Question about Pinnacle Studio Version 9 for PC
Creating a Disc project
No disc writer device found under setup cannot continue to burn project to disc HELP!! I Have Pinnacle Ultimate Version 11
Loaded a patch Studio 11.1.2 solution is valid for Pinnacle ultimate Ver 11
Posted on Jul 10, 2008
Pinnacle Studio Ultimate 14 - I can't get video projects to burn. Photo projects work well. I use Dazzle to load video from a vhs into Pinnacle. Seems to work well and I create a project. When I go to...
A general workaround would be to let your software create an ISO image instead of burning a disc. Then burn the ISO with a known-good burning software (many user here - me included - recommend ImgBurn).
Feb 17, 2011 | Pinnacle Studio Ultimate 14 for PC
Sir i download Pinnacle Studio 12 ultimate...but there is showing me all files/ RAR HOW CAN I INSTALL THIS SOFTWEAR without setup file there is all rar files
Its seem like you have downloaded a ISO file or Rar file extract the first rar file , mostly it will unzip all the file when you unzip the first file then you can install if it is a ISO file burn it to a disc using Nero or BurnXp software.
Nov 28, 2010 | Pinnacle Studio Plus Version 11
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
Whenever I try to burn a disc on Pinnacle 12 Ultimate the burn fails. Then it tells me that I need to use an empty or re-writable dvd. I then used an empty re writable dvd and still the burn failed, and it...
The new Pinnacle Studio 12 includes more than 25 new features and more than a ... This is an upgrade. so you need Pinnacle studio 11 first. ...... could you tell me if u have tried that on a different computer with out ..... of data of the Pacific and burn it then because a compact disc and then the ...
Jul 18, 2010 | Pinnacle Studio Ultimate 12 for PC
Pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Feb 14, 2010 | Pinnacle Studio Plus Version 11
When making / creating a DVD, how do you make the "Play" button work, so that the result of your movie you will select the "Play" button and your movie will play. Also how do you create chapters, but allow...
hi there,
you can find the manual here :
Pinnacle Pinnacle Studio Ultimate Version 11
and in other languages please look here :
I suggest to look under the word :
Scene detection ...............26
The Video Scenes section ....... 40
Output to disc media ... 243
Have a nice computing
Hope that helps
IF NOT then try to return here
Please rate my answer
Dec 09, 2009 | Pinnacle Studio Ultimate Version 11
Hi, The music added to my projects does not sound ok after burning them to DVDs. It sounds ok when played directly from the project file in Pinnacle Studio on my computer, but when burned to a DVD it...
Click on set up>video and audio preferences>unchecked background rendering>click on "used this codec for background rendering>click and choose MPEG2 for best output to disc. Now click on project preferences>click on delete button and then choose delete auxiliary files for all project and then click okay. Try burning your video again.
Nov 08, 2009 | Pinnacle Studio Plus Version 11
Video and audio lose sync when disc is burned
If your video and audio is out of sync you need to repeat burned to your dvd disc again.
Insert your blank DVD disc and then after that do this.
Click on start button of your Studio>video and audio preferences>uncheck background rendering>check used this codec for background rendering>check the pull down arrow and choose MPEG2 for best out put tot disc. Click on prject preferences>look for delete button click it then delete aux file for all project then click okay. You may now try to burned to disc again.
Jun 01, 2009 | Pinnacle Studio Plus Version 11
Studio 11 want allow me to burn my project to dvd
I suggest to render the project to a video file first avi conversion to isolate the case. Once you have finish import the AVI file in the pinnacle did try to create now the dvd disc so that the rendering process will be fast since that you already have the file not the project.
Jan 05, 2009 | Pinnacle Studio Plus Version 11
Pinnacle Studio 11 ultimate
To highlight the person you need to use spotlight video effects which can be found to your video tools under video effects> bravo vol 2. You need to install your Studio 11 bonus dvd disc.
Sep 30, 2008 | Pinnacle Studio Plus Version 11
Pinnacle Studio Version 9 for PC Logo
272 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
