Question about Toshiba Satellite M35X-S349 Notebook
Won't boot up.
Hello:
I have a Toshiba Satellite M35X-S349 laptop. I recently had issues with the DC jack but everything else was working fine. But yesterday morning when I turned it on the HDD led blinks once and thatz it. Nothing else happens. No display nothing. I took it to the store and they checked my HDD and reseated my memory. But still no use. HDD is Ok. They said my motherboard is dead. And told me it is better to get a new one. My question is is there anyway I can get my motherboard fixed. The night before this happened I was using it on battery power without any issues. Please help. My Thanks in advance. My email id is anilkpa@yahoo.com
Thanks
Anil
  • FJDM Jul 10, 2008
    I HAVE THE SAME PROBLEM AND WENT BACK TO STORE 6 DAYS AFTER BUYING IT THE TOLD ME IT HAD TO BE RESET BY TAKING OUT THE BATTERY AND STRATING THE COMPUTER WITH JUST THE POWER CORD. IT HAPPENED AGAIN I WEEK LATER THE DID THE SAME DIDNT WORK UNTIL THE 11TH TRY AND AGAIN THE GEEK TOLD ME IT JUST HAD TO BE RESET. NOW IT HAPPENED AGAIN THEY SAID THEY CANT DO ANYTHING ITS OVER 14 DAYS. SO WHAT DO YOU DO THROW IT OUT?
Anilkpa, I don't know if your tech ran a diagnostic or was able to.
It doesn't hurt to take it somewhere else for a 2nd opinion. If the mobo is dead I'd do what the tech advised.
Question by FJDM,
"SO WHAT DO YOU DO THROW IT OUT?"
Definately not. Did you buy this new ? As is ? What does your warranty state ? Usually a store will offer a limited warranty and extra avail thru the manufacturer or if you pay more, right thru the store. 15 days seems a little short in any case and you reported the problem to them BEFORE that period.
It sounds like what you're dealing with is a customer service issue, bypass that technician and ask for the Customer Service Manager.
Posted on Jul 29, 2008
RAM upgrade
(1) flip the Notebook/Laptop PC over - see Fig.1 below
(2) find the memory cover - it really easy to find in this photo.
Fig.1 Toshiba M35X bottom view - the memory cover is seen at center left and secured by a single screw.
(3) remove the (1) screw securing the memory cover.
Fig. 2 Toshiba M35X laptop shown with memory cover removed and HDD (Hard Disk Drive) removed, and with the HDD cover flipped up.
The RAM (SO-DIMM boards) are visible at center left.
The HDD cover is seen at the bottom of the photo.
(4) Using proper anti-static/static control techniques, clip alligator clip or your anti-static wrist strap to a frame ground of the laptop at an I/O connector or frame ground under the HDD cover.
(5) carefully remove (2) old 256 MB SO-DIMM DDR333 memory modules.
Store old memory boards in the anti-static plastic baggie in which the new memory boards were shipped.
(6) install (2) new 1GB SO-DIMM DDR333 boards, for total of 2GB of system RAM.
(7) reassemble system, and boot OS (operating system).
The laptop's ROM BIOS will auto-detect the new RAM and begin a standard POST (Power-On Self Test).
(8) If OS is MSWindows, it will also auto-detect the new memory, and allocate it to application software.
The technology of the Toshiba Satellite M35X-S349 memory module is called
DDR333, meaning DDR (Double Data Rate) SDRAM (Synchronous Dynamic RAM), at a memory bus speed of 333 MHz.
The Form Factor of the DDR memory card is SO-DIMM, which stands for Small Outline DIMM (Dual In-line Memory Module) (see photo).
Reference: http://en.wikipedia.org/wiki/DDR_SDRAM
Reference: http://en.wikipedia.org/wiki/SO-DIMM
Fig.3 Each 1GB SO-DIMM DDR333 memory module will look like this one.
The Toshiba Satellite M35X-S349 supports a maximum of two SO-DIMM memory modules.
Each memory module can hold (a) 256MB, (b) 512MB, or (c) 1GB,
in the SO-DIMM Form Factor compatible with the Toshiba M35X-S349 Notebook PC.
Dec 03, 2011 | Toshiba Satellite M35X-S349 Notebook
Satellite M35X-S349 PC Notebook: How do I speed up my toshiba pg 35 laptop...
RegTOOL can helps you scan your PC, safely clean the errors & invalid entries cause system slow, freezing and crashing, and repair registry problems to speedup your computer performances. It is easy to use.
http://www.keep-pc-clean.com/
May 18, 2010 | Toshiba Satellite M35X-S349 Notebook
Toshiba m35x-s349 turns on but does not boot
check battery power. Lots of times laptops won't boot if the battery has gone down to low. Probably has just enough charge to turn the machine on but not enough charge to boot the machine.
Nov 09, 2009 | Toshiba Satellite M35X-S349 Notebook
Boot Recovery Wizard
try f1 f2 if that dont work then f10 f11 or f12 it has to be 1 of them
Oct 07, 2009 | Toshiba Satellite M35X-S349 Notebook
Computer crashes when turn on Wireless switch
problem:sounds like polarity is switched on wireless card
Solution: remove cover plate on bottom and make sure black wire runs to Main and white wire runs to AUX
Aug 02, 2009 | Toshiba Satellite M35X-S349 Notebook
Toshiba Satellite Laptop M35X-S167 - Windows Won't Start
Please try re installing your operating system. (Genuine windows xp or vista recommended)
If the problem still persists feel free to get back me @
deepuunni1985gmail.com
Jul 19, 2009 | Toshiba Satellite M35X-S349 Notebook
Pops up lime wire, curser won't work, extremely slow
Try downloading Avast Free version. I have had great success removing things infected from LimeWire with this software. When you download and get it set up, it will ask if you want to set up a boot scan. Say yes. Let the system re-boot and run. if something pops up it will pop up a window with a siren on it. move everything to the chest. Do not delete anything as it may be a system file that you delete. Lime wire is a haven for viruses. I would suggest getting rid of it.
Dec 02, 2008 | Toshiba Satellite M35X-S349 Notebook
Satellite laptop turn off
Hello maurice. Looks like you have an over-heating problem. The CPU has more chance of overheating when you use graphic intensive applications like Games etc., Clogged heatsink is one of the reasons for over heating. It would require you to get to the heatsink and clean any dust or any other stuff that may have got clogged in the heatsink. Another Idea will be to buy some kind of laptop cooler like the one below.
http://www.circuitcity.com/ccd/productDetail.do?oid=89840&om_keycode=3
Sep 28, 2008 | Toshiba Satellite M35X-S349 Notebook
No display
Hello. By what you`ve said, i would suggest you to get the computer to a service. It seems like a motherboard problem
Jul 03, 2008 | Toshiba Satellite M35X-S349 Notebook
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
133 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
