Question about Canon CanoScan FB630P Flatbed Scanner
CanoScan Fb 630 P flatbed
Lost my drive and my computer request for driver to run the scanner on window XP. please send me the drive
  • 3 more comments
  • Anonymous Jul 25, 2008
    I lost our driver and want to install the driver.
  • zcm788 Jul 31, 2008
    lost driver for Canon CanoScan FB630P
  • Anonymous Aug 18, 2008
    cannot run the scaner
  • waterloo6688 Aug 18, 2008
    scanner cannot run
  • Micky48 Aug 28, 2008
    I change my C and now I want o reintall the scanner and I lost the divers I had and want to obtain a new one to slve the problem ¿could you help me please?
    This is from Peru, and my name is Luis Miguel Dellepiane and my email: lmdellepiane@gmal.com
    Thank you,
    best regards,
    Luis Miguel
    President:
  • 1,114 Answers
Hi - You can download the software from the link below:
CanoScan Fb 630
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 09, 2008
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Need drivers
there is no driver yet for windows 7.but download scan gear and scan gear toolbox from here:http://software.canon-europe.com/products/0000473.asp  open properties,compatibility and run it in compatibility mode for xp sp2
Feb 28, 2010 | Canon CanoScan N650U Flatbed Scanner
Can CanoScan be installed on two computers?
Most scanners including all-in-one printers can be shared acrossed a network. Hook up the scanner to one computer. At that computer, go into the control panel and to scanners (XP that would be printers and other hardware and then scanners). Right click on the CanoScan and click sharing. You can assign a name to the device. Go to other networked computer and add the device. You should be given an option to locate device on a network. Install the same driver and software you want to use with scanner.
Note: I'm not a Mac user, I've given instructions based on Windows XP/Vista. But, process should be similar.
Oct 19, 2009 | Canon CanoScan 4200F Flatbed Scanner
Canoscan Lide 30 - want to use on laptop running XP Pro
Did you restart your computer after you downloaded your drivers and software? Did you select the correct operating system? Make sure the USB cable is plugged into the computer and the scanner...Open the toolbox and click scan or save and check to see if the scanner makes any noise or lights up...If you are using Windows XP then make sure you have downloaded the "TWAIN" driver and the "WIA" driver (two seperate downloads)
Jun 30, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Downloading driver for canscan FB 630U on Window XP
You can download the driver from the following link
Description: Canon CanoScan FB 630U driver for Windows 95/98/ME/NT/2000/XP Download Driver Updater Pro to get the most current drivers for your computer.
I hope this will solve your issue.
Good Luck
If my solution proves useful please accept it.
Regards
Arjun
Mar 29, 2009 | Computers & Internet
NEED DRIVER
CanoScan LiDE25 Drivers & Manuals from Official Webpage Click Here to go.
Before downloading the drivers please choose the Operating System.
Thanks & Regards
Nandu :)
Mar 24, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
I'm interested in buying a Canon CanoScan N656U flatbed scanner but worry it won't work with my laptop. I've got a Dell Inspiron (can't remember model no.) running Windows XP. This scanner's system...
It will work fine with Xp but, not Vista. The user can download the appropriate driver update for XP on the Canon website under the support tab on the main website. this printer will work with XP. It will not work with vista.
Mar 16, 2009 | Canon CanoScan N656U Flatbed Scanner
Canon CanoScan 3000ex. (Scanner)
kind of,if your pc is compatible,i just installed windows 7 x64 and had the same problem,but i installed virtual xp mode and i was able to install the drivers for my 3000f and i can use the scanner againin widows 7 x64.good luck.
P>S: windows 7 is free till next year (march) ,not all processors support "xp mode",i was using vista 32 bit before,make sure u update your bios to the latest,i did cause before it wouldn't run
Dec 25, 2008 | Canon CanoScan 3000ex Flatbed Scanner
TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Aug 04, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Canoscan fb 30u and vista
Just visit the following URL to download the VueScan 8.5 which will resolve Vista driver issues with a lot of flatbed scanners including CanoScan FB 630U.
http://www.hamrick.com/files/vuesca85.exe
Apr 21, 2008 | Canon CanoScan FB630U Flatbed Scanner
Canon CanoScan FB630P Flatbed Scanner Logo
765 people viewed this question
old marine
old marine
