Question about Mitsubishi Heating & Cooling
What are the overall dimensions of the outdoor unit of Mitsubishi air-conditioner type 6E50VA?
  • 2,133 Answers
You can check with your model and type log on to :
www.mitsubishielectric.com.au/.../MXZ-2A52-3A54VA-Specs.pdf
Posted on Jan 03, 2011
Mitsubishi air conditioner flashing timer light flashes twice
Switch the polarity of the control voltage...make sure it matches with the indoor & outdoor unit
Dec 18, 2013 | Mitsubishi Heating & Cooling
Have a Mr Slim. Air comes out but not cool. The green light was flashing. Turn the unit off and then back on and it stopped flashing, but still not getting cold air. Cleaned out the filters as well
i have vast history with this type of unit its like working on a computer all controls are microprosser based send me m# and s# of indoor and outdoor units might be able to help.
Jul 03, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
P8 showing on air cond and air con is not working
P8-Abnormality in outdoor unit.
Solution:
1) Check the indoor/outdoor connecting wire in proper point.
2) Change the connection of electric wiring, if reversed phase.
3) Check the protection device, if malfunction, replace it.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Thanks.
Feb 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
How much does this unit weigh?
dear sir
AMNA PTC153D35AR AIR CONDITIONER,S SPECIFICATION DATA ARE GIVING BLOW:
Dimensions & Weights Overall Width: 42" Chassis Width: 40" Wall Sleeve Width: 42" Overall Depth excl. Outdoor Grille: 21 1/2" Wall Sleeve Depth: 14 1/8" Overall Height: 16 1/16" Net Weight: 105 lbs. Shipping Weight: 120 lbs
Sep 29, 2010 | Amana PTC153D35AR Central Air Conditioner
This unit will not cool. The heat pump seems to work fine. Unit is fully charged. One tech seemed to think it might be a valve of some sort. Never been used.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
I would check the wiring between the indoor and outdoor units...
There also should be some led lights blinking that will help you troubleshoot the problem...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Sep 12, 2010 | Mitsubishi Heating & Cooling
I have a Mitsubishi MS-a12-wa Mr Slim. I have a mouse caught between the grill and the unit of the outdoor unit. How do I remove the plastic grill from the unit. It looks like there may be tabs but I do...
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Aug 15, 2010 | Mitsubishi MS-A12WA Air Conditioner
Rheem, 3.5 ton,heating unit does not come on, main braker is at the on position,air handler comes on, is there a braker in the unit itself?
There is a red reset on the outdoor unit, near where the copper lines connect to it, also there should be fuses in the disconnect box, near the outdoor unit, that the electrician installed.
Jan 12, 2010 | Mitsubishi MS12TN Air Conditioner
Mitsubishi Mr Slim mini split outdoor unit fan.
Check the capacitor. Rating must be within 90% of rated microfarads. If it is a dual capacitor test between C and FAN. Set your meter to read microfarads (uF).
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Ac unit shuts down
See this document for P8 code on Mitsubishi Mr Slim MXZ30TN... It is likely you can get the fix just from following the diagnosis steps 1-7. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jul 02, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Open Questions:
Heating & Cooling Logo
110 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
