it
OR
Got to http://gd.panam.acer.com/home/
Select the computer model
Select Operating System
Click Drivers
Select Camera (Orbicam) and download it.
Once downloaded install it on your computer.
If still facing the issue, then you may need to perform full system recovery, to do so please follow the steps mentioned below
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer
Dec 06, 2010 | Acer Aspire 3690-2710 Notebook
I cnt found the VGA driver compaq c500 laptop.
Go to the compaq's official website, Go to drivers and enter your model number then you can download drivers of your notebook. Thank you. If you like it, please vote me.
Jun 12, 2010 | Compaq Presario Notebook
My dell latitude c510/c610 failing
Sounds like the fan may be failing and need replacement. On a system that age, it is debatable whether it is worth fixing.
You can boot to he resource cd and run fan diags is you want to try and confirm
Fans can be found on EBay
May 26, 2010 | Dell Latitude C640 Intel Pentium 4-M...
No sound,modem and wireless assistant for my compaq presario c500
You didn't mention what OS you are running but this link will take you to the main driver page for the c500 on HP's website.
Please post your results back here, especially if you have problems finding/installing the drivers for your unit and need additional assistance.
Mar 31, 2009 | Compaq Computers & Internet
Pop up weindow
Hi Ma`am,
You can stop this message from appearing by deleting it in the start-up configuration. How to do this is go to start then run, on type msconfig. A menu will appear then go to start up tab then uncheck the the HP Product Assistant. After the configuration was done the computer will ask to restart your computer. Try if the popup windows will still appear.
Sep 09, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
