Question about POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer
I have replaced a posiflex receipt printer with a bixolon SRP-350 plus. Both printers are serial printers. I haven't been able to get a peep out of the Bixolon. I have tried changing all settings possible on the POS without success. The print test works ok , i cant get anything out of the printer when I send from the register. My POS system is a Toshiba TEC running winpos restaurant software
  • 5 more comments
  • peter454 Jan 03, 2011
    This POS system is a Toshiba Tec system not a normal PC. No CD drive etc.
    All controls are touch screen set up for restaurant service, not normal windows options.
    Peter
    I am using a touch screen Toshiba Tec POS system all printer setup is pre loaded, The system does not have an external disk drive. My Posiflex printer worked first go - just plugged it in. The Bixolon doesnt respond at all. Not a peep.
  • peter454 Jan 07, 2011
    The Toshiba Tec Winpos (Wilpos) software will only accept Toshiba or Epson Printers. I am unable to load any other drivers on to the system. The posiflex works because its settings are emulating the epson printer.
    This is straight from Toshiba.I was unawre they had a locked system until I purchased the Bixolon Printer
    I am sure the printer is Ok, brand new
    I believe it to be a restriction of the software and hardware by Toshiba .
    I have attached the link to the system.
    http://www.toshibatec.com.au/products-1/...
    The system does have USB but not an accessible disk drive
    When I said the print test works - this is just a self test facility on the printer it self not through the POS.
  • peter454 Jan 09, 2011
    I have checked the baud rating for both the machine and printer - both 19200
  • peter454 Jan 15, 2011
    The baud rate is 19200 the same for the POS and the new and old printer
  • 355 Answers
If this is a serial printer i bet your problem is the baud rate setting, it's probably not the same speed as the old printer. check page 12 of the manual HERE and see if it's set correctly. They also have a "technical inquiry" page where you can ask questions HERE
Posted on Jan 07, 2011
  • 1,472 Answers
Peter454
You stated that you got the test print to work. If this correct it like it is working properly and that you have a software problem inside the POS system. Now I have not used this POS system before but when I worked fast food we have to reinstall thermals software to fix problems from time to time.
So is this a dumb termial that connects to a master system or is this the master unit.
Let me know the model of the POS system so I can look for some options on repairing the printer. Also if you know the versions of the Windows and POS software this will help me as well.
Issken
http://www.fixya.com/users/issken
  • Will Hartford
    Will Hartford Jan 07, 2011
    peter454
    I am still looking on info on the system. Just for you info I did find the user manual on the Americas site but it did not cover anything about the printer setup.
    http://www.toshibatecusa.com/Products/So...
    Question when you do the printer test where are you at in the system. It sounds like you just need to select the printer in the software how ever if it does not read the device properly you may not be able to select it. This is why I would like to know where you are doing the testing from. You may be able to install the drivers via the USB port to allow the POS system to properly see the printer.
    Issken
  • POS X Master
  • 19,396 Answers
Hi.
The Posiflex was already installed in WinPos. Did you install the Bixolon POS driver correctly?
Here download page with drivers and installation guide.
Ensure you follow directions in the installation guide. See also FAQ page here (you will need to register and login).
Regards.
Ginko.
Posted on Jan 03, 2011
  • Ginko
    Ginko Jan 14, 2011
    Hi.
    Did you try calling Toshiba to verify if there is effectively a restriction?
  • POS X Master
  • 2,600 Answers
Now go to Add priinter device then remove all printer driver and go to control panel then device manager then go to printer unistall all printer device right click on it then remove all driver unplug the printer data cable from your pc then restart your pc after restart your pc then plug the data cable of your printer install printer driver from your printer cd software go to run choose setup install printer driver which printer do you want to use then restart you pc then try for print.
Thanks
Tony
Please vote me
Need for driver
Your printer sounds like it might be a bixolon srp-350 badged as a samsung. I dont know if there are android drivers for SRP350. There is an android sdk for SRP350ii. Anyway this is the site where you will find them if they exist - http://www.bixolon.com/html/en/download/download_product.xhtml?prod_id=3
May 30, 2013 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Can I switch my red for my black toner in a bixolon srp 500
Yes you can! but verify if you were working on wax or resin before.
Apr 08, 2013 | BIXOLON SRP-500CPG SRP-500 Receipt Printer
Please help with the following: Printer BIXOLON SRP 350 IG When I turn it on Power light: Green Error light: Red Paper light: Red The printer "beep ... beep" continously
Looks like you'll have to contact Samsung http://www.samsungminiprinters.com
The operators manual does not give any indication about what to look for if the error light is on.
Here's what the manual states about the paper light:
This light indicates the near end of the paper roll. Install a new paper roll and the printer will continue printing. When the light blinks, it indicates the self-test printing standby state or macro execution Standby state when the macro execution command is used.
Jul 18, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
I have bixolon srp 350 for my restarant when i give print command from register it always comes in queue with showing error. i done all softaware re installation and self test for printer everything works...
hello, im trying to send a print to my BIXOLON SRP350 Thermal printer by java codes. but java can't use the all the page width, what should i do to use all of the page width ?
Feb 20, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
I have developed an ms access POS. When i print receipt to samung thermal printer srp 350 ver 2, it prints very slow. i have tried several drivers but i end up with the same slow printing problem. I am...
itecghana, printing slow is probably an issue of the interface type (serial, parallel, usb, ethernet...) and not the printer itself. The Bixolon 350 has a self test printout capability (turn on printer while holding down the feed button) which'll demonstrate the print speed capability of the printer.
My guess is you have a serial interface (COM port), serial is notoriously slow when printing via any windows driver.
If the printer you have is a 350, one solution is to change the interface card on the printer from Serial to USB. The part number of the USB interface card is IFA-U Type, can buy one for about 35 bucks online.
Jan 10, 2011 | Samsung SRP 350 Thermal Printer
I have replaced a posiflex receipt printer with a Problem with the POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer I have replaced a posiflex receipt printer with a bixolon...
If the print test works, then that rules out cables, etc. Definitely sounds like a comm setting issue. The most common problem with swapping serial printers is incorrect baud rate. Is that winpos from quest in Aus? I think they might use 9600 baud. You change the printer baud rate using the dipswitches under the panel on the bottom of the printer.
Jan 03, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Linux drivers for Samsung SRP 350 Plus Thermal Printer
This was originally a Samsung printer, and they had plans to release a Linux driver. However after some corporate games it's now owned by Bixolon, and everything Linux has been axed.
Jan 19, 2009 | Samsung SRP 350 Thermal Printer
POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer Logo
409 people viewed this question
Top POS X Office Equipment & Supplies Experts
jasbo
jasbo
Are you a POS X Office Equipment and Supply Expert? Answer questions, earn points and help others
