Question about HTC G1
My phone will not work at all! When I try. To charge the battery it keeps showing battery chaging 0%. Now the screen will not even light up at all. The phone is not geting any power at all. I used the battery from my other g1 phone and it still did not work. I also used the phone charger from my other phone and that did not work either. Please help!
  • 2,133 Answers
Pleaae take your phone to service center, as softttware problem in cell.
Posted on Jan 03, 2011
Nokia 6300 charging not supported
When your phone shows charging not supported. First, you need to try a another battery on the phone, if it says the same thing, then try to use another charger, and if it shows the same thing, then you need to fix the charging port of the phone.
Before you do that, test, your battery and charger on another phone to see what happens, if they both work fine, then you need to fix the charging port of the phone.
Take care and good luck
Oct 13, 2010 | Nokia 6300 Cellular Phone
I have htc p3300. once started charging its get switched off automaticaly
does the charge light stay on (orange led) on or does it go green or flash on-off orange?
could be battery issue..
on the charge slot on the bottom of p3300 there will be 2 bins left and right inside. try bending them slightly - ONLY slightly tho incase it snaps.
use a needle.
its wat im doing at the moment, im currenlty trying to figure this out so ill keep you informed if i find the soloution.
atm i have to have my phone on charge to use it, otherwise it just goes off but thats how im getting it to charge atm.
if im not in touch..
raving_nanza@hotmail.com
Oct 28, 2009 | HTC P3300 Smartphone
Why does my phone not charge it has a red light on at the back
remove the batteries and put it again to reset the power.
Jun 15, 2009 | Sony Ericsson W890i Cellular Phone
Blackjack just wont chage at all
Do a master reset of the phone. Sounds like a software problem since both the usb and power jack not working.
  1. Once the handset has rebooted to the Today Screen, enter the following code: *2767*3855#. The handset should display a message “Formatting- Please wait a moment”.
  2. The phone will reboot after the Full Reset as this is normal operation.
Apr 28, 2009 | Samsung Blackjack SGH-I607 Smartphone
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Feb 20, 2009 | HTC P3300 Smartphone
Not chaging
Maybe the battery is completely depleted. Keep charging it for bout 4 hrs and check
Aug 18, 2008 | Motorola Mobility RAZR V3
Discharging
sony ericsson battery chages time 1.30ho
Dec 26, 2007 | Sony Ericsson K750i Cellular Phone
Motorola razr v3 white screen problem
try the new battery, but be sure it the right battery and fully charge V6.0 or higher. if no change, than you may have damage on the inside from the liquid discharged (short)
Nov 30, 2007 | Motorola Mobility RAZR V3
My phone will not show it charging and will not turn on, red light flashing
dear
you have mentioned that ur phone is charging and not getting on. that means ON\OFF path is having problem .due to dry solder of ON\OFF switch its happening. please resolder it and then check it
Nov 06, 2007 | Cell Phones
HTC G1 Logo
43 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
