Question about Sanyo Cameras
My sanyo digital camera model vpc-e860 fell down and the lens dis align wat would i do?
SOURCE: sanyo vpc-e760 digital camera
lens error 21
Posted on May 14, 2008
jerryg50
  • 1667 Answers
SOURCE: my digital camera say lens error:21
The lens has a servo fault. This can be either the lens motor, the helicoil in the lens is jamming, or the servo drive electronics has a fault.
You will have to send the camera for service if you want to fix this. I doubt you can fix this yourself unless you have access to the parts, and have the training and tools to do this type of service.
Jerry G.
SOURCE: the sound with the sanyo(vpc-5500) digital camera
I thought my pink sanyo VPC-5500 was messed up, but once I imported my pictures and viceos onto my computer, I opened up a vidoe player and the sound worked perfectly. So if you have the USB cable, hook your gigtal camera up to your computer and import what's on it, then you will be able to open up a video player and watch a video that was stored on it.
Posted on May 23, 2008
SOURCE: my Sanyo VPC S670 - digital camera lence is stuck
My camera had the same problem it would turn off after i tried to take a picture and it would say lens error 112 all i did was put duracell batteries in it as soon as i did it worked it seems wierd but try it its cheaper than getting a new camera
Posted on Aug 06, 2008
  • 102366 Answers
SOURCE: lens error 22 or 25
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
Sanyo VPC-S1415 lens stuck in camera
that's happen due to physical damage like dropping etc.
try to open inside and align well the lens mechanism
Jul 01, 2016 | Sanyo vpc-s1415 - Vpc-s1415 14.0...
Screen of my cam (Sanyo Xacti VPC A5) has lost its visual after fell down from table..
Cameras do not fair very well from even slight impacts, it will need to be looked at by repair shop.
Jan 26, 2013 | Sanyo Xacti VPC A5 Digital Camera
MY CAMERA IS VPC-E860 IS BLURD WHEN TRY TO USE TO PICTURE WHAT SHOULD BE THE PROBLEM
You should try changing your settings/mode in which you are currently using your camera.
Jan 18, 2012 | Sanyo VPC-E760 Digital Camera
My camera fell on the lenns while it was on and the lenns got stuck. The model is VPC-E1500TP. Is there a way i can repair that at home?
There really isn't much you can do with your camera lens at home because of how great of a force that drop was on the lens. From your description, I'm assuming it pushed the lens back into the camera, the mechanism for the lens to rotate is probably damaged. Contacting Sanyo customer support is your best bet.
May 16, 2011 | Sanyo Cameras
Sanyo vpc s1070 displays - lens error when turned
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Apr 18, 2010 | Sanyo Vpc-s1070w Digital Camera
Sanyo VPC s1285 stuck lens.
Well lens errors are very common in these digital cameras. Usually it's sand or grit interfering with the lens extension mechanism.
Check the below link to do a try to correct it -
If further you have the same problem it means there is a gear-motor alignment of the lens which moves in and out with the help of motor. This part is replaceable at an authorized Sanyo Service Center. Aprox repair cost is $120.
Good Luck!! Thanks for using FixYa
Mar 31, 2010 | Sanyo Cameras
Sanyo vpc s1275 lens error 0x0311
Good Luck!!
Jul 30, 2009 | Sanyo VPC-CG65 Camcorder
Lens Error: 0x12110000 when previewing pictures in camera.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 01, 2009 | Sanyo Vpc-s1070w Digital Camera
My Sanyo VPC S670 - digital camera lence is stuck
Jul 19, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Cameras Logo
35 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
