Question about Sunpentown Heating & Cooling
I have a sunpentown technitrend tn-12e ac unit, recently when I press the power on, I just get a beeping sound and the unit won't power on. What's the problem?
2 Suggested Answers
  • 10 Answers
SOURCE: Light flashes red at Portable A/C unit
drain system clogged or condensate pump no good
Posted on Sep 01, 2009
Testimonial: "The condensate pump was jammed and causing the water to rise in the tank and thus safety shut-off of the A/C unit. Freed up pump & cleaned water tray."
How much water do I need for the air conditioner
I've never seen an air condition device that needs to add water to work. Actually they RELEASE condensation water and you need to collect this water or drain it through a tube
Jul 20, 2015 | Sunpentown Spt Tn-12e Technitrend...
How do I troubleshoot this unit to see why it is not working?
First check the box were the water goes. Not sure if you have a hose going out the window with the plastic hose the air conditioner will not work when the water bucket is full it should have a light on the front of the machine that shows you.
Jul 08, 2014 | Sunpentown TN-09E - Technitrend Portable...
My m/b is Compaq BL30G and recently i had to reinstall winXP and it automatically installed audio driver (intel(r) 82801BA/BAM AC`97) but now it gives a continues "beep" sound. I even tried...
First of all open your chassis and then reconnect all the connection and remove hard drive. If you have two RAM in your PC then remove one RAM Now plug the power supply and ON the machine. If it is giving beep sound then press esc again and again untill the beep sound could be stopped. If it is continuous then remove the RAM and fix the other one then ON the machine And if it is giving beep sound the press esc again and again. Before fixing the RAM you have to clean the RAM with a soft cloth smoothly. I hope this can work for you ! and beep sound is stopped then attach your HDD then ON the PC
Sep 14, 2011 | Abit BL7-RAID Motherboard
My Sunpentown WA-1210E airconditioner stopped working. It emitted several beeps and the power light is blinking continuously. When I unplug, wait a few minutes and replug in the unit, it shows the same...
Have you checked the water container in the unit? It has a float switch that when it is full it will not allow the unit to run so that it will avoid spilling water on to the floor. Hope this helps 2rns4u <*{{{>(
Jun 29, 2009 | Sunpentown WA-1210E Air Conditioner
Recently moved from CA to TN. My Brother IntelliFAX 770 plain paper is not responding at all - no phone, no on screen display of any kind. My name is Diane Hartley, Phone: 731-989-8393, email -...
Welcome to TN, Nahsville here.
Sounds as if you do not have power to the unit.
Did you try another outlet?
Do you get and noise, if the unit is trying to inialize?
(basic questions ,but need to know to try to figure this out.)
Here is the User manual:
http://pdf.textfiles.com/manuals/FAXMACHINES/Brother%20IntelliFAX%20770%20Home-Office%20Fax%20Machine.pdf
let me know, Joe
Oct 05, 2008 | Brother Office Equipment & Supplies
Help
go to sharpusa.com and click on support, they have all the model airconditioners and all the help. its in pdf format and i dont know how to paste the info. really easy problem to fix.
Basically, tells you to make sure air filter is clean.Unplug from wall, then hold Power/on/off button down and plug unit in wall. press Power/on/off button until you hear a beeping sound(approx 5 sec) then disconnect powerplug from wall. plug back in and start your ac again. it should work!
If this dont work try the same thing but by pressing the Mode button and same kind of operation as above, but the unit will start to operate after you press mode and herar the beeps. turn off by pressing On/off button. then start as normal. if you cant get it go visit the website.
Jul 16, 2008 | Sharp ENERGY STAR AF-S60FX...
Wont turn on just keeps beeping
Hi, I posted the same problem. I unplugged the unit overnight, and now it works. don't know if this will help, but it works!!!! :D
Jul 04, 2008 | Sunpentown SF-610 Portable Air Conditioner
Heating & Cooling Logo
56 people viewed this question
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Pete Norton
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
