Question about Hitachi L47V651 47 in. HDTV LCD Television
It will not turn on somtimes and I have to press the Input button on the TV approximately 20-30 times before the TV will stay on
  • Hitachi Master
  • 6,993 Answers
once a TV does not power on, it is said to have a power problem. The TV still turns on after so many attempts because the damage is not very much. Since it is a power related problem, you need to check those part of the TV that has to do with power such as the AC power cord/wire that runs from the wall (electric outlet) to the TV and the power board inside the TV.
Check the AC power cord/wire, make sure the wire is not damaged in between the part that enter into the wall and the TV. If the wire is intact, then it means the power board is the next to diagnose.
This is the board where the AC goes to. First, check the AC wire and make sure it's not having a partial contact on the power board.
If the AC wire is intact on the power board, then this problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
I do not think the power board needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Posted on Jan 03, 2011
What is the code for a universal remote 24914 to a kcpi dt 504 digital tv????please help we done punched in all kinds of diffrent codes and nothing
1. Manually turn on the device (TV,DVD, etc.) to be controlled.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP
button.
3. Press and quickly release the desired device button (TV,DVD,, etc.). The red indicator blinks off once.
4. Press the ON•OFF button repeatedly (up to 300 times) until the device to be controlled turns off. The red indicator blinks off with each button press. Press and release ENTER to install the code.
Auto Code Search Method for GE Universal Remote 24914-v2
1. Manually turn on the device you wish to control.
2. Press and hold the SETUP button until the red indicator light stays on (approximately 4 seconds) and then release the button.
3. Press and release the desired device button on the remote ( TV, DVD, CBL/SAT, DVR/AUX). The red indicator will blink once and then remain on.
4. Point the remote at the device and press and release the POWER button (for TV) or PLAY button (for DVD, VCR,etc.) to start the search. The red indicator will flash (approximately every 2 seconds) as the remote searches.
Note: The remote must be pointed at the device for the duration of this search.
5.Place your finger on the #1 button so you are prepared to lock-in the code.
6. When the device shuts off or begins playing, press the #1 button to lock-in the code. The red indicator light will turn off.
Note: You have approximately two seconds after the device shuts off or begins playing to lock-in the code.
7. Point the remote at the device and check to see if the remote operates the device as desired. If it does, no further programming is required for that device. If it does not, return to step 2 and start the auto search again
Mar 22, 2015 | Universal Televison & Video
I lost my manual to my ge 24914 universal remote, i need the code to program it to my curtis mathes tv.
Press 'setup' until red light stays on, then press TV once. Press the on/off button (up to 300 times) until TV turns off. Then press 'input' on the lower right side of the remote until the light goes off. It's programed now, I just did this for my mother-in-law. For us, it was about 40 presses of the on/off button.
Feb 05, 2011 | GE JASRM24912 Remote Control
Brookstone jumbo remote control - 2006, I've lost the manual on how to program it to my parents RCA tv. It does not have a code search button on the remote itself.
finally found answer online... power off the TV press the tv/dvd/aux/etc button until the red power light turns on and stays on, then press the power button on the remote one time, then once it's on use the channel up/down button pressed repeatedly until the TV turns on, then select input to store the code.
Feb 16, 2010 | Televison & Video
How do i program this remote to a mitsubishi tv?
  • Manually turn on the device you wish to scan for (e.g. TV)
  • Perform Power Scan by pressing and holding (approximately 3 seconds)the desired DEVICE MODE button TV, VCR, CBL, DVD or SAT until the status indicator light begins to blink.
  • Press and release the PWR (power) button. The status indicator light will stop blinking and stay ON at this point.
  • Press and release slowly and patiently the blue UP ( ? ) button to scan forward through the code database. To scan backward through the code database, press and release the blue DOWN ( ? ) button. Each time you press the up or down arrow, the remote will try and turn off the device (TV, VCR etc) you originally selected.
  • When the device (TV,VCR etc.) responds by shutting off, press the ENTER button. This will store the code
  • in memory and you will see three blinks of the status indicator light to confirm the code input. Be patient, there are over 100 codes to search through.
Oct 20, 2009 | Big Button TV Universal Remote
S-video
you must use tv remote to select s-video w/input or source button. somtimes you must scroll down to desired input then press OK or ENTER on remote. mch
Feb 20, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
The screen stays black but have only the sound
if u have sound, hold a flashlight to the screen and look for a picture. if u see a pic, the backlight/inverter has failed.
Dec 06, 2008 | Televison & Video
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
Pioneer XV-DV99 high definition DVD/Rewriter
Try one of these codes:
221, 222, 154, 160, 174, 180
Or use the Seach feature:
Hope that fixed ya...
Geno
Mar 28, 2008 | Televison & Video
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
RGB
Press input until tv apears again. Or go into menu , setup Video input and select av or tv what ever you use.
Dec 23, 2007 | Vizio L37 Television
Hitachi L47V651 47 in. HDTV LCD Television Logo
63 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
