Question about GE 15.7 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White
Model number of my GA fridge is GRT11AAPAPWW A loud 'burring' type sound was emanating from the back of the fridge and the freezer was starting to gain temperature. I adjusted the colling know away from the 'Coolest' setting and that shut off the loud 'burring' sound and the freezer started to lose temperature again. Two days later there is still no burring sound however the freezer is gaining temp and the stuff in there now has defrosted. Can you advise if this is a fixable problem ?
myob247
  • 1342 Answers
SOURCE: GE Profile- Freezer/ Fridge at 56 wont go cooler!
More good into HERE
Posted on May 03, 2008
SOURCE: GE PCG23NHMF side by side fridge freezer - stopped cooling
Although this machine is supposed to be frost-free (i.e. automatic defrost), there was a build up of frost. We manually defrosted the machine, then restarted it - the noise has stopped and the freezer and fridge are now working. However, this may be a temporary solution.
Posted on Jan 19, 2009
SOURCE: Evaporator freezing up, refer side.
There is a blanket type of heater stuck on the wall behind the coils.  However,  my tech guy checked the heater in our fridge, and he said it was ok.  The problem seems to be that the sensors and main circuit board do not turn the heater on - this is an inherent design flaw, and may not be able to be fixed.  There are 100 complaints about this this on consumeraffairs.com (usa),  and tons more in England.   This a very large problem which Samsung does not want to address, probably because of cost.  I'm seriously thinking about taking them to small claims court.
Posted on Jun 08, 2009
  • 15 Answers
SOURCE: Samsung fridge, Model#RB215LASW/XAC has defrost
Here's a link for the service manual....This is a complex device....
Kinda like a Prius....
There are tests modes and you can pull the error codes and force modes...
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Posted on Apr 12, 2010
aasc
  • 1606 Answers
SOURCE: fridge broken, freezer is temp. that fridge should
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . ( If you notice your compressor is not running before unplugguing the blue plug , then jump wire1 to wire3 to see if the compressor runs . If so , then the main control board is bad . Plug the refrig back in to see if compressor starts with the jumper wire in place , ) . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Posted on Jun 27, 2010
Ice build up in LG frost free american freezer
You have a problem with your auto defrost system or someone did not get door shut all the way
Jul 14, 2014 | LG Refrigerators
Very noisy fridge, back wall freezing up
Possible bad freezer fan motor. I need more information such as brand and model number
Mar 10, 2014 | Samsung RS2630WW Side by Side Refrigerator
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
My fridge/freezer work bur aren't cooling properly
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
I have a ge sisde by side model#gss25rgma ww. the fridge/freezer is working good, but now not making ice, it has started to make a really loud humming type sound if the doors are left open to long than...
Sounds like a evaporator fan motor problem. However remove rear panel and if slight frost on top of evaporator replace motor if not post back or call professional
Oct 02, 2017 | Refrigerators
Kenmore Freezer on Bottom Fridge
The number you listed is an item number used by the store and is not a model#.. The model sticker is usually located on the right wall inside the fridge and can sometimes be on the ceiling as well as under a drawer if it is a built in. They look like this and I would need the complete number to look at what you have.
I can say that if it is loud and you do not see anything around the fan blades.. You unplug it then plug back in, watch the fans start and a minute later is when it gets loud then that is the compressor. It is a very expensive fix and is rarely worth it.
Jan 06, 2018 | Kenmore 63822 / 63824 Bottom Freezer...
Loud shreaking sound coming from Kenmore Frost Freezer.
The fan behind the molding is hitting some ice build up and causing the sound. Sounds like the timer for the defrost isn't working. Try to turn off the unit for few hours or take off the molding in the freezer compartment and remove the ice build up with hair dryer.
Nov 23, 2008 | Kenmore Freezers
GE 15.7 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White Logo
26 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
