Question about Panasonic PT-52LCX65 44" HDTV
HDMI stopped working tonight! I used an HDMI switchbox for years with this TV, but tonight it doesn't respond to any HDMI signals, even if I remove the switchbox and plug the sources in directly. If I plug in my cable box (Motorola HD PVR) or my PS3, the TV shows "HDMI" in the top left corner, but the screen is black and there is no audio. If I plug in my Xbox 360, I get the video, but no audio. All these sources work fine when plugged into another HDMI monitor. The TV works fine with other inputs (ie. Component, etc.). I tried the TV's "reset" options (both from within the TV's menu and the "VOL- and remote OK" method) to no avail. Why would the 360 picture work, but the picture doesn't work for the cable box or PS3? Please help! I need the HDMI to work. Greg
  • gsalter Jan 03, 2011
    No, I don't think that's correct. I just put in a second lamp (my old one that I took out when the LAMP replacement light came on a couple years ago, even though it worked perfectly), but nothing changed.
    Also, like I said, the TV works perfectly well on Component input, just not HDMI.
    And your solution doesn't make sense why the video works for Xbox 360, but not for the PVR or PS3.
  • brugal17
    brugal17 Dec 28, 2013
    hey Greg. i'm having the same problem you were having and was wondering how you were able to fix it before i go buying a new motherboard. Were you able to find a solution?
  • Panasonic Master
  • 11,800 Answers
The HDMI is a digital signal connector, in the tv is handled and decoded separately from the analogue connectors. Because of that the tolerances on the signal characteristics are much tighter so , if the chip is damaged even in the slightest way, it can no longer process the signal. The video from the Xbox is displayed because the signal generated there is most likely at the limits of the tolerances.
This is a hardware fault, that no reset will fix: the AV processor is faulty and the only way to fix that is to replace the motherboard.
Posted on Jan 03, 2011
    New Friend:
  • 90 Answers
You lamp in the tv is probally burnt out you can replace them though.
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
Feb 09, 2016 | Sony Televison & Video
How do I fix my new TV which will sometimes lock up and will not respond to some buttons on the remote or the TV itself?
it is under 1 year warranty from the manufacturer,contact them for repair,they will send someone to you
May 24, 2015 | Televison & Video
No Signal when HDMI connected with TV and cable box
Replace HDMI cable first, then check whether your box works on HDMI out. Try connecting box using other out (USB, VGA, DVI, DP, cable)
Apr 25, 2017 | Sony BRAVIA Televison & Video
Scott tv LCT37SHA. The hdmi input doesnt work. It doesnt recognize the signal. Is this a common problem. I tried everything.
I have this same problem as well, While i have not found a true solution i have found a theory as to why. I have 3 hdmi devices to the 1 port. The Xbox 360 hooked up to it works fine, however the dish and the ps3 do not. When run though a switchbox however i can get the Dish to work by turning on the 360, this trigers the port on and after its on i can turn the 360 off. however this does not work for the ps3. My best guess is that the TV is not receiving enough power from the cable (or sensing) to triger it to display the signal. Its just a theroy though
May 26, 2011 | Akai LCT3201AD 32 in. LCD Television
What do i need to buy to get it to work on my new tv
How to Connect Your Old Videogame System rca_cable.jpgIf you've just dug your old videogame system out of the attic, you might not remember exactly how to connect it. They're not quite like modern game systems, and may require something extra to connect it to that brand new TV you have. To the left is the cable you should see attached to your videogame system. It is typically called RCA, and you will have to use some sort of adapter before you connect it to your TV. While it looks like it should fit into one of the composite jacks (and it will actually fit), that will not work because the audio and video signals are being carried in the same cable. In order to use the composite jacks on your TV, you will have to separate the audio and video signals somehow (described below). The following instructions are relevant to most vintage videogame and computer systems that connect to a television. Specifically, the Atari 2600, 5200, and 7800. However, if you have the 4-port (four joystick ports) version of the 5200, you need a special switchbox. Try eBay or Best Electronics (catalog item) for this proprietary switchbox. If you have the 2-port version of the 5200, you can use the methods described below. coax_jack.jpg composite_jack.jpg Coaxial CompositeThe first thing you need to do is figure out what type of connection you're going to make. Look at the back of your TV and compare to the pictures to the left. It's much easier to connect to a coaxial jack, and this is what most people will do. Composite will give you better audio and video quality, but you must perform a hardware modification.
Coaxial
Coaxial (F-type) to Female RCA Adapter
Radio Shack part #278-276
Manual TV/Game Switchbox with Coaxial Output
300 to 75 Ohm Matching Transformer
Coaxial is by far the easiest way to connect your old game system, and the method most people will use. This is the 'cable ready' input that is found on every TV made today (and for some time now). If you don't at least have this connection, you have our sympathy. There are several methods you can use for this connection.
The best way is to get a Coaxial to RCA adapter (left). It is cheaper, smaller, and provides a better signal than the traditional TV/Game switchbox. This is a small plug that will cost you about $3 at Radio Shack. It is called a "Gold-Plated Phono-to-F Adapter" and the Radio Shack part number is 278-276. Just connect it to the RCA cable of the game system, then plug the other end into the coaxial ("cable") jack on the TV. Set the TV to the channel that the game system is set to (usually 2-4), and your're ready.
If you still have an old TV/Game switchbox and you don't want to buy something new, you can use that. You can also purchase these at Radio Shack for about $5, but if you're going to go buy something we recommend the adapter described above. Some TV switchboxes have built-in coaxial output, some do not. If yours does not, you will need to buy a 300 to 75 Ohm matching transformer (again, about $2 at Radio Shack). If you you do have coaxial output on your switchbox, just plug the game system's RCA cable into the switchbox, connect the switchbox to your TV's coaxial ("Cable In") jack, and push the switch to "Game" or "Computer". Note - you cannot use the 'automatic switching' boxes that newer game systems like the NES use - the signal in most old systems is not strong enough to trigger the automatic switching, so be sure you buy a manual switchbox.
Most new TV/Game switchboxes will allow you to connect your Cable TV and Videogame system at the same time, but the picture is often less than ideal. We recomend a coaxial selector - this will allow you to choose between inputs (game, cable, whataver) at the touch of a button. We found this one at Parts Express for about $6.
av_switchbox.jpg AV Switchbox
Composite composite_jack.jpgAny way you slice it, generating composite output takes more work. How much more depends upon exactly what you want to do. To get true composite signals, you will need to be handy with a soldering iron and modify your Atari 2600 internally. If you've never soldered anything before, it might be a little tricky, but it's worth it for the clean signals! You may also notice that modern equipment has left and right audio jacks - this is for stereo sound, but you can't get stereo sound from your 2600 unless you make further hardware modifications. So if you make the mod, you'll just have one audio cable in use. vcr_composite.jpgNow if you don't want to do that, but you're using a monitor or tv without a coaxial input (for example, a Commodore monitor), there are other options. You will still have to convert the signal to coaxial first (see Coaxial section). Then, if you have a VCR handy, you can run the coaxial connection into the VCR, and then use the composite outputs from the VCR. This will not give you the true signal clarity of composite audio/video, but it will allow you make that composite connection. If you don't have an extra VCR for this, you can probably go buy a junker at the local thrift store - the tape mechanism doesn't need to work, just the demodulator. Demodulator's rarely go bad on VCR's, they're usually thrown out because of the tape mechanism. Speaking of demodulators, you can simply use one of these instead of taking up all that space with a VCR. Unfortunately, these are much more expensive ($100+) and you're not likely to find one in a thrift. Unless you're going to make a hardware modication, we really recommend using a straight coaxial connection, because going through a VCR/demodulator defeats the purpose of a composite connection.
Feb 15, 2011 | Atari Video Game Consoles & Games
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
We recently got a Philips 42PFL3704D/F7 lcd tv. We have our computer hooked up to one of the HDMI channels, and we have a switchbox hooked up to the 'Component' channel. The switch box does TV and our...
I had this a issue with the Component input not working right as well. I had a repair tech come to my house to take a look on Philip's dime. Turns out it's the main circuit board. You cannot obtain this part from Philips. I've been in a fight with Philips to replace the TV. All this started in Aug 09.
Jun 22, 2009 | Philips 42PFL3704D LCD TV
PS3 setup/withHDMITV
1 cable from the PS3 goes to input 1 on switchbox 1 cable from directtv goes to input 2 on switchbox 1cable from output of swichbox to your tv.
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Panasonic PT-52LCX65 44" HDTV Logo
238 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
