Question about Cell Phones
I bought my phone last week tat time the battery was working fine .The battery gives back up for like 3 days .But past 2 days i need to charge my battery every night and if i dont charge the phone gets switched off please help me
  • 2,133 Answers
There are two things you have tto check. 1. Your charger is perfect-check and replace it. And secondly, don't keep continuing in charging after you get indication of charging completed, remove charger.
Posted on Jan 03, 2011
My cell phone battery dies much quickly
Some cell phone batteries work fine for a short period of time and then rapidly diminish their holding capacity. The battery that has previously worked fine for 10 days standby begins a downward time drop to last merely a couple of days. A simple procedure that I have found to be invaluable is to:
1. Turn the power to the phone off.
2. Remove the battery from the phone.
3. Replace the battery into the phone.
4. Fully charge the battery.
5. Test the results by noting the time and day of item 4 above. Leave the phone on standby and see if the charge will now last many days. If so, congratulations, your phone is almost as good as new, and you didn't need to find and buy a new battery (or bother the customer service staff).
Feb 05, 2012 | Sharp Cell Phones
I'm using Nokia E63, my battery was gone a month before, so i bought a new BP-4L from Nokia point, it only gives 2 days standby back up, which my old one gaves me 5 to 6 days. is there something i
I will tell you what! I own 3 Nokia phones. And I know how to extend battery life (before recharge is needed) by UNloading the battery! Turn off location services, wifi, cellular data, and automatic updates, and only use them when you NEED them ... then, OFF they go!
During the Obama administration, they started TRACKING every citizen (and perhaps non-citizens too), 24/7/365.25! That is a terrible waste of battery power on all cell phones. Without all those TRACKING services on, my batteries (one per phone) can go for WEEKS without a recharge!
May 12, 2017 | Nokia BP-4L Battery
Charging problem
hi :) have your phone has been water damage ?? most after water damage,phone mother board's charging piont will be pro,tat only way u can do,pls send to mobile shop for repair it.
Jul 08, 2010 | Nokia N70 Cellular Phone
Nokia e63 won't switch on or charge
hello,
this have nothing to do with your phone battery and the phone charger
from your statement what you need to do to fix up the problem is that you have to make a change of your phone charging port this is well the problem is from
the charging port bad
dole it will give a sign that it charging but the same time it will discharge the power and this can cause a damage on the battery bass on constant charging
what you need to do is that you are to make a change or replace the port with a better one
if you can not do the fix up your self then you will have to take it to a very good phone work shop around you to do the fixing then your phone will work fine again
thank you .
May 01, 2010 | Nokia E63 Cell Phone
My K800i battery dies very quick
Dear Friend,
                 U are saying that u have bought this mobile 2 yrs back so check wither ur battery has been expired and change it.Otherwise switch off ur mobile and put it in charge and check it out the normal standby for any mobile is 2 to 3 hrs.Kindly check it and revert back
Regards,
Aysaam
May 06, 2009 | Sony Ericsson K800i Cellular Phone
RAZR needs charging 2 times a day even with new battery.
Drain the battery completely 2 or 3 times, then fully charge it and see how long it lasts. If this doesn't help then you might want to take it back to the store. Your phone is obviously trying to figure something out which is sucking down the battery. Bluetooh will drain a ton of battery out for long periods, hence keeping it hooked up in the car. I have gone through multiple razr phones in the past and they all sucked down batteries pretty quick so in the case, blaming the phone is an option :) . You can also try taking the battery out to give the phone a good restart, perhaps leave out for 30 seconds or so. I wouldn't recommend sending it in to Motorola, they like to find ways to charge you to just have it looked at.
Hope this helps! Don't forget to rate :)
Apr 08, 2009 | Motorola Mobility RAZR V3
LG viewty ku990 - no battery life and phone gets really hot
Hi
I dont know if this will help you, but it helped me. I had the same problem, with phone not holding charge and getting really hot both during and after complete charge.
I needed my memorycard from my LG to my other phone, so I took it out, and off course the phone needed to be charged so I charged it, and... it did not get hot at all, and when it was finished, the charge lasted a day and a half!! Now the problem is I cant use the memorycard anymore in my Viewty :S Win/Loose situation i guess....
Dec 26, 2008 | LG KU990 Viewty
Sony Ericsson W910i wont charge or turn on?
don't know if this will help,
I had this same problem a couple of months ago, battery appeared to be charging but got emptier and emptier, tried different chargers and no improvement etc.
Friend has same phone, used their battery in my phone which was charged and phone was working fine, meanwhile, charged my battery in their phone and it charged fine and then for 2 months no repeat of the problem...
then last week, it happened again, trouble is this time i'm on school holidays and can't use the friend's phone for another 3 weeks!
Apr 15, 2008 | Cell Phones
My sidekick 3 wont turn on
my sidekick 3 wont turn on at all,, it charges but when i go to turn it on. nothing.. how can it get fixed or wat kind of profesional help could i get to fix it?
Dec 01, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Cell Phones Logo
46 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
