Question about Dishwashers
Hello, my dishwasher doesn't drain - Dishwashers
  • 417 Answers
check for a stuck float inside corner, there may be a cover over newer models, its a round white thing in the front corner, it should move up and down and click once you get the cover off. if thats not it next to the sink is the aerator, pull the chrome cover straight up and off and unscrew the inner white part and look down in there. if that still doesent do it, have to go under the sink and undo the black or clear drain hose coming from the dishwasher into a bucket and study where its clogged under the sink. if its not that then it may be inside the trap inside the drain in the dishwasher, take the bottom rack out, undo the wash arm, unscrew the drain cover, undo the next drain cover, (theres usually 2) and then down in there may be the obstruction. shut the power off if you go digging into the pump of the dishwasher.
good luck
jm
Posted on Jan 03, 2011
Dishwasher will not drain
Hello there and welcome to fixya
Please check the following carefully
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it. Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 05, 2011 | Neff 24 in. S5409X0 Built-in Dishwasher
How do I find the pump on model #she44c06uc/48? Dishwasher wont pump water out?
Hello
When you say pump out water, do you mean the drain pump used to empty the hopper? Usually dishwashers have two pumps, one to empty it and one to supply water to the wash arms. If it drains but doesn't spray it sounds like spray supply pump is gone. Could be just a loose connection or it a dodgy contactor or relay, or the pump itself. Someone with a very basic knowledge of electricity and a multi meter could very easily diagnose this and you may be able to order the part.
Sep 07, 2011 | Dishwashers
Doesn't drain out all the way water stays in
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Maytag Dishwasher
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
My dishwasher doesn`t drain. there is water at the bottom at te end of every wash... what`s wrong? how can i fix it?
Hi
Daniel
Aug 06, 2011 | Whirlpool Dishwashers
Water doesn't drain
Hi
Daniel
Aug 03, 2011 | Maytag MDB8851 Built-in Dishwasher
I just install brand new dishwasher, and test it, but it doesn't drain all the water out, can you help.
Hello.
WHen installing your machine it should have a high loop in the drain hose that means the drain hose under the sink is higher at one point that the drain its attached too with a corregated hose this is very easy to usea plastic zip tie and attatch a part of the hose to a higher point than where it connects to the drain. DID YOU DO THAT ?? if not that very likely is your trouble
Hope this helps
Gene
Aug 01, 2011 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher doesn't drain completly, I took off drain hose to see if it was plugged. Any other ideas?
Hello, welcome to FixYa.
I understand by reading your post which indicates it is a dishwasher you appear to have a drain cycle concern, however if you could verify the make, i.e. Kenmore, Bosch, Whirlpool etc. And post the model number I'd be better equipped to help without generalizing.
I'll watch for your reply and try and help going forward. Thank you.
Regards,
Macmarkus :)
Jul 17, 2011 | Dishwashers
Hello. after washing water still inside of machine. MAYTAG QUIET SERIES 300.
Hello there and thank you for choosing fixya
Drain line/air gap
Pump
Belt
Motor
Timer
Jun 29, 2011 | Maytag Dishwasher
Water does not drain,how do I access the pump
Hi jolanda03,
Remove the Top Panel, fastened by 2 screws at the back, Then remove the right Side Panel, you should see the Drain Pump attached to the sump. To test it, you could attach direct power to the two pins on it (Alternating current, so position of connectors unimportant). If it works, it could be either that it is not receiving power from the PC Board, or the sump is clogged inside (Filter).
Hope this helps, if it did please rate with 4 thumbs up. A testimonial would be nice too. :-)
Apr 21, 2011 | Dishwashers
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
