BACKGROUND HUM PRESENT AT ALL TIMES - Audio Players & Recorders
  • 1,583 Answers
There are a number of possibilities.
First, get an outlet checker from the electrical department of a building supply store (for the US electrical systems, it has three neon lights indicating normal, open ground or hot and neutral wire reversal). If one of the outlets you are using for your audio equipment is not properly wired, it could cause hum.
Second, disconnect external input devices one at a time (CD players, TV sound, cassette decks, etc., but leave the speakers connected). If the hum goes away with one of those devices, it may have a problem with ground isolation. Post back if you find this, and include brand and model number. If the hum goes away with the very last piece of equipment, and comes back with something else connected again, or is present with two particular devices connected, post back with details of the devices and how they are connected (both signal cables and power).
If the hum is still present with all input sources disconnected, it's time to check the power supply inside the receiver for failing capacitors or other defects.
Posted on Jan 03, 2011
    Scholar:
  • 85 Answers
What sources do you have connected to the receiver? The thing to do is to disconnect your sources one at a time and see if one of those eliminates that hum.
How to get rid of loud background hum when using phone
If your phone is a home landline the hum is probably due to a bad ground. You need to check Where the line comes in the house and ensure there is a good ground wire connected to the block.
Jan 08, 2015 | Lands Phones
Panasonic TH37PA50E 3yrs old In AV1 mode, disconnected from all video sources, scintillating blue horizontal bands slowly scrolling up the screen. Turns red when set to component video. When connected...
It looks like the TV might have retrace lines that are cause by a defective video amplifier IC, couple of fuse resistors burnt.
You might be able to make an adjustment to the blue screen voltage by reducing it slightly to get rid of the lines.
The devices that you connect to the TV have a different output and the TV is very sensitive to the higher video outputs from the DVD or any other device that you connect using the AV inputs.
Let me know if you need more assistance.
Apr 29, 2008 | Televison & Video
AKAI X-1810D LOW HUM WHEN RECORDING REELS
I am not an expert in the repair of Akai units- most of the time I refuse them, however just to put you on the right path, the hum is coming from a power supply issue in the record audio section or may be in the bias section. You may need to put new Electrolytic caps in the power supply to resolve this. You can also scope the supplies on this deck to find the cause. I commonly work on Teac, Pioneer, Otari, Studer, Sony and better made decks. Some brands are real trouble and are more costly to repair due to poor construction.
I have been doing repairs for 40 years so far.
Sep 05, 2012 | Audio Players & Recorders
Technics M14 cassette deck has hum. Bought used and had hum but I got it to go away by switching the tape select dial to metal,etc. but hum came back later. I'm thinking ground or a wire to that switch. ...
If the hum is audible without monitoring a tape playback it has nothing to do with the oxide formulation or any aspect of the media.
Determine the conditions present whenever the hum is present:
Player just turned ON?
Tape deck Playing or Paused?
Tape deck Recording or Paused?
"Tape" selected at the receiver?
Any source selected?
What switch are you referring to? You could have a floating ground or shield through a Tape Monitor or other control. Audio cables between the Deck and the receiver could be faulty or require reseating with a twisting motiuon to remove oxide build-up.
Hum can enter any unshielded cable running near any motor, magnetic field or some light sources. Sometimes simply reversing the polarity of an AC power cord will cure it.
Feb 02, 2011 | Yamaha KX-393 Cassette Deck Dual Cassette...
Satellite Pro microphone has hum in background when recording
Usual cause of mike hum is poor earth of screen in cable. Check connections between cable and earth pin or shell of plug. Don't make earth connections at both ends of cable as this will create a loop areal and pick up electrical noise.
You might also want to check for poor amp earthing. Normally moving close to, or touching, the front panel will reveal this problem as hum will reduce dramatically.
Sep 21, 2009 | Toshiba Audio Players & Recorders
Background hum
I fixed the same issue by replacing the original AC power supply with a 13.8 volt DC power supply (Radio Shack) It seems to be more consistent at high SPL and no hum , as the Boston acoustic unit accepts either AC or DC power.
Jan 29, 2009 | Boston Acoustics MediaTheater Computer...
2002 Accent Fuel Pump problems
I think that the 2002 accents still have a external fuel pump i would change that but to be shue it is a fuel problem remove the fuel line from the fuel rail and cycle the key on and off checking to see that there is no fuel spurting out of the line. New fuel pumps aer extremly quiet
Sep 29, 2008 | 2002 Hyundai Accent
Background "hum" in R speaker
Yea try plugging it into another wall socket, if it's still humming could be a damaged transformer. or bad capacitor.
Jun 05, 2008 | RCA RS2531 CD Shelf System
Background huming
How does it sound when you just play straight vinyl through your system? If you still get that hum, issue might also be faulty RCA cables, and even cartridge. So you would need to test everything out.
You don't really need a pre-amp unless you are connecting straight into your pc from your turntable. In that case, yes you will need a pre-amp, and this actually might be the cause of everything. If you are going into a DJ Mixer or a receiver, and your turntable is connected to the PHONO INPUT connection, you do not need a phono pre-amp.
Here are some inexpensive PHONO PRE-AMPS.
Hope this helps some.
- TWEAK AV LAB
Nov 25, 2007 | Audio Technica AT-PL50 Turntable
77 people viewed this question
 Grubhead
Grubhead
