Question about Zanussi Washing Machines
Washing mechine is not working with hot water
    Problem Solver:
  • 4 Answers
Hot water celonid needs replacing
Posted on Jan 03, 2011
Why there no water into my washing mechine..but its still working..just no water in
You could have a blocked pressure chamber, which if blocked in the full position would hold the pressure switch in the on position and the machine thinking there is enough water in the drum starts the wash. Although not a hard job it is not a job I would advise being done by a novice without instruction.
Regards
Casper
Feb 08, 2017 | Washing Machines
Is ther any way to test the water level sensor?
yes turn mechine off remove thin hose from mechine end blow up small tube switch should click twice then click same when mouth removed
Apr 21, 2015 | Kenmore Washing Machines
Samsung wt8202
Were did i get the front pannel in blue colour because my washing mechine wt 8202 drain knob is not working .Technician says change the front pannel board white colour is awailable but blue is not get yet.
Apr 05, 2012 | Samsung Washing Machines
Sir, panel is working but water is not taking drum is not rotate of my samsung Ag+ top loder washing mechin.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jun 28, 2011 | Washing Machines
My simpson encore 605 beeps when you press the start button buy no water comes threw. Water is on at the tap. Same if water is on hot or cold. worked last night then stopped today. can you help
problem was caused by lever mechinism under lid ,which pushes down safety lever inside top box behind electronic control pad. when lid is closed. Adjusted to suit , now machine is working fine.
Nov 05, 2009 | Washing Machines
MECHINE MAKES HUMMING SOUND, IT WON'T SPIN, WON'T
THe motor coupling or belt is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 08, 2009 | Kenmore Washing Machines
My washing mechine washes with only cold water
They make a Y or T-adapter so you could hook up the hoses (you;d have to pick up one for hot water) and then the other part of the attachment to the washer.
This is not exactly it, but it'll give you an idea of what you need to look for:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100485918
Feb 28, 2009 | Washing Machines
Washing mechine 1200 hoover
Hi, It sounds like it might need new brushes in the motor. Sometimes just before they wear down completely, they will wash but not spin, this is because the spin needs more power. Tom.
Mar 12, 2007 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
