Question about Carrier 38CKC036 Air Conditioner
I have got a carrier 38GF004930 air conditioner at home, the condenser fan stoppes running after about 5mins,i had to change the capasiter the previous one had rusted though at the bottom and all the liquid had run out.
  • irvineellis Jan 04, 2011
    I have changed the capacitor with a 30 m/f i do not know what is the proper one as i do not have a manual for the air con as the old one was very rusted.When i check the fan when it stops it is not hot and the blade run,s freely.
    Genius:
  • 1,400 Answers
Hello
Could be a bad low pressure cycle switch causing it to shut down after 5 min.Try jumping the switch and see what happens.
Another possibility is a bad fan contactor,if the contacts are burnt or pitted they will heat up and shut down on high heat.Have a look at the contacts replace if need be.
Posted on Jan 04, 2011
  • Carrier Master
  • 17,130 Answers
Make sure that the capacitor that was changed is of the same type and rating. If this is low then the fan can flutter off. So make sure the rating of the capacitor is correct , if not replace with a correct type. Make sure that the motor is not jammed, as it might heat and stop. Also the possibility of the motor failing should be checked if the motor is heating to stop- possible fault of the motor.
Posted on Jan 03, 2011
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
Carrier package unit. 48SS series. Condenser fan continuously runs even when T-stat is off.
The one side of the contacotr in the condenser electrical box is welded closed...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 08, 2010 | Carrier 38CKC036 Air Conditioner
Carrier outside unit not starting and is very hot
Either the condenser fan is not working and it has shut down on high pressure... or the compressor is locked up and trying to run and is making the heat...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 13, 2010 | Carrier 38CKC036 Air Conditioner
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
We require condenser fan motors for Interclisa Carrier package (rooftop) air conditioner model AAD 250 (1980's model) model. Air conditioner - supply voltage 380 Volts 50 Hz AC. Condenser fan motor voltage...
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Jan 21, 2010 | Carrier Heating & Cooling
Outdoor unit compressor when stareted up carring high amps with out changed from start winding to run winding .
There should not be a change from start to run winding on this unit. If it is running high amps (how do you know this? ) and the fan is running and clean condenser you probably have a failed run capacitor.
Jun 29, 2009 | Carrier 38CKC036 Air Conditioner
Evaporator fan turns on. compressor and condenser fan do not turn on.
Sounds like low on refrigerant charge. Low pressure switch keeping the compressor and condenser fan from running.
Jun 05, 2009 | Carrier Heating & Cooling
Air conditioner fan problem
Take a brush and clean it, then oil it.
Jun 01, 2009 | Carrier Heating & Cooling
MODEL # CARRIER 38XD124300
sounds like you had a condenser fan replaced ok you just have verify if the fan is a reversible one there is like a plug type connector on top of fan all you have to do is swap the position of the plug ex. if black / white to white/black that changes the rotation. check against the diagram it should be for the CCW position.
Apr 20, 2008 | Carrier 38CKC036 Air Conditioner
Carrier 38CKC036 Air Conditioner Logo
41 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
