Question about Microwave Ovens
Display works well but is very hard to read even in the dark.
  • 472 Answers
UNFORTUNATELY THIS IS A COMMON PROBLEM..THEY HAVE 2 SEPARATE LIGHTS IN THESE DISPLAYS AND ONE HAS WENT BAD...UNLESS YOU CAN SOLDER AND FIND THE REPLACEMENT LIGHT BULB THE ALTERNATIVE FIX IS TO REPLACE THE DISPLAY CONTROL ON THE UNIT....PLEASE VOTE...GOOD LUCK TO YOU
Posted on Jan 03, 2011
Hi our microware is not working, can you help me?
I have serviced 100's of microwaves and the most common problems for microwaves not working 1)fuse blow(but display will be dark), 2)not plugged in(or house fuse blown) (microwave display is dark and other outlets would be off) 3) connections to one of the door switches is burnt out. The display is not dark but microwave will not work. The wire going to the switch looks black right at the switch.(this wire must be removed and a new connector attached to wire and then reattached to the switch
Dec 24, 2017 | Microwave Ovens
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
Advantium display reads "nite"
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Feel free to contact me directly (see below) if you have other questions.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 30, 2017 | GE Advantium 120 Convection/Microwave Oven
Display panel is scrambled on my Dacor DMT2420 microwave.
There are two options for this model:
- You can order our exclusive modified control unit with our proprietary upgrades for $135, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $40.
For details, see: http://www.microwavedisplay.com/exchange.htm
- Or we can repair your existing control unit for $39.95 in about a week with a one year guarantee.
Jan 25, 2009 | Dacor DMT2420 1200 Watts Microwave Oven
Will not cook
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Please reply back with your brand and model number so we can help you.
Oct 25, 2008 | GE JE1590 Convection / Microwave Oven
MICROWAVE NNS541BF
That would be the child lock.
Sep 06, 2008 | Panasonic NN-S254BF Microwave Oven
The digital display is very dim and hard to read even in the dark. Is there a way to adjust the brightness?
I have a Sharp Carousel 1.5kW microwave oven with model number R-310F(W)C. The LCD dispaly on my unit recently became very dim. After check the small circuit board on the front panel, I found that the problem is caused by the LCD backlight driver which drives three surface mount LEDs. As the LED driver is inside a chip built on a small daughter card, it requires a replacement daughter card, or the entire circuit board for display and keyboard. A simple alternative solution is to cut the link between the three LEDs and their driver, then build a small circuit to drive the LEDs. I can provide the circuit diagram if interested.
Apr 13, 2008 | Microwave Ovens
SHARP R-316F
easy to fix you need to cut the tracks to the led lights then solder 2 wires to the leds next use a 1k resistor on one of the wires then conect it straight to the power surply just after the bridge rectifier noteing+ and -
Mar 06, 2008 | Sharp R-202EW Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
