Question about Air Tools & Compressors
Kaeser Sigma SX-6. By some reason I have not access to password level 4. For the levels 0,1,2,3- no any problem. Until now I have been used 12EXP as Level 4 and it was working. Any idea what can be changed to get Level 4 access.
  • 98 Answers
SOURCE: Sigma air end pump repair
A company in Forsyth , GA tele. phone # 478 974-0018 Simple Air Solutions LLC.
Posted on Aug 12, 2009
Testimonial: "Thank you for the information ."
Porrelli
  • 167 Answers
SOURCE: need to set low level on my compressor
That would depend on the type of pressure control switch it had on it, but all of the ones I've ever seen have it near the high pressure adjuster under the pressure switch cover- VERY HIGH VOLTAGES- RISK OF INJURY OR DEATH- UNDER PRESSURE SWITCH COVER WITH UNIT STILL CONNECTED TO POWER-
On the common switch used (A condore mdr 5) the differential is adjusted by DEPRESSING the nob & turning it.
On MDR 4 the adjuster is directly behind the high pressure adjuster. it is a flat bladed screw attached to a spring-screw in to increase cut in pressure.
You can also get pressure switches with a higher cut in pressure.
In Australia from a company called Ross Brown Sales in N.S.W
Hope this helps
Regards Andrew
Posted on Jul 18, 2010
  • 432 Answers
SOURCE: My compressor 2475 ir (5hp) has no dip stick or
In the owners information your compressor takes the 1 bottle of IR oil that comes with it. If you have a local tractor supply company or another company who carries IR you might check with them, it is the only oil i would recommend for your unit.
Posted on Jul 31, 2010
muthur85
  • 117 Answers
SOURCE: volume level display
install this launch manager software
its working
http://support.acer-euro.com/drivers/notebook/tm_540.html
Posted on Nov 07, 2007
  • 108 Answers
it sounds like your laptop drivers aren't working properly.. possibly the program dealing with your sound volume is corrupted or missing.
I'd try reinstalling your keyboard/touchpad drivers. what is the make and model # of your laptop?
Posted on Dec 28, 2007
I cant reset my service hours on my kaeser compressor
at service hours press and hold enter then password will be basic
Jan 16, 2014 | Cars & Trucks
I have a Toshiba SD-K730 DVD Player I am trying to set the Parental Lock limit what type of movies are viewed. Can you help?
Parental control setting
Some discs are specified not suitable for children. Such
discs can be limited not to play back with the unit.
1) Press C or D to select "Parental", then press B
or A until the level you require appears.
Level Off: The parental control setting does not
function.
Level 8: All DVD software can be played back.
Level 1: DVD software for adults cannot be
played back.
Select from the level 1 to level 8. The limitation will
be more severe as the level number is lower.
2) Press C or D to select "Password".
Press Number buttons (0-9) to input a 4-digit
password. Be sure to remember this number!
• If you input a wrong number, press CLEAR.
3) Press ENTER to store the password.
Note: Now the rating is locked and the setting cannot
be changed unless you enter the correct pass
word.
4) Press OPEN/CLOSE to activate Parental control
setting. (See "Temporary disabling of rating level by
DVD disc" on page 36.)
Notes:
• Depending on the discs, the unit cannot limit playback.
• Some discs may not be encoded with specific rating
level information though its disc jacket says "adult." For
those discs, the age restriction will not work.
To change the parental level
1) Press C or D to select "Password".
2) Press Number buttons (0-9) to enter the password
you have stored.
3) Press ENTER.
• The rating is now unlocked.
4) Press C or D to select "Parental", then press B
or A to change the parental level.
5) Press C or D to select "Password", then press
Number buttons (0-9) to enter the password.
Note: You can change the password if you want.
6) Press ENTER.
Now the parental level is changed and locked.
If you forget the password...
1. Press OPEN/CLOSE to open the disc tray.
2. Remove the disc.
3. Press OPEN/CLOSE again to close the disc tray.
"No Disc" appears on the screen.
4. While holding STOP down on the front panel,
press 7 on the remote control. "PASSWORD
CLEAR" appears on the screen.
5. Enter a new password again.
hope this helps
John
Mar 24, 2011 | Toshiba SD-K740 DVD Player
Error 5800
Here's the thing you can do.
1 press menu
2 PRESS scan copy scan to enter service mode
3 use > to go to NVRAM ACCESS
4 set ABS-M LEVEL TO 0
5 Set ABS P LEVEL TO 0
6 Set press STOP to EXIT
Hope it solves your problem thanks.
Jan 15, 2011 | Canon Computers & Internet
HOW TO SOLVE PROBLEM ERROR 5B00 IN CANON IP2770
You need to reset your printer.
(1) Press MENU
(2) Press SCAN COPY SCAN to enter service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
Nov 26, 2010 | Canon Office Equipment & Supplies
The alarm light is on and the message says check printer 5B00
Turn on the machine
(1) Press MENU
Nov 18, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Error 5B00 Canon MX308
The reset procedure (for canon MP130) is:-
Turn on the machine
(1) Press MENU
Hope this help for you also.
Oct 26, 2010 | Canon MX300 Office All-In-One Printer
Printer is saying waste ink absorber is allmost full/what do i do
You can reset the waste ink counter like this:
1 press menu
Jun 12, 2010 | Canon PIXMA MP130 All-In-One InkJet...
MESSAGE- DRAIN OR CLEAN INK RESEVOIR
1 press menu
May 10, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA iP 1500 does not print
1 press menu
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Reading multi zone DVD's
If you forget your 4-digit code
If you forget your password, to clear the current
password, follow the procedure below.
1. Display Setup menu then select an 1 level icon.
2. Use the Number buttons to enter the 6-digit
number “210499”.
3. Select [Yes] then press ENTER. The 4-digit
password is cleared. Enter a new code.
Mar 10, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Air Tools & Compressors Logo
712 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
