Question about Nintendo Wii Console
Everything is plugged in correctly, but the light on the console is black. And it will not turn on or eject.
  • 839 Answers
There are series of problem in Nintendo wii which can be solved without much technical knowledge........ Your problem belongs to that so don't worry i will give you the link to download the Nintendo repair guide that will help you a lot...
Click here to download Ninento wii repair guide
Posted on Jan 03, 2011
My son was playing his newly internet connected game black ops, in the middle of the match it said error on disk please eject disk and turn off console. He ejected the disk but the console would not turn...
This sounds like an error with the console that would need a repair from Nintendo. You can send the console to them in order to get it fixed. This usually takes about a month.
If you are more adventurous, however, there is a great guide I will link below that will help you correct the problem yourself. Warning, though, it should not be attempted unless you know what you are doing.
http://hubpages.com/hub/wiidiyrepairguide
Mar 06, 2011 | Nintendo Wii Console
Red light flashes when turned on, cant even eject disc
Try to do these 3 things.1 - Restart your console.
2 - Take out all cables, and plug them back in.
3 - Take out the hard-drive, and place it back in your PS3 console.
Try this to take the disc out:
1. turn the PS3 off from the back
2. Put a finger on eject button
3. then turn PS3 on from back with finger still on eject button
4. disk should come out
May 07, 2010 | Sony Playstation 3 (PS3) Console
What is wrong with my xbox it says error 65?
Error 65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
Flashing red:
1.the av cable cannot be detected
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
2.general hardware failure
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
Feb 08, 2010 | Microsoft Xbox Console
My wii turns on to a black screen and stays there
as a manufactuer of the wii console the internal scart funtion may be damaged due to, to much use of the console. Basically not being able to be used
Sep 19, 2009 | Nintendo Wii Console
Xbox 360 won't turn on
To troubleshoot this problem, try the following steps:
Examine the power indicator light that is located in the center of the Ring Of Light on your Xbox 360 console. If there is no power to your console, the indicator light is off and the fans are off.
* Press the power button. The power button and the power indicator light are located in the center of the Ring of Light on the front of your Xbox 360 console. If your Xbox is functioning correctly, the power will turn on.
* Press the eject button on your console disc drive. If your console turns on when you do this but does not start when you use the power button, there may be a problem with the power button or the console faceplate may not be attached correctly. Contact Xbox Customer Support for more help.
If the above step does not resolve the problem, examine the power cord where it connects to your console and to the power outlet. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord.
If this does not resolve the problem, see whether the power cord is plugged in to any device other than a typical power outlet. For example, the power cord may be attached to an extension cord. If this is the case, remove this device and then plug the power supply directly into a power outlet.
If the problem is not a connection problem, examine the light on the Xbox 360 Power Supply.
* A green light indicates that the power supply is functioning correctly. If the light is not green, contact Xbox Customer Support for more help.If these steps do not resolve the problem, your console needs service.
Sep 01, 2009 | Microsoft Xbox 360 Console
Disc stuck inside Wii Consule
Unplug everything from the system and the power cable from the wall or power strip, let it sit for about 5 minutes. Plug everything into the system first then the wall. Power should come on
If the disc does not eject, contact nintendo, the disc drive will need repair
Mar 15, 2009 | Nintendo Wii Console
Power Outage & Now Wii Won't Power Up...
When this same thing happened to me, I unplugged the Wii power supply from the wall (not just from the back of the Wii) and let it sit unplugged for about 10 minutes. When I plugged it back in, everything was fine.
Nov 11, 2008 | Nintendo Wii Console
Green light stays on, black screen, no sound, no connection w/ remotes
Go to the tv settings and check to see if you blocked any incoming devises. If you did block the devides, your tv will not read the wii
Jun 11, 2008 | Nintendo Wii Console
N64 Console
try using the cables instead of RFS's
Apr 01, 2008 | Nintendo 64 Console
Nintendo Wii Console Logo
12 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
