Question about Toshiba Satellite L500 Series Notebook
Hi mate.Got a virus On windows 7 on my Toshiba P500 sat.Have tried the zero key and power button,but wont go to full reinstall.Want to get rid of the lot and take it back to factory settings.
  • Toshiba Master
  • 4,806 Answers
The only way to restore without purchasing a Windows 7 disks is to perform the 0 key restore. Try it again using the following proceedure>>>>
ALL DATA WILL BE ERASED ON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THE POWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURING THIS PROCESS.
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
5) Select Recovery of Factory Default Software; click Next.
6) Select Recover to out-of-box state. Click Next again.
7) Click Next to Start recovery.
If this does not work you may have to purchase a Windows 7 disk.
Good luck.
Posted on Jan 03, 2011
I hhave a toshiba sat and it wont get out of the boot screen. Windows wont load. I dont have a windows cd
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Jan 29, 2013 | Toshiba Satellite Computers & Internet
Bios Problem
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jul 30, 2012 | Toshiba Satellite A660-ST2N02 Laptop...
Toshiba l455D
Sounds maybe like the hard disk drive has become corrupt. Maybe try to reinstall windows if you have the discs. However, if you don't and cannot boot to windows successfully you may have to check with the manufacturer, Toshiba in this case, to see if they can be purchased or sent to you for free. If the hard disk drive is found to not be format-able or the discs don't work for reinstalling windows, then a new hard disk drive is indicated.
You may also try to restore the windows using a backup copy that was made before. However, if you were not backing up your windows image on a regular basis, this may prove to be futile.
Dec 09, 2011 | Toshiba Satellite L455D-S5976 Notebook
Toshiba tellite L500 - comes up startup repair. indows cnnot repair this computer atomatically. Please can you tell mwhaaaais wong. Marie
Windows has been corrupted by a virus and you must reinstall it.
Press and hold "0" (zero) key on your keyboard and then depress the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility Screen will appear, presenting 3 options, just choose Restore Original Factory Image.
Jul 10, 2011 | Toshiba Satellite L500 Series Notebook
How do i reset my toshiba satellite A135-S4427 to when i bought it
This should work on every recent Toshiba laptop (). - Start with you laptop turned off.
- While holding down the 0 (zero) key tap the power button.
- When you hear a beep, release the 0 key.
- select Yes to continue with the system recovery.
- Select Recovery of Factory Default Software and Next.
- Select Recover to out-of-box state and Next.
WARNING: the procedure will delete all data on your hard drive!!
Feb 28, 2011 | Toshiba Satellite A135-S4427 Notebook
I have toshiba laptop satellite l650-15g core i5 is working to slow like Pentium 2 every think is opening to late please help me fast
use these steps:
1- reinstall your operating system (OS).
2- after the OS installed , download and install a powerful anti virus(with latest updates) (like NOD32 ANTI Virus or Kaspersky etc)
3- start a full scan (in anti virus options).
4- reinstall your OS again and enjoy fast speed.
NOTE:always remember to use an updated anti virus on your Laptop.
and if your laptop worked slow again use this way:
1- start "RUN" from start menu.(if you are using windows 7 go to accessories)
2- enter "msconfig".
3- go to startup tab.
4- disable some installed software (like yahoo messenger or ID Manager etc) in start up but be careful not to disable windows applications.
Jan 12, 2011 | Toshiba Computers & Internet
I have a Toshiba Satellite running Vista and am having all kinds of trouble lately. I'm getting blue screens, trouble shutting down, 'Not Responding', etc errors. I use this laptop for both personal and...
as long as you are not having a hardware issue, windows 7 fixes alot of vistanogo's problems. i would recommend windows 7 professional for mixed home office use and 64 bit. if you are having alot of blue screens, i recommend trying to reload windows to factory settings. the 0(zero) key is the one you press and hold with eht battery out and connected to dc power to get to the restore partition. follow the prompts and reinstall. if this works reinstall all the updates for vista up to and to include service pack 2. then purchase windows 7(do not recommend pirated software because of the risk of viruses and errors). install the update to windows 7 option and repost on your findings.
Dec 07, 2010 | Toshiba Satellite L355D-S7809 Notebook
I have a HP compaq 6735s notebook and it currently has a virus on it called security tool. i was wondering how to get rid of it because whenever i try to open a security program to get rid of it the virus...
Hello
I would suggest a full format and a reinstall of the operating system.
At the links below you will be able to read step by step instructions on how to reinstall your Operating System.
Windows Vista
Windows 7
Hope this can be of help.
Kind regards
Andrea
Sep 30, 2010 | Computers & Internet
Every time i start my hp laptop running windows 7 i get a message saying: ''there was a problem starting your winmzh32.rom The specified module could not be found.'' how to get rid of it? what caused it?
hi,
This may because you might have unknownigly deleted this component.When you scan your computer for virus also the antivirus may delete some coponent. To get rid of this please format/reinstall your window 7 operating system. you wont get this problem again.
thanx
Jul 21, 2010 | HP Pavilion dv6000z Notebook
Toshiba Satellite L500 Series Notebook Logo
90 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
