Question about Frigidaire ATF6000ES Front Load Washer
My washer goes all the way thru a wash cycle n at the end it gives an err E20...n the clothes r still soaked with water
Its not draining the water properly,do u have a water drain any were if so unscrew put towels on floor and drain out
Posted on Jan 03, 2011
Is Whirlpool AWT 5108 only a washing machine or a washing machine with dryer?
Washing machine usually have different wash cycles you can chose from. The washing machine should go into a spin mode to get most of the water out of the cloths at the end of the wash cycle. You might try another wash cycle on the washer and see if the washer goes into spin mode and gets most of the water out. If it goes into spin mode on one cycle and not another my experience has been it is the timer which is part of the switch where you chose which wash cycle you want.. My experience is only working on my washers and driers of the last 40 years. I have washed cloths with what ever cycle worked till I could change timer.
Nov 19, 2017 | Whirlpool Washing Machines
How much water do I use when using a front loader say 5 items of clothes with 3 large towels and two sweater
many front loader washing machines don't have different water level options since they cycle the water differently than the "tub-o-soap" upright washers. The best answer I can give, if there are different fill settings, is to put the laundry in the machine and see how full it looks. Err on the side of overfilling, since the towels will soak up a lot of the water, and unless the sweaters are delicate or inclined to stretch out badly, I'd opt for an extra spin cycle to get rid of the excess water soaked up by the towels and sweaters.
Mar 21, 2011 | Washing Machines
Cycle stops and shows error E20. Cylinder hold water and does not drain or complete cycle
E20 is a draining error.
Check the filter.You need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out.
If still the problem persists then the problem is with the draining pump.The pump is not pumping out the water.Check the pump impeller it may got stuck due to some obstacles.Replace it and this wont come again.
Sep 16, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
ZANUSSI JETSTREAM, CODE E20 appears with every wash near the end of cycle
If still the problem persists then the problem is with the draining pump.Replace it and this wont come again
Thank You
Sep 09, 2010 | Zanussi Washing Machines
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
Drying cycle malfunction
Unplug the dryer and replug back up again.
Put on wash /let it go thru the cycles.
Nov 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
