Question about Sharp LC-32D41U 32 in. LCD Television
Screen goes black but sounds continues to work. what to do?
Samsung lcd tv has sound but no picture. Samsung TV works for about 10 minutes then screen go black but sound continues
Use a flashlight on the screen when it goes black. If you can see a faint picture then the board that controls the back light has gone bad. If you see no picture then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix the TV yourself. It's not that difficult.
Mar 13, 2016 | Samsung LN40B610 LCD TV
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
Lap boots up, shows dell logo then screen goes black but runs.
ur unit is overheating turn off and unplug and let cool down,clean vents around fan intake (under unit) and around top each side of keyboard when cool enough plug back in and listen for fan operation while booting up if no fan it may be stuck or burnt up and may need replacement but ur biggest problem will be the hard drive if it was overheated for to long could or is damaged good luck hope ur lucky and that it just got hot
Dec 05, 2009 | Dell Inspiron B130 Notebook
The screen goes black while playing.
It is nothing just hold your on button untill it turns off again hold it again but nou it will make a sound keep holding your finger untill it makes the sound twys in a rowe take your finger of and in about 5 sec a screen will apear say restore sestem if it's not working the first time do it again untill it work's 100%.HOPE I WAS USEFULL PLZZZZ RATE ME O JHE SORRY FOR ME SPELLING I AM ONLY 13 AND AFRIKAANS if u want some more answer about ps3,2 or 1 or any network or PC problems email me to markusmaritz@yahoo.com i even do DVD player so lpzzz rate me and if there is anything els plzzzz email me i will help...
Nov 17, 2009 | Sony Playstation 3 (PS3) Console
Sometimes the screen goes black and will not work
the video/graphics you opened is too high where the video card of your unit cant handle it which turns into overdrive. upgrade your video card if necessary
Oct 10, 2009 | Sony DVP-FX810 Portable DVD Player
Screen still goes black and gets worse when adaptor is plugged in
That sounds like a hardware issue, not driver related at all. You could try doing a system restore to when it did work, but that probably won't help.
I'd suggest opening it up and reseating the plugs to the lcd panel, but anything more than that gets complex very quickly. It could also quite possibly be an LCD inverter problem, in which case your laptop needs to go back to the manufactuer to get fixed. (You "could" look for a new one on ebay and install it yourself, but that's very tedious, and kinda risky if you haven't done it yourself before, and I'm not about to help a rookie break a laptop that's already in rough shape.)
Dec 15, 2008 | Dell Inspiron 6400 Notebook
Sharp LC-32D41U 32 in. LCD Television Logo
37 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
