Question about Siemens WFXD5200UC Front Load Washer
Dimension size for the ducting. - Siemens WFXD5200UC Front Load Washer
  • Siemens Master
  • 17,130 Answers
If you want the drain to be ducted the measurement is about the size needed for the drain pipe. Normally a duct with an OD- outer diameter -of about 3 inches should be sufficient to plug in the drain hose .
Make sure your drain hose fits into the duct as you can buy one with the drain hose taken out to sample.
Posted on Jan 03, 2011
What make of furnace would fit in the existing hole , duct fed air
talk around with dealers who supply that sort of equipment as there will be a variety of sizes made by different manufacturers that will be close to the dimensions that you have
get quotes and check for warranty aspects of any machine you decide on
Jul 18, 2015 | Cars & Trucks
What size furnace do I need to replace my old lenex model number g20qq3 4G 125 4
If we're talking physical size, modern units won't be the same, you could essentially look at any manufacturer's dimensions and see what gets closest. For BTU's it's better to base it on the size of your duct system. Generally, or just unprofessionally, lets say 8,000 btu per register. If you have 10 registers in the house, an 80kbtu unit would do nicely. 16 registers - 120kbtu. They max out around 150kbtu. However, I highly recommend you have a professional do it all. If you do something wrong, you could very easily kill yourself or anyone in the house. The risks are huge; installations should be done by licensed contractors under a permit. Plus, contractors should know all of the new energy saving tricks, they could save you tons by changing your system altogether.
Apr 10, 2014 | Heating & Cooling
I am trying to determine the duct size for my new AC Goodman 5 ton unit. the unit is a package system, GPH1560M41A it is a 34,100 BTU unit. The home is a Mobil home 2,280 sq. ft. I am looking for the...
Its a bit more difficult than just the duct size, are you going to take it to other rooms? ect.. My advice is have it designed for the space.
Aug 04, 2011 | Heating & Cooling
How to properly size a duct return in a house
To size that return duct you need to know the cfm of the unit, and size according to that...Ell's and distance also need to be factored in....
Here is a free duct calc. that you can use to help you size you ductwork...
Here is a website that will let you get a free trial duct calc.
http://efficientcomfort.net/Calculators.html
Here is another free duct clac...
http://duct-sizing.downloadsoftware4free.com/
Heatman101
Sep 21, 2010 | Coleman Heating & Cooling
Reinstall RANGE HOOD from non-ducted to ducted
You need to uas a 7 inch duct to duct it out. You can get all the info you need in the manual on the link below. Please give it some time to load. If you need parts you can call Sears at 1-800-4-MY-HOME.
http://www.managemylife.com/mmh/owner_manuals/2285/KENMORE-Range-Hood-L1002022?brand_name_search=233.55213.000+
Good Luck and please rate 4 thumbs up for the free answer
Aug 01, 2010 | Kenmore Kitchen Ranges
Calculation of CFM discharge from an opening of a duct collar
There's a thumb rule in A/C air distribution. At 1 TR load, the air supply is about 400 CFM and the ideal diffuser size is 16" x 16" with an effective flow area of about 70%. Branch duct size for this outlet should be around 12" x 12".
Jun 20, 2009 | Carrier Heating & Cooling
Extraction ducting too long!!
To get the correct dimension, you could make up a template out of thin carboard to do your testing before you cut the metallic duct.
You will need to match the area of square inches of the duct, no matter the shape. If it's round the formula is (pi (3.1416) x radius squared). If it's square or rectangular, it's L x W in inches. Your local home improvement store (if there is one) should stock various adapters and metallic round duct.
Note that since this is being used in a kitchen, the duct should be metal and it should vent to the outside unless it is a recycle hood.
Let us know if that helps...if not we'll try again!
Jun 06, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
Crossover duct for model C3QA-042U intertherm
The opening for the coil for your coil is 18 1/8" by 18 7/8". The ducting will have to be removed and measured. The strapping you have mentioned is easily replaced and can be bought at Home Depot in the plumbing section where all the duct work is. Your looking for duct ties. They are essentially large zip ties. Don't be scared about cutting it off. You can tape the core back onto the start collar for a temp measure anyway.
Apr 10, 2009 | Intertherm P3RA-048K Air Conditioner
Need the cubic inches for the return air duct
For proper minimum opening you need to do duct calculation. This is not a typical math equation for the typical homeowner. And unfortunately alot of contractors do not take the time to calculate this.
If you insist on doing this yourself...... I would recommend the largest opening that a common filter will fit. probably 20" by 25". Going to big on a return air will never hurt. But going to small will.
20" x 25" will work safely 95% of the time. But... If you are running airconditioning that is 5 tons in size, you will need the design a return air system that will feed from BOTH sides of the furnace.
If you are just sizing the trunk line you should use a ductulator to calculate the minimum size. A good rule of thumb would be to size the "return air" trunk 1 - 1 1/2 times the size of the supply trunk line.
Mar 01, 2009 | Goodman GDS80904BNA Open Flame Heater
Siemens WFXD5200UC Front Load Washer Logo
298 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
