Question about Levelone Level One FreeCon 802.11G Outdoor WAP 108 Mbps (WAP-1001)
I cann't login to my level one wap 1001 router wireless Admin password not loging
  • 108 Answers
Try this, user-name admin password admin.or user user
Posted on Jan 03, 2011
Why i cannot factory reset username, password and ssid ap? and i just can factory reset ip ap
What are you connecting the wap-1001 to? An existing network . Does the subnet mask match it defaults to 255.255.0.0
if the p.c you plug directly into the ethernet connection of the ap has a different subnet mask it can't talk to the router. how does your p.c get its ip address is it static or dynamic via dhcp server . ip is default of 192.168.1.20 also is anything assigned 192.168.1.20 .
http://download.level1.com/level1/manual/WAP-1001v1.02_UM.pdf
the default password and user name is in the user manual
Jun 17, 2015 | Levelone Level One FreeCon 802.11G Outdoor...
I can't connect to my internet. I don't know the correct password.
You will need to login to your wireless router to get, or set, your network password. A typical default router IP address is 192.168.0.1, but there can be any number of possibilities depending on router type, and network configuration, and who set it up... Some routers will put their default IP Address, and password on a sticker, located somewhere on the router. If this is the case, type the default IP Address into a browser on your computer, and hit enter, or return. A web page should appear asking for login information. User name, and password. Again this information varies... Typically the default user name is "Admin" or "admin" you can also try leaving this field blank, and just entering the password found on the router. In some cases the password is actually "admin" while leaving the user name blank.
If your successful at loging-in, you need to look at your wireless settings, under one of the sub-tabs you should find a password field indicating your network password. This is what should allow you to login to your network with your Roku device.
Nov 17, 2014 | Roku 3
Wap-1001 has no reset button. How can I reset to default settings without login in. I forgot Admin password. Thanks.
Its easy but you have to open the unit. Undo the 6 screws holding the base one
Slide out the internals
You will see spot on the board labels SW for switch but no switch soldered to it.
While the power is on, use a wire to short the 2 contacts of the switch that stand out alone. IE. not the 3 together. Hold this short on for about 5 seconds then the led should blink
Presto!
Its now back to factory default 192,168.1.20, User name is "Admin" and leave password blank as per the manual.
Dec 23, 2011 | Computers & Internet
Software to rest wap 1001 to default
"Its easy but you have to open the unit. Undo the 6 screws holding the base one
Presto!
Its now back to factory default 192,168.1.20, User name is "Admin" and leave password blank as per the manual." -fixyaMarkoa34a5098-f669-488f-a6a9-3f02c825de75.jpg
Nov 11, 2011 | Levelone Level One FreeCon 802.11G Outdoor...
Gmail.comi forget password wep-1001
Presto!
Its now back to factory default 192,168.1.20, User name is "Admin" and leave password blank as per the manual."-fixyaMarko6b1bc267-b1e9-46c6-83c5-0f9087420f37.jpg
Sep 11, 2011 | Levelone Level One FreeCon 802.11G Outdoor...
How can i change the password? the problem is i forgot my old pass work.....
Hi
Which password for login password or security key. if you forget the login password then you reset your router and put the password admin, and if you forget security key then lo problem login and open the router go the wireless setting and change WAP or WPA1 what ever you select your pre shared key.
Jun 02, 2011 | D-Link DIR-615 Wireless Router
Reverted to factory default, typed in router name and wap password, but cannot acces, it goes to dlink
you need to reconfigure the wireless settings since you reset your router to factory defaults.
login to your router with admin/admin as the login/password
click on wireless settings and enable wireless security mode to wpa and type in the wireless password you wish to setup.
all wireless devices will need to be setup to your new router settings.
May 22, 2011 | D-Link DIR-615 Wireless Router
I forgot password and want to reset to factory default ... I can't seem to logon to my level one wap 1001 ap. I can't seem to logon to my level one wap 1001 how can i reset password or factory defaults
thanks, I open it and I short 2 contacts [sw1] but after4 shorting its changing the IP only 192.168.1.20 but may be the name and password remain same, bcoz i try to login with defaults user name : admin and password : balck but its fail.
so can u help me to reset it again ?
thanks
Nov 26, 2010 | Levelone Level One FreeCon 802.11G Outdoor...
Need to place password on wireless router. help! Router already in use for a while. just learned that i need a password.
goto router ip
192.168.1.1
admin login
admin :blank
password:admin
wireless setup
wireless security
enable wep wpa
wep 10 digit
wap 8 alpha numeric
Apr 29, 2010 | Linksys Wireless-G WRT54G Router
Wireless computer
Open your web browser and type the IP address of the TEW-450APB in the address bar. The default IP address is 192.168.1.1. At the login, enter your username (admin) and password (admin).
The default IP is 192.168.1.1 and not 192.168.1.100 as you have entered.
Apr 18, 2009 | Zyxel ZyWALL 10 Router
Levelone Level One FreeCon 802.11G Outdoor WAP 108 Mbps (WAP-1001) Logo
408 people viewed this question
Top Levelone Computers & Internet Experts
micky dee
Prashant M
Prashant M
Are you a Levelone Computer and Internet Expert? Answer questions, earn points and help others
